  3. Docker
  4. Moving to Docker
Moving to Docker
A number of folk are running openLuup on Docker... ...and I'm about to try the same. There are a couple of epic threads in the old place: https://community.getvera.com/t/openluup-on-synology-via-docker/190108 https://community.getvera.com/t/openluup-on-docker-hub/199649 Much of the heavy lifting appears to have been done by @vwout there (and I've asked if they'll join us here!) There's a great GitHub repository: https://github.com/vwout/docker-openluup Hoping to get a conversation going here (and a new special openLuup/Docker section) not least because I know I'm going to need some help!
Docker
Openluup docker filling up disk space?
I've been doing other projects the past weeks, and now started seeing sluggish behaviour in the system.. SSH'ed in, and noticed that the harddrive was completely full! I had some other issues as well that caused it to fill up, but i noticed that when I removed the openluup container, that freed up 1.5GB! This is obviously not the persistent storage folder (cmh-ludl), what else can do this? On the base system, it showed as a massive sized /overlay2 folder in the /var/lib/docker/.. Mabye @vwout knows some docker-hints on this?
Docker
InfluxDB 1.x in docker
I've now gotten most of my applications/components into the docker system, only one left is influxdb. I allready have the database files on an external SSD, and the plan was to have a volume for the influxDB (which holds the .conf file), and a bind mount to the database folder. This is however not the only files of influxdb that needs to be persistent, when i load up the docker, influx has no information about the databases, even when i know the database folder is available. Anyone here know where influxDB stores database setup info? influxdb.conf just enables stuff and sets folders, the info on existing databases and settings is stored elsewhere. (should the docker forum be under software, not openluup?)
Docker
Grafana on Docker
As part of my hardware infrastructure revamp (a move away from 'hobby' platforms to something a bit more solid) I've just switched from running Grafana (a very old version) on a BeagleBone Black (similar to RPi) to my Synology NAS under docker. Despite the old system being on the same platform as my main openLuup instance (or, perhaps, because of this) and now with the new system the data has to be shipped across my LAN, this all seems to work much faster. I had been running Grafana v3.1.1, because I couldn't upgrade on the old system, but now at 7.3.7, which seems to be the latest Docker version. It's a bit different UI from the old one, and needed next to no configuration, apart from importing the old dashboard settings. One thing I'm missing is that the old system had a pull-down menu to switch between dashboards, but the new one doesn't seem to have that, since it switches to a whole new page with a list of dashboards. This doesn't work too well on an iPad, since it brings up the keyboard and obscures half the choices. Am I missing something obvious here? Thanks for any suggestions.
Docker
Moving to Docker
Scheduled Pinned Locked Moved Docker
62 Posts 11 Posters 45.2k Views 11 Watching
    It's MAGIC !
    I particularly like the look of this...
    This instills a sense of wonder in me... I mean, I know (almost) exactly how openLuup works, but to see it wrapped in a container running on a NAS, seems rather special. "Hats off" ("chapeau?") to those who have engineered this, not least @vwout.
    One is never quite finished, however.
    I understand that to make any changes last across container/NAS restarts, I need to make the volumes external to the container, as per the above yaml. So this is my next step.
    Any further insights welcomed. Perhaps Portainer is that next step?
    K Offline
    K Offline
    kfxo
    wrote on last edited by kfxo
    #21
    @akbooer
    I have been messing with this today. I do not currently run openluup through docker so this may not even be the best way to do this but it is what I did to get it up and running and with the ability to easily see and manipulate all openluup files within "File Station" on the synology.
    I created three folders on my synology:
    /docker/openLuup/cmh-ludl
    /docker/openLuup/logs
    /docker/openLuup/backups
    Then I created three volumes with a bind to the created folders
    'openluup-env' bound to '/volume1/docker/openLuup/cmh-ludl'
    'openluup-logs' bound to '/volume1/docker/openLuup/logs'
    'openluup-backups' bound to '/volume1/docker/openLuup/backup'
    I used portianer but you can ssh into your synology and use the command line to create these volumes with the binds, see this
    Then I created the container using portainer making sure to set the correct ports and volume mappings, which can also be done in the command line with
    docker run -d \
           -v openluup-env:/etc/cmh-ludl/ \
           -v openluup-logs:/etc/cmh-ludl/logs/ \
           -v openluup-backups:/etc/cmh-ludl/backup/ \
           -p 3480:3480
           vwout/openluup:alpine
    Hope this helps.
    Edit: The binds are not necessary, I only did it to make it easy to access the files. Without the bindings, the volumes are somewhat hidden on synology that is not easily accessible for example at '/volume1/@docker/volumes/openluup-env/_data'
      RHCPNG
      Good explanation, this is where it comes down to. But in the end, you probably want the bind to make your data persistent and, more important, easy acccessible.
        I'm still struggling with this. I've manually created some external folders, but can't get the multi-line command to work.
        @vwout, following my new experience with AlpineWSL on a PC (which I assume to be something very similar to Docker) I created the whole of the cmh-ludl folder as one single external volume. This is really convenient. Is it possible to make the same configuration for a Docker image?
        R V 2 Replies Last reply
          mrFarmer
          Hi @vwout, can your docker image also be used on the arm64 platform (Pi4)? If not, how would I go about building one? I think with an Unbutu docker and then use the same setup as on a plain Pi.
          I am setting up some new things on a Pi4 and came along this (https://github.com/SensorsIot/IOTstack) to use Dockers on a Pi. Looks like a very quick way to (re)build an environment from a basic starting point. Especially the split between user data and all else looks attractive.
          Cheers Rene
            Why would you want to do that? It’s not as though installing Lua is difficult. What am I missing?
