  4. Time series documentation
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 2 Posters 2.7k Views 2 Watching
    Is the current manual (incl. examples) up to date with how retention value is handled in time series configuration? Referring to this post
      @tunnus Not entirely. I need to spend some time on that. As the post suggested, comment out or remove your retention configuration value. It will be computed from interval and depth.
      Simple moving average:
                name: "Outdoor Temperature Average"
                capabilities:
                  value_sensor:
                    attributes:
                      value:
                        model: time series
                        entity: "weather>home"
                        attribute: "wx.temperature"
                        aggregate: sma
                        interval: 60  # minutes
                        depth: 5
                        precision: 2
                primary_attribute: value_sensor.value
                type: ValueSensor
      Rate:
                name: "Garage Humidity Change Rate"
                capabilities:
                  value_sensor:
                    attributes:
                      value:
                        model: time series
                        entity: "mqtt>garage_handt"
                        attribute: "humidity_sensor.value"
                        aggregate: rate
                        interval: 30  # minutes
                        depth: 3  # last three samples, t-0, t-30, t-60
                        precision: 2
                      units: "%/min"
                type: ValueSensor
                  capabilities:
                    value_sensor:
                      attributes:
                        value:
                          model: time series
                          aggregate: sma
                          depth: 5
                          precision: 2
                  type: ValueSensor
        Rate:
                  capabilities:
                    value_sensor:
                      attributes:
                        value:
                          model: time series
                          aggregate: rate
                          precision: 2
                        units: "%/min"
                  type: ValueSensor
        @toggledbits I cannot get "accel" (acceleration) method to work. It used to work at some point, but at least with the latest builds (now using 25328) I'm getting "null" as a value. Entity values below:
        value_sensor.units=null
        value_sensor.value=null
        x_virtualentity.last_request_time=null
        x_virtualentity.request_failures=null
        x_virtualentity.template=null
        x_virtualentity.timeseries_aggregate="accel"
        x_virtualentity.timeseries_debug=[{"time":1766248080000,"value":694},{"time":1766248380000,"value":694},{"time":1766248680000,"value":694},{"time":1766248980000,"value":701},{"time":1766249280000,"value":701},{"time":1766249580000,"value":691},{"time":1766249880000,"value":691},{"time":1766250180000,"value":691},{"time":1766250480000,"value":696},{"time":1766250780000,"value":696},{"time":1766251080000,"value":696},{"time":1766251380000,"value":707},{"time":1766251680000,"value":707}]
        x_virtualentity.timeseries_depth=null
        x_virtualentity.timeseries_interval=5
        x_virtualentity.timeseries_length=13
        x_virtualentity.timeseries_nextsample=1766251980000
        x_virtualentity.timeseries_retention=60
        And configuration from reactor.yaml:
                  name: "Netatmo CO2 change rate"
                  capabilities:
                    value_sensor:
                      attributes:
                        value:
                          model: time series
                          entity: "hass>sensor_carbon_dioxide"
                          attribute: "value_sensor.value"
                          interval: 5
                          aggregate: accel
                          retention: 60
                          precision: 2
                  type: ValueSensor
        When I tried to drop "retention" and used "depth" instead, got the following error:
        Unable to configure time series "value_sensor.value" on "virtual9": missing required configuration 'retention'
        Controller: VirtualEntityController#virtual
        Last 15:56:17
        Looking at the entity values, there's "x_virtualentity.timeseries_depth=null", and if depth is needed in the calculation, that could be the culprit?
          You have to wait for the time series to fill before acceleration can be computed. depth is used in the calculation, as well as retention... that's a peculiarity of this aggregate (accel). There need to be at least 2*depth-1 samples collected before the calculation can occur.
          I have updated the documentation in the online version just yesterday, so check here.
            @toggledbits this configuration has been running for hours (retention being 60 min), and still "null"
              @tunnus OK. Let's start here: copy-paste the device attributes for that VEC entity (remember to use fenced code block formatting when pasting in reply).
                @toggledbits those were already in my previous post, or was something missing?
                  The previous post shows depth as null or not provided. Please specify both depth and retention, restart and wait at least one full interval, then copy-paste the attributes if a value hasn't been calculated.
                    @toggledbits ok, when I get back home I’ll try that. But wasn’t depth optional, i.e. defaults to 2 if not specified?
                      In the version you are using, it is still required; that's the docs leading the released code by a step (sorry). The version you are using also doesn't enforce limits well, so it allows values that could produce no result, or store more data than needed.
                      For example, given your retention of 60 and interval of 5, there would be r/i+1 = 13 samples in the series. But if you specify depth of 2, then only the most recent 2d-1 = 3 samples are considered... the other 10 samples don't contribute to the result value. A depth of 7 would be the best match for the given interval and retention (just mathematically, ignoring your semantic goals).
                        @toggledbits adding depth did the trick, thanks again!
                          162.8k
