  3. Docker
  4. Moving to Docker
Moving to Docker
Docker
Openluup docker filling up disk space?
PerHP
Docker
InfluxDB 1.x in docker
PerHP
Docker
Grafana on Docker
Docker
Moving to Docker
62 Posts 11 Posters 49.3k Views 11 Watching
    RHCPNG
    I'm using the docker of vwout for a while now. I've asked for several additions to the docker and vwout has been very helpful. I think a docker container is ideal for me. Problem solving is easier, because the different applications are containerized. It's easy to start an additional dev/test environment and needs fewer resources than a complete VM. Updating is also easier, when the docker is maintained actively of course.
    But of course, everyone has to decide what works best for him/her. Dockers are here to stay, that's for sure. I think you're going to like it, @akbooer .
    Thanks for the docker again, @vwout! Great support. I have had no problems with it.
    • R RHCPNG
      @rhcpng
      Ooh, super – another Docker expert.
      I'm really stuck. I think that there's a vital piece of documentation that I haven't found/read. Whether this is Synology, or Docker, or GitHub/vwout, I'm not sure...
      • I have Docker installed in Synology
      • I have the (alpine) version of openLuup installed and running (apparently)
      • but I can't access it at all or work out where the openLuup files go.
      I think this is something to do with the method of persisting data:
      docker-compose.yml
      and whilst I understand that there are (probably) some commands to be run:
      docker run -d \
             -v openluup-env:/etc/cmh-ludl/ \
             -v openluup-logs:/etc/cmh-ludl/logs/ \
             -v openluup-backups:/etc/cmh-ludl/backup/ \
             -p 3480:3480
             vwout/openluup:alpine
      I don't know where that goes either.
      So I feel stupid, and stuck. (Nice, in fact, to understand how others feel when approaching something new.)
      Any pointers, anyone?
      R K 2 Replies Last reply
        @rhcpng
        docker-compose.yml
        docker run -d \
               -p 3480:3480
        RHCPNG
        @akbooer
        I'm far from an expert, but have some experience with it yes. I haven't composed a container through yaml yet.
        You first need to define/create the volumes, that's when you can state where the volumes should be "placed" and where the data resides. This can be a local directory or a nfs mount for example. Default, it creates a dir in the docker dir.
        If you are not a Linux expert, like me (although I can manage), I would advise installing Portainer first. It gives you a nice GUI for managing your dockers. Far easier than doing everything through command line.
          @rhcpng
          docker-compose.yml
          docker run -d \
                 -p 3480:3480
          K Online
          K Online
          kfxo
          @akbooer said in Moving to Docker:
          You are using the synology docker package to create and deploy your container, correct? At minimum, to get the container accessible, change the port settings to 3480(local):3480(container). Then you should be able access it at http://YourSynologyIP:3480/
          • K kfxo
            @kfxo said in Moving to Docker:
            Yes, that's correct for now. I need also to investigate Portainer, apparently.
            OK, I was looking for where to do that, but I guess, I'll look harder. Thanks.
              ... Oh, THOSE settings!
              Thanks again.
                It's MAGIC !
                I particularly like the look of this...
                This instills a sense of wonder in me... I mean, I know (almost) exactly how openLuup works, but to see it wrapped in a container running on a NAS, seems rather special. "Hats off" ("chapeau?") to those who have engineered this, not least @vwout.
                One is never quite finished, however.
                I understand that to make any changes last across container/NAS restarts, I need to make the volumes external to the container, as per the above yaml. So this is my next step.
                Any further insights welcomed. Perhaps Portainer is that next step?
                  RHCPNG
                  I'm not familiar with the docker GUI of Synology, maybe that's good enough. But Portainer is widely used for managing docker containers. I like it. It is quite easy to create volumes and the sorts.
                    It's MAGIC !
                    K Online
                    K Online
                    kfxo
                    You cannot create named volumes through the synology GUI. You will need to use portainer or you can ssh into your synology and run the manual commands as outlined by vwout/openluup
                    You can also do this manually. Start by creating docker volumes:
                    docker volume create openluup-env
                    docker volume create openluup-logs
                    docker volume create openluup-backups
                    Create an openLuup container, e.g. based on Alpine linux and mount the created (still empty) volumes:
                    docker run -d
                    -p 3480:3480
                      It's MAGIC !
