x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
services:
reactor:
container_name: reactor
environment:
TZ: GB
restart: "always"
expose:
- 8111
ports:
- 8111:8111
volumes:
tmpfs: /tmp
Posters
528
Views
Watching
This topic was forked from Cloning actions in reactions does not work
What architecture are you running the container on?
@toggledbits amd64 (synology nas)
OK. I've respun 26140 docker images with some additions to the underlying minimal OS. Grab the updated image for your container and you should have ping back.
