reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hubitat and MSR
Is the way Hubitat reports Zwave data the reason for no data in the Primary Value field on the Entities screen? Is this a permanent problem for Hubitat or is there a work around planned for this in the future?
It's the way Hubitat reports data for all devices, ZWave or not. Capabilities on Hubitat are free-form, and there's no indication which capability might be the most useful or primary, nor is there a device type that might formulate an assumption about it. At some point, I'll probably have to come up with a weighted decision tree for making a guess, but that's going to be wrong for some devices, and at that point, per-device overrides in user configuration will be the answer.
I Understand, Thanks
