  4. MSR Logic vs Reactor question
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 3 Posters 2.1k Views 3 Watching
    RogerO
    Hello,
    Trying to convert my Reactor scripts to MSR. Couldn't get the import to work so gave up on that. Anyway, curious on how to work with the following example.
    Have a motion sensor on my back porch. Very simple logic:
    7fbcd69e-9f85-4b7f-8138-1267d4e4ba1a-image.png The Reactor activities are as follows:
    34e715fd-c2f1-4b92-99ea-e2838fc5d3dc-image.png.
    In MSR, how do you tie activities to sub conditions like I have with the last action in activities.
    In this case I was to trigger BlueIris to trigger regardless of the time of day, but only want the light to come on at night. Do I need multiple Rule Sets?
    Thanks,
    Roger
      I believe the answer you seek lies within the new-ish "Group" feature in Reactions. (There is no section covering this yet in Docs, at least when I looked under "Creating Automations" > "Reactions").
      I'm sorry not to have the time to type out a complete example for you, but I know the Forum contains several use cases involving "Group Constraints".
        RogerO
        I did not find anything in the forum under those keywords. Do you have a link or 2?
          I had looked for links earlier and found none that were illustrative of setting up Group Constraints, but generally speaking, I can suggest:
          In your Rule, within your Set Reaction, add a "Group Constraint" (which will look and behave like it's own "section"). Add one or more Conditions, such as your "Is Night" timeframe, and then add the thing(s) you want that group to do when true.
          Do all this again, adding a Group Constraint to the Set Reaction which contains your "Porch Sensor Tripped" logic, along with actions you want it to take when that logic is true.
          In this way, you wind up with a Rule that runs under the appropriate AND logic it always did, but internally forks to run one (or both) subsets of functions depending on their truth.
          Of course, since my basic example happens to repeat your SET conditions within the Group Constraints sections, they will kinda automatically be TRUE every time the Rule fires, so both constraints' actions will always fire. Up to you to decide which logic you really want internally.
          • toggledbitsT Online
            toggledbitsT Online
            Using Group Constraints is one way. The other way is to make Porch Sensor Tripped its own rule with its own reaction (the HTTP Request), and then create an additional rule Back Porch Motion that uses a "Rule State" condition to test Porch Sensor Tripped and the entity condition to check the back porch switch.
              The way that Patrick is suggesting I believe is the more versatile and manageable approach.
                RogerO
                Went with Patrick's suggested approach. I do like the old reactor a bit better for this instance. Less clutter. Sure there was a technical reason to do it this way. Guess I can create multiple rule sets to group them by.
                  163.4k
