  4. Handling Dead Entities and Renamed Entities
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.6k Views 3 Watching
    Hello all.. been a minute! I recently rebuilt my Z wave network and migrated to a new z wave stick. In order to prevent any downtime I kept my original z wave network up and ran a docker version of Z Wave JS UI with my new controller. This way I could add device by device without having any devices down.
    I finally moved all the devices over to my new stick today. The final step was to migrate everything from my Docker instance of Z Wave JS UI to the HA add-on of Z Wave JS UI. However during this migration some of the names didn't populate correctly which I later managed to import back into Z Wave JS UI. The issue was in Reactor it is stuck on the default names and the entities are not updating. I removed the controller from Reactor, restarted, hard refreshed, and added the controller back however the new entity names have not updated. Also it seems like the old entities from my previous instance of Z Wave JS UI are lingering and not being marked as dead (I believe a certain amount of time needs to lapse before they're marked as dead in Reactor).
    My goal is to basically purge all the entities for the 'ZWaveJS' controller in Reactor so it can pull all the updated entity names and only the entities that exist in Z Wave JS UI. I cannot find a quick way to do this, I know entities can be deleted one by one, but with over 100 entities this would take long 😛
    I am guessing that if I added the controller with a new name in in the Reactor config it would pull the updated entities and names but I think that would break my rules since the entity IDs would change (I made sure to name all the entities the exact same as they were previously to prevent this issue).
      I don't know if there's a UI option, but when I migrated things, I just stopped reactor, opened the files and removed everything from reactor/storage/entities/zwavejs (after a backup). And start again, of course. It's brutal for sure, but it worked.
      PablaP 1 Reply Last reply
        @therealdb This did the trick thank you!!
        Patrick, how should Reactor handle updated entity names and deleted ones for Z Wave JS? With HA it seems fairy instant with a restart that renames and deleted entities are updated but not the case with Z Wave JS.
        • PablaP Pabla marked this topic as a question on
        • PablaP Pabla has marked this topic as solved on
          Reactor's ZWaveJSController will take the first name it is given and that sticks until you rename it. If you rename it in Reactor, no amount of changing it in ZWave JS will change it in Reactor.
          This is by design. It is possible, for example, to use entity names in getEntity() expressions. If Reactor just changed them on its own like HA, that would break those expressions.
          By the way, HassController behaves the same way. If the name of a HA entity changes, the corresponding Reactor entity doesn't follow the change. You can see it in the extended attributes of the Reactor entity, but the Reactor entity itself retains the unmodified name.
          Deleted entities are marked "dead" in Reactor and will be removed at a later time if they don't reappear. Reactor doesn't immediately remove entities just because the remote hub omits them. Some hubs may not fully enumerate all devices during startup, so removing an entity only to recreate it a few seconds/minutes/hours later would be troublesome. If you're impatient, you can purge dead entities by using the purge_dead_entities action on the Controller's system entity (give it small age limit, like one second; it only acts on entities that are already marked dead).
            @toggledbits interesting, I totally understand the rationale why the controllers act this way. However, I feel like there are times where you’d want to batch update entities. Could this be added into the UI, similar to the purge dead entities action? Maybe an “update entity metadata” action?
              162.5k
