  3. Looking for Bluetooth device for smartphone audio transmission
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
1 Posts 1 Posters 660 Views 1 Watching
    mberezinski
    Hello,
    I am in search of a device capable of using Bluetooth to connect with a smartphone and serve as its primary sound source on demand. This device should function similarly to conventional Bluetooth headphones, which automatically become the phone's sound output upon activation. However, this device should differ in that it transmits the audio signal to an amplifier via a jack, SPDIF, or similar connection. Alternatively, it could be an integrated amplifier that directly sends the signal to passive speakers.
    The control of this process should be manageable through an API such as MQTT, REST, MODBUS, or similar. Are you aware of any devices that operate in this manner?
    The concept is as follows: upon entering the bathroom, I would press a wall-mounted switch. This switch would send a signal to the Bluetooth device, prompting it to connect to my smartphone and seamlessly continue playing the audiobook I am currently listening to. Instead of using the phone's speakers, it would seamlessly start playing through ceiling-mounted speakers.
    Many thanks 🙂
      159.2k
