  4. Lock code as trigger
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 3 Posters 2.1k Views 3 Watching
    I'd like to trigger off of the entry of someone's lock code into my Schlage CONNECT lock. I've stared at my options in the Entities and the closest I can come is the stored x_hubitat_extra_attributes.lastCodeName="Nik".
    It just doesn't feel quite 100% like what I'm looking for - but nothing else comes even close.
      Unless someone has specific experience with the device and can answer, you are blazing the trail here. That may be all you get.
      It may be useful to take a closer look, though. Can you please restart MSR, and then grab and post your logs/hubitat_devices.json file.
        @toggledbits As requested, obvious info redacted.
                "id": "25",
                "name": "Schlage BE468/BE469 Lock",
                "label": "Front Door",
                "type": "Schlage BE468/BE469 Lock",
                "attributes": [
                        "name": "lock",
                        "currentValue": "unlocked",
                        "dataType": "ENUM",
                        "values": [
                            "locked",
                            "unlocked with timeout",
                            "unlocked",
                            "unknown"
                        "name": "lockCodes",
                        "currentValue": "{\"3\":{\"name\":\"Jen\",\"code\":\"xxxx\"},\"4\":{\"name\":\"John\",\"code\":\"xxxx\"},\"5\":{\"name\":\"Nik\",\"code\":\"xxxx\"}}",
                        "dataType": "JSON_OBJECT"
                        "name": "codeLength",
                        "currentValue": null,
                        "dataType": "NUMBER"
                        "name": "lastCodeName",
                        "currentValue": "Nik",
                        "dataType": "STRING"
                        "name": "maxCodes",
                        "currentValue": 30,
                        "name": "codeChanged",
                        "currentValue": "deleted",
                        "dataType": "ENUM",
                        "values": [
                            "added",
                            "changed",
                            "deleted",
                            "failed"
                        "name": "battery",
                        "currentValue": 99,
                "capabilities": [
                    "Configuration",
                    "LockCodes",
                        "attributes": [
                                "dataType": null
                                "dataType": null
                                "name": "maxCodes",
                                "dataType": null
                                "dataType": null
                    "Actuator",
                    "Refresh",
                    "Battery",
                        "attributes": [
                                "name": "battery",
                                "dataType": null
                    "Lock",
                        "attributes": [
                                "name": "lock",
                                "dataType": null
                    "Sensor"
                "commands": [
                    "configure",
                    "deleteCode",
                    "getCodes",
                    "lock",
                    "refresh",
                    "setCode",
                    "setCodeLength",
                    "unlock"
                  "id": "25",
                  "attributes": [
                          "name": "lock",
                          "dataType": "ENUM",
                          "values": [
                              "locked",
                              "unlocked",
                              "unknown"
                          "name": "maxCodes",
                          "currentValue": 30,
                          "dataType": "ENUM",
                          "values": [
                              "added",
                              "changed",
                              "deleted",
                              "failed"
                          "name": "battery",
                          "currentValue": 99,
                  "capabilities": [
                      "Configuration",
                      "LockCodes",
                          "attributes": [
                                  "dataType": null
                                  "dataType": null
                                  "name": "maxCodes",
                                  "dataType": null
                                  "dataType": null
                      "Actuator",
                      "Refresh",
                      "Battery",
                          "attributes": [
                                  "name": "battery",
                                  "dataType": null
                      "Lock",
                          "attributes": [
                                  "name": "lock",
                                  "dataType": null
                      "Sensor"
                  "commands": [
                      "configure",
                      "deleteCode",
                      "getCodes",
                      "lock",
                      "refresh",
                      "setCode",
                      "setCodeLength",
                      "unlock"
          @gwp1 Interestingly... Hubitat Rules Machine allows for lock code triggering so there's SOMETHING in there that allows it.
          Whilst I can create a rule to do what I was looking for in Rules Machine, I really prefer to let MSR drive everything. One SSOT, (T=Truth and Troubleshooting.)
            There's no reason not to use the extra attribute. It's fine. They're added for just that reason -- so you can get to any data that's device-specific. Since there's no consistent capability for that data across devices on Hubitat, I'm just going to leave it the way it is.
              apocalypsehobby
              @gwp1 I have done this within Vera/Reactor. I'm not sure how much will translate, but you're on a similar track to what I did.
              The logic basically says "if user code has updated within the past 15 seconds AND the code is X" then perform action.
              • A apocalypsehobby
                @apocalypsehobby Interesting approach. I'm gonna look into this further.
                  164.0k
