  3. Socket settimeout times out every time for no apparent reason
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
2 Posts 2 Posters 1.0k Views 2 Watching
    In the pseudo code below settimeout always times out after ten seconds. I can set the timeout to any value and it always times out when it reaches the set value. But why? The transmit is fine and the data is rx'ed OK exactly as expected. ie the expected data is always the length expected. There are no partial results.
    The only way to get it to work is to set the timeout to zero. ie no timeout delay and use socket.select to become a defacto timeout. It works great after that.
    -- Socket library version is: LuaSocket 3.0-rc1
    m_tcp = socket.tcp()
    m_tcp:settimeout(10)    -- set to zero when using socket.select fix
    m_tcp:connect('ip_address', port)
    repeat
        -- send request
        local txMsg('Data request. Hi what is the hardware status? (ongoing)')
        m_tcp:send(txMsg)
        -- THIS fixs the problem as long as m_tcp:settimeout() is set to zero
        -- Wait on the socket for 50 msec for rx data.
        -- The rx data will arrive in the rx buffer in less than this time.
        -- *** local rxlist, _, selectStatus = socket.select ({m_tcp}, nil, 0.05)
        -- get the response to the request
        -- get the 16 byte data header, that contains the length of the payload
        local expectedLength = 16
        local s, status, partial = m_tcp:receive(expectedLength)
        if (status == "timeout") then print('timeout') end
        -- the returned data amount varies but we know what it is from the header just rx'ed
        expectedLength = s[1]
        -- do this every 0.5 sec;
        -- we're regularly updating the status of a hardware device
        luup.sleep(500)
    until false
      mrFarmer
      Hi a-lurker,
      This is a pesty problem with the LuaSocket lib that has been fixed years ago, but for some reason is not in the latest GA packages. The problem is in buffer.c, the timeout is only handled correctly if it is compiled with debug flags. Look at about line 80, and if that shows a compiler flag it will have the problem you see. You can install the luarocks scm-2 version and it should work as expected. I have the running with openLuup without any problems.
      Cheers Rene
        165.4k
