  4. Constraints states visually do not match actual
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 690 Views 2 Watching
    When viewing a rule, the constraints conditions do not match the current state of the entities. After the rule runs then they will display what the state of the entity was when the rule fired but otherwise they do not update to show the current state. While editing the rule the entities show the correct state and they will change state in the editor window. The rule functions but visually does not look correct. I believe they used to show the current value when viewing the rule. I have tried Safari and Chrome browsers, hard refreshed the browsers, restarted MSR.
    Screenshot showing that Motion Overide constraint is false but actual state is true. (Rule has not executed yet.)
    Screenshot 2025-12-09 at 6.38.30 PM.png Screenshot 2025-12-09 at 6.39.36 PM.png Screenshot after rule execution:
    Is this the intended behavior?
    Synology Docker
    latest-25325-2c235fbb
    Mac Safari 26.1
    Chrome 143.0.7499.41
      Expected and known. Will be addressed later. Constraints are updated when the rule is evaluated.
        I guess I never noticed before as I thought they used to update.
        The rules function so just visual.
        Thank You for the information.
          162.9k