                      K Online
                      K Online
                      kfxo
                      wrote on last edited by kfxo
                      #21
                      @akbooer
                      I have been messing with this today. I do not currently run openluup through docker so this may not even be the best way to do this but it is what I did to get it up and running and with the ability to easily see and manipulate all openluup files within "File Station" on the synology.
                      I created three folders on my synology:
                      /docker/openLuup/cmh-ludl
                      /docker/openLuup/logs
                      /docker/openLuup/backups
                      Then I created three volumes with a bind to the created folders
                      'openluup-env' bound to '/volume1/docker/openLuup/cmh-ludl'
                      'openluup-logs' bound to '/volume1/docker/openLuup/logs'
                      'openluup-backups' bound to '/volume1/docker/openLuup/backup'
                      I used portianer but you can ssh into your synology and use the command line to create these volumes with the binds, see this
                      Then I created the container using portainer making sure to set the correct ports and volume mappings, which can also be done in the command line with
                      docker run -d \
                             -p 3480:3480
                      Hope this helps.
                      Edit: The binds are not necessary, I only did it to make it easy to access the files. Without the bindings, the volumes are somewhat hidden on synology that is not easily accessible for example at '/volume1/@docker/volumes/openluup-env/_data'
                        RHCPNG
                        Good explanation, this is where it comes down to. But in the end, you probably want the bind to make your data persistent and, more important, easy acccessible.
                          I'm still struggling with this. I've manually created some external folders, but can't get the multi-line command to work.
                          @vwout, following my new experience with AlpineWSL on a PC (which I assume to be something very similar to Docker) I created the whole of the cmh-ludl folder as one single external volume. This is really convenient. Is it possible to make the same configuration for a Docker image?
                          R V 2 Replies Last reply
                            mrFarmer
                            Hi @vwout, can your docker image also be used on the arm64 platform (Pi4)? If not, how would I go about building one? I think with an Unbutu docker and then use the same setup as on a plain Pi.
                            I am setting up some new things on a Pi4 and came along this (https://github.com/SensorsIot/IOTstack) to use Dockers on a Pi. Looks like a very quick way to (re)build an environment from a basic starting point. Especially the split between user data and all else looks attractive.
                              Why would you want to do that? It’s not as though installing Lua is difficult. What am I missing?
                              M 1 Reply Last reply
                                RHCPNG
                                #26
                                I don't know what AlpineWSL is, but you can make a volume for your cmh-ludl folder and map it in vwout's docker container.
                                This is what it looks like in portainer, like a mapping. Really convenient, like you said.
                                • R RHCPNG
                                  @rhcpng
                                  Thanks for that. I guess my question is why these have to be done separately, rather than just making cmh-ludl/ (and all its sub folders) external (which, effectively is what I’ve done for WSL.)
                                  I was trying to do it on the command line, since Portainer seemed to be several hundreds of megabytes, which seemed a bit of overkill just for this task (which, I think, is all I need it for.)
                                    RHCPNG
                                    You mean not splitting it up in backup, log and cmh-ludl? That's a choice of vwout. To be able to be flexible with what you store where, probably. You can do it with the command line too, but I'm not familiar with that. I don't think you have to do all mappings. Probably the cmh-ludl is enough, but I'm not sure.
                                      mrFarmer
                                      @akbooer Well, if I have a complete openLuup setup, except my data, in a Docker and I need to rebuild a system from scratch I can just run a script, restore my data and be back up and running. Creating a complete new system from scratch takes a lot more. Especially if you need to do Grafana, DB, webserver, ... All the packages I need to install again (i never document that well for the next time) etc.
                                      • M mrFarmer
                                        @mrfarmer
                                        Ah, I see. More of a backup, than anything else, then.
                                          @mrfarmer
                                          mrFarmer
                                          @akbooer a quick restore from a fatal crash of the Pi (SD/SSD) yes.
                                            164.0k
