  4. Latest version (21267-a507fec) stopped working
11 Posts 5 Posters 2.0k Views 5 Watching
  • F Offline
    Hi Patrick @toggledbits !
    I have MSR running on my Odroid n+ (Home Assistant Blue), and always pulls the newest version of MSR in Portainer. I pull the docker: toggledbits/reactor:latest-raspbian-armv7l.
    In Portainer MSR has always had the state "Healty". But with the latest version (21267-a507fec) the state has changed to "Running". But... it's not running. When I open the web UI, I only get a error message (in swedish - since I'm living in Sweden):
    Don't know whats wrong - so I copy-pasted the log from Portainer:
    2021-09-25T09:55:00.449Z <app:INFO> Process ID 1; platform linux/arm #1 SMP PREEMPT Thu Sep 9 01:50:48 UTC 2021; locale (undefined)
    2021-09-25T09:55:00.449Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
    2021-09-25T09:55:00.450Z <app:INFO> NODE_PATH /opt/reactor
    2021-09-25T09:55:00.450Z <app:INFO> Configured locale [ "en-US", "UTF-8" ]
    2021-09-25T09:55:00.455Z <default:NOTICE> Unable to load locale data for en-US, trying en
    2021-09-25T09:55:00.456Z <default:WARN> Failed to load locale data for [undefined1]; reverting to system default en-US
    /opt/reactor/server/lib/i18n.js:186
        !_0x31a08d && (logger[_0x34da3b(0x9c)](_0x34da3b(0xbb)), _0x31a08d = util['loadData'](['common'], _0x34da3b(0x86), _0x3b261a)), localeData = _0x31a08d, localeData[_0x34da3b(0xed)] = localeData[_0x34da3b(0xed)] || {}, logger['debug'](0x5, _0x34da3b(0xe1), _0x31a08d[_0x34da3b(0xa4)], _0x47b224, _0x31a08d[_0x34da3b(0xc7)], _0x31a08d['format']);
    TypeError: Cannot read property 'strings' of undefined
        at Object.exports.<computed> [as loadLocale] (/opt/reactor/server/lib/i18n.js:186:197)
        at Object.<anonymous> (/opt/reactor/app.js:244:25)
        at Module._compile (internal/modules/cjs/loader.js:1068:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
        at Module.load (internal/modules/cjs/loader.js:933:32)
        at Function.Module._load (internal/modules/cjs/loader.js:774:14)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
        at internal/main/run_main_module.js:17:47
    basedir /opt/reactor
    confdir /var/reactor/config
    datadir /var/reactor/storage
    logsdir /var/reactor/logs
    plugindir /var/reactor/ext
    module.paths [ '/opt/reactor/node_modules', '/opt/node_modules', '/node_modules' ]
    2021-09-25T09:55:52.395Z <app:null> Reactor latest-21267-a507fec starting on v14.17.0
    2021-09-25T09:55:52.396Z <app:INFO> Process ID 1; platform linux/arm #1 SMP PREEMPT Thu Sep 9 01:50:48 UTC 2021; locale (undefined)
    2021-09-25T09:55:52.397Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
    2021-09-25T09:55:52.397Z <app:INFO> NODE_PATH /opt/reactor
    2021-09-25T09:55:52.398Z <app:INFO> Configured locale [ "en-US", "UTF-8" ]
    2021-09-25T09:55:52.402Z <default:NOTICE> Unable to load locale data for en-US, trying en
    2021-09-25T09:55:52.403Z <default:WARN> Failed to load locale data for [undefined1]; reverting to system default en-US
    I have downgraded with good results. I have both upgraded and downgraded multiple times and older versions is working - but latest doesn't. Can it be related to the new functions?
    Best regards,
    /Fanan
      I have the same problem on a bare metal Debian installation, after updating to this latest version of MSR, I am no longer able to access the MSR web GUI.
      I also reverted back to version 21258-6fb388e and MSR is running and accessible again.
        Sorry, guys. I respun the release and it's now available, 21267-f3f821b
        F CrilleC wmarcolinW 5 Replies Last reply
          @toggledbits Thanks for your swift correction! It's now working! 🙂
            @toggledbits After updating from 21243 to latest 21267, all my ezlo devices are missing the defined capabilities/entities like power_switch,dimming, motion_sensor and so on.
                @toggledbits I just checked it now and it already works, we can close the ticket.
                  • F Offline
                    I've also lost some of the available actions on my Ezlo Plus. My siren is no longer possible to turn on and off.
                      @toggledbits Great work! latest-21270-48528ec fixed all my issues.
                        Updated to 21270-48528ec MSR now loads again in the web browser (Chrome).
                        However the menu headings don't look right:
                        EDIT:
                        Restarted MSR again and now they look normal:
