reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
MSR - long-leap updating
Haven't been keeping track with the releases for a while, still on 096.
Is there any risk in using savedata from this old version on the newest, or can i just go ahead and update to the new docker?
Just thinking if there's any changes in savedata format or handling?
As with Reactor for Vera, if file formats evolve, I like to implement automatic upgrades, and I tend to leave those in for a long time because people sometimes restore backups from previous versions, etc. I can't think of any reason you should not be able to upgrade from pretty much any prior version of MSR to the latest.
