  3. looking for a light switch with presence sensor?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 4 Posters 4.1k Views 3 Watching
    tommydog
    I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied.
    I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film.
    Are there any products on the market that would work for my application?
      Hi there!
      Reliable presence detection is notoriously difficult. There are technologies and work-around solutions, but I hesitate to recommend anything at the outset.
      Let's see if anyone here chips in with a great idea.
      • C Offline
        C Offline
        christian_fabre
        I am testing the following presence sensors:
        Sensor FP2 - AQARA
        Sensor SNZB-06P - SONOFF
        The Aqara detector can detect several areas, and several people, and seems to be very reliable.
        I'm starting to test the sonoff which only detects a presence and which costs much less.
          RogerO
          166 CAD
          Red Series (Z-Wave) - Smart Presence Sensing Dimmer
          Inovelli
          • R RogerO
            166 CAD
            Inovelli
            tommydog
            @RogerO said in looking for a light switch with presence sensor?:
            Inovelli
            Is it any good? I don't see much information on it
            R 1 Reply Last reply
            • C christian_fabre
              Sensor FP2 - AQARA
              tommydog
              @christian_fabre said in looking for a light switch with presence sensor?:
              Sensor FP2 - AQARA
              thats interesting what you say about the Aqara being reliable. I read a few reviews of it where the user complained that it was unreliable.
              How does the Sonoff compare to the aqara in your testing?
              Secondly, it seems that some of these devices are quite power hungry in themselves, requiring around 1amp.
              The other option I saw was Ecobee sensors, although they only seem to work with their themostat system, but they look very power efficient. Although I am not sure if they are true presence sensors?
              • T tommydog
                Inovelli
                RogerO
                @tommydog It is in prerelease ordering. I don't have one, had just heard about it.
                  160.0k
