  4. Feature request: drag & drop between "triggers" and "constraints"
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 3 Posters 2.0k Views 3 Watching
    I've imported all reactors from openLuup, and find myself moving a lot of entity-actions from triggers to constraints.. It would help a lot to have "drag & drop", or a move function for this?
      Would you also want that functionality for items in the SET and RESET reaction panes?
        Absolutely, and one could even add a copy if holding down CTRL whilc dragging and dropping?
        I know this probably is easier to think of than to make happen though. 😉
          I think you're onto something, insofar as SET and RESET already have a "Move/Copy" feature, which even allow moving items among separate Rules, not solely within the one you're editing. So your Feature Request might just involve adding a "Move/Copy" button to the Triggers and Constraints panes. Could be a game changer for power users like me.
            Big undertaking. It may get done some day, but while there are bigger fish to fry, I can't get this on my radar right now.
              I fully understand the priorities. Would you things like this in the bug-tracker somehow?
                Answer: Yes, @PerH , he would. Mind tossing it in there as a new PR?
                  Done !
                    Perfect. Also remember there is an import button on rules, so you can at least import between constraints and triggers.
                      163.9k