            M 1 Reply Last reply
              RHCPNG
              #26
              @akbooer said in Moving to Docker:
              I don't know what AlpineWSL is, but you can make a volume for your cmh-ludl folder and map it in vwout's docker container.
              This is what it looks like in portainer, like a mapping. Really convenient, like you said.
              • R RHCPNG
                @rhcpng
                Thanks for that. I guess my question is why these have to be done separately, rather than just making cmh-ludl/ (and all its sub folders) external (which, effectively is what I’ve done for WSL.)
                I was trying to do it on the command line, since Portainer seemed to be several hundreds of megabytes, which seemed a bit of overkill just for this task (which, I think, is all I need it for.)
                  RHCPNG
                  You mean not splitting it up in backup, log and cmh-ludl? That's a choice of vwout. To be able to be flexible with what you store where, probably. You can do it with the command line too, but I'm not familiar with that. I don't think you have to do all mappings. Probably the cmh-ludl is enough, but I'm not sure.
                    mrFarmer
                    @akbooer Well, if I have a complete openLuup setup, except my data, in a Docker and I need to rebuild a system from scratch I can just run a script, restore my data and be back up and running. Creating a complete new system from scratch takes a lot more. Especially if you need to do Grafana, DB, webserver, ... All the packages I need to install again (i never document that well for the next time) etc.
                    • M mrFarmer
                      @mrfarmer
                      Ah, I see. More of a backup, than anything else, then.
                        @mrfarmer
                        mrFarmer
                        @akbooer a quick restore from a fatal crash of the Pi (SD/SSD) yes.
                          V Offline
                          V Offline
                          vwout
                          @akbooer As @RHCPNG said, you can easily do this, once you have a running setup by copying the contents of /etc/cmh-ludl/ to a local folder, restart the container with that folder mounted to /etc/cmh-ludl/.
                          The difference between using a volume and a folder mount is (amongst other details) how Docker handles this at first startup. When using a volume, Docker copies the contents of e.g. /etc/cmh-ludl/ when it is started with a empty new volume, to that volume. As of that moment all changes are kept in the volume and survive container restarts and updates.
                          A mounted folder also preserves all settings, but in contrary to volumes, Docker does not copy the original contents of the mount target to the folder at first startup. This means you need to store create the files needed in /etc/cmh-ludl/ yourself, which makes it harder to initially get start (except for one who masters openLuup 😉 ).
                            wrote on last edited by PerH
                            #33
                            I thought i'd give this a stab, as i have some dependency issues.. Found an old laptop and installed Debian to test with.
                            I want the following apps to run on the machine:
                            Z-Way
                            Domoticz
                            InfluxDB
                            Grafana
                            Miio Server (stupid implementation of domo plugin for my vacuum)
                            Any reason not to just have one docker each? They all use TCP/UDP for all communication (i use ser2net for usb ports)..
                            I've had to install python on the domoticz image i have, and therefore saved a new image. Where is this image stored?
                            R 1 Reply Last reply
                              @vwout: There is a choice between Debian and Alpine in your image, why? 🙂 is there advatages to one or the other? If its just interface/packages in the container there wouldn't be a difference if you're not doing changes to it right? (which ideally is not nessecary)
                              • PerHP PerH
                                Z-Way
                                Domoticz
                                InfluxDB
                                Grafana
                                RHCPNG
                                @perh I think the main point of dockers is to put every service in it's own docker. This way it is easier to manage with as less dependence as possible.
                                • PerHP PerH
                                  @perh said in Moving to Docker:
                                  The Alpine image is somewhat smaller. It comes with a more limited set of Linux installed utilities, but who cares about that in the openLuup environment?
                                    As long as it works.. 🙂
                                    New question: I've set up two containers (domoticz and miio server), and by default - they are on the same network. This network will however give the containers an IP at startup, and it seems to be first come - first served. Is there a way to give them static IP's in this internal docker network?
                                    I tried docker run --IP=<IP> without success..
                                    The plugin in Domo reaches miio server with that IP, so i need it to be the same after restarts!
                                      OK, now I have a problem.
                                      It was all going so well until I realised that all incoming IP addresses were being mapped to 172.17.0.1by the LuaSocket library.
                                      Reading the Docker docs: https://docs.docker.com/config/containers/container-networking/
                                      "By default, the container is assigned an IP address for every Docker network it connects to. The IP address is assigned from the pool assigned to the network, so the Docker daemon effectively acts as a DHCP server for each container. Each network also has a default subnet mask and gateway."
                                      But I don't understand, yet, how this works if I want a straight-forward mapping of IPs from my LAN into the Docker container.
                                      It may be that the Synology Docker interface is not adequate for this and I have to revert to the command line?
                                      Any advice/clarification much appreciated.
                                        ok, i got the IP stuff figured. A custom network must be made in order to choose IP, then connect the container.
                                        sudo docker network create -d bridge --subnet=192.168.0.0/16 --ip-range=192.168.0.0/24 --gateway=192.168.0.254 <Network name>
                                        sudo docker network connect --ip=<IP> <Network created by you> <container name>
                                        sudo docker network disconnect bridge <container name>
                                        Still struggling with getting openluup to work as i want it.. tried to copy the cmh-ludl folder from my prod. system to the _data folder for my volume, but can't seem to overwrite user_data.json..
                                        Tried to bind to a folder instead, but then it won't start, as the folder is missing the "openLuup_reload_for_docker" file..
                                        what do i do next?
                                        • PerHP PerH
                                          what do i do next?
                                          #40
                                          You can't do this when the system is running, because it gets overwritten with the current system state on restarts. Stop openLuup with a /data_request?id=exit request, change the file, then stop and restart the container (to restart openLuup.)
                                            147.5k
