x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
services:
reactor:
container_name: reactor
environment:
TZ: GB
restart: "always"
expose:
- 8111
ports:
- 8111:8111
volumes:
tmpfs: /tmp
Posters
479
Views
Watching
T toggledbits forked this topic on
Got it. Next build... tomorrow, or Sunday at the latest.
