  4. How to auto start on Rpi reboot ?
26 Posts 6 Posters 8.7k Views 7 Watching
    Getting the firmware onto the Pi is a series of commands rarely used, so that's part of it. The other part is that your choice of interfaces is critical, as some are supported and some are not.
    • MatohlM Offline
      MatohlM Offline
      Matohl
      #22
      I had no problems with the interfaces, I guess I was lucky. I bought an ordinary SATA to USB3 cable and a standard Samsung 250G disc and plugged it in.
      For the commands and if anyone is interested I used the following guide:
      Jul 24, 2021  /  Raspberry Pi
      How to Boot Raspberry Pi 4 / 400 From a USB SSD or Flash Drive
      A firmware update lets you use any USB device to boot a Pi 4 / 400.
      The only problem with the guide was that boot-option in raspi-config had been moved to another menu location since the guide was written
        The guide is OK, but it contains two omissions that I think are pretty important for the average user:
        1. The first is the interface issue. Only certain interfaces work, and some definitely do not. I first purchased the Sabrent 3.0 to SSD model EC-SSHD. Doesn't work. Found in another guide (linked below) what does work. Thankfully, I had on hand a bigger 3.1 dual-drive powered USB 3.1 interface I use for doing backups and other evil deeds around the house, so I got that Frankensteined on until the working Sabrent 3.1 to SSD model EC-SS31 arrived. Notice the subtle but important difference. Sad but true.
        2. In Tom's Guide, in the SD Card Copier, the "New Partition UUIDs" checkbox must be off. They neglect to say this (it's shown off in the screen shot, but it's worth using words). If it's on, the boot will fail because the boot script and fstab will have the old IDs rather than the new. This is easily fixed if you know where and how to do it, but I think most users would find it frustrating if they don't realize what they've done.
        Link with supported interfaces below. Don't use these older instructions, just use the list of supported devices it offers:
        Jun 29, 2019
        Raspberry Pi 4 USB Boot Config Guide for SSD / Flash Drives
        The Raspberry Pi 4 is finally here and has a lot of exciting changes. One very major downside is that it doesn’t support true USB booting yet out of the box (like the 3 series did).
          Right now, all data is written when modified, but that may not always be the case, and there's a high likelihood it will be user-configurable, even.
          One of the things designed in is that MSR is "crappy-storage-ready". @rafale77 can tell you at length about the merits and woes of various storage technologies, and an SD card in a Raspberry Pi is no exception (in fact, probably both a good example and a dire warning). MSR has a storage architecture for its data that allows "pluggable" storage disciplines, so you could, for example, choose a cached-with-delayed-write-back mechanism to reduce wear, and you could choose that for everything, or just states, or states and logs, etc. So in that case, as the system shuts down, it is necessary for the cache to write back any "dirty" (modified but unsaved as yet) data, or the modifications would be lost.
          That said, you should be thinking about getting your Pi off an SD card if that's what you're running, if you intend to run it full-time with MSR and depend on it. There are only two types of SD cards: those that have failed, and those that are about to. I have my Pi running on a cheap 2.5" SSD, and it's also a good bit faster, although there is some alchemy to getting that working, and while it's much better than it was, it involves some pretty magical incantations still today and can be a bit angst-inducing.
          Black CatB Offline
          Black CatB Offline
          Black Cat
          #24
          @toggledbits said in How to auto start on Rpi reboot ?:
          ha......truer words have never been spoken.
          I just spent the last weekend trying to get a Pi4 booting from a SSD, followed every "how to" I could find and just can't get the bootloader to set to 0xf41, it remains stuck on 0xf14.
          I might have to wait for a Pi5 to achieve my dream or borrow your magical incantations.....
          edit: now after reading the How to patrick refers to, it confuses me even more. It appears every time there is a FW update the goal posts change and Boot Order becomes something else. 0x1 , 0x4, OMG Maybe a Windows install is easier?
          aka Zedrally
            #25
            OK. Build 21074 has some necessary changes to support running as a system daemon under systemd on RPi4. As seen earlier in this thread, a service file is needed that needs to be placed in (typically) /etc/systemd/system. The easiest way to get the correct service file for your current install is to run the tools/rpi-install.sh install script. On an installed system, it will not do much of anything, but it will create a file called reactor.service in the tools subdirectory. From there:
            1. Make sure any other Reactor processes are stopped (e.g. pkill -QUIT node)
            2. Use sudo cp tools/reactor.service /etc/systemd/system/ to copy the file to /etc;
            3. Run sudo systemctl daemon-reload
            4. If you want Reactor to start automatically at boot: sudo systemctl enable reactor
            5. Start Reactor now: sudo systemctl start reactor
            You should now be able to see your log file recording the startup. You may also observe the log messages rolling in /var/log/syslog. The running Reactor instance will also leave a reactor.pid file in the reactor install directory (it will remove it when it shuts down, so its absence is a good indication that it is not running under systemd).
              #26
              rpi-install.sh
              This is the reactor.service file it created:
              # This file allows you to run your Reactor installation under systemd,
              # so it can be started at boot. Copy this file (as root or under sudo)
              # to /etc/systemd/system, and then run "systemctl daemon-reload". You
              # can then able Reactor to start at boot "systemctl enable reactor".
              # The usual systemctl subcommands can also be used to start, stop, and
              # restart reactor at will (e.g. "systemctl restart reactor").
              [Unit]
              Description=Multi System Reactor
              After=network.target
              [Service]
              Type=simple
              User=pi
              WorkingDirectory=/home/pi/Documents/reactor
              ExecStart=/usr/bin/node app -p
              Restart=on-failure
              RestartSec=5s
              [Install]
              WantedBy=multi-user.target
              I followed the rest of the instructions and I could see a reactor.pid file had been created and reactor was running again.
              I then rebooted my Pi and after it rebooted MSR is running again.
              So everything appears to have worked OK.
                148.6k
