  4. Hubitat primary attribute
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 1.4k Views 2 Watching
    I am trying to display the primary attribute on this device like all my other Hubitat devices. The attribute is x_hubitat_extra_attributes.Status. This gives an error in the log. I can't see what I am doing wrong with this one. Do I need to to something different to display this?
    Log:
    [latest-21286]2021-10-16T14:42:23.141Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
    [latest-21286]2021-10-16T14:42:23.166Z <HassController:NOTICE> HassController#hass attempting reconnection to ws://192.168.1.21:8123/api/websocket
    [latest-21286]2021-10-16T14:42:23.168Z <HassController:NOTICE> HassController#hass connecting via WS to ws://192.168.1.21:8123/api/websocket
    [latest-21286]2021-10-16T14:42:23.246Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-21286]2021-10-16T14:42:23.269Z <app:INFO> Structure running; pausing for controllers' initial ready
    [latest-21286]2021-10-16T14:42:23.273Z <HubitatController:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
    [latest-21286]2021-10-16T14:42:23.290Z <HassController:NOTICE> HassController#hass connected, starting protocol
    [latest-21286]2021-10-16T14:42:23.296Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.1.21:8123; fetching initial data...
    [latest-21286]2021-10-16T14:42:23.300Z <HassController:INFO> HassController#hass Hass reports version "2021.10.5" location Home timezone America/Chicago state RUNNING safe_mode false
    [latest-21286]2021-10-16T14:42:23.303Z <HassController:ERR> HassController#hass reported Hass version "2021.10.5" is not supported!
    [latest-21286]2021-10-16T14:42:23.379Z <HassController:NOTICE> Controller HassController#hass is now online.
    [latest-21286]2021-10-16T14:42:23.563Z <default:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to x_hubitat_extra_attributes.Status invalid, not in { "x_hubitat": { "id": "568", "name": "BlinkAPI", "commands": [ "ArmSystem", "Authorize", "CheckSyncModule", "DisableMotionDetection", "DisarmSystem", "EnableMotionDetection", "GetCameraInfo", "GetCameraLiveView", "GetCameraSensors", "GetCameraStatus", "GetCameraUsage", "GetHomescreen", "GetNetworkStatus", "GetNetworks", "GetNewThumbnail", "GetNotifications", "GetVideoEvents", "ListSchedules", "VerifyPIN", "refresh" ], "capabilities": [ "Actuator", "Refresh", "Sensor" ] }, "x_hubitat_Actuator": {  }, "x_hubitat_Refresh": {  }, "x_hubitat_Sensor": {  }, "x_hubitat_extra_commands": {  } }
    [latest-21286]2021-10-16T14:42:23.566Z <HubitatController:ERR> HubitatController#hubitat failed to connect/query http://192.168.1.70/apps/api/416: Error: Entity#hubitat>568:setPrimaryAttribute() can't set x_hubitat_extra_attributes.Status, not defined for entity
    [latest-21286]2021-10-16T14:42:23.567Z <HubitatController:CRIT> Error: Entity#hubitat>568:setPrimaryAttribute() can't set x_hubitat_extra_attributes.Status, not defined for entity
        at Entity.setPrimaryAttribute (/opt/reactor/server/lib/Entity.js:403:19)
        at /opt/reactor/server/lib/HubitatController.js:865:183
        at /opt/reactor/server/lib/HubitatController.js:805:76
        at processTicksAndRejections (internal/process/task_queues.js:95:5)
    [latest-21286]2021-10-16T14:42:23.713Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
    [latest-21286]2021-10-16T14:42:23.714Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    [latest-21286]2021-10-16T14:42:48.577Z <HubitatController:NOTICE> HubitatController#hubitat not ready; performing initial connect/query
    [latest-21286]2021-10-16T14:42:48.779Z <HubitatController:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.1.70/eventsocket
    [latest-21286]2021-10-16T14:42:48.781Z <HubitatController:NOTICE> Controller HubitatController#hubitat is now online.
    [latest-21286]2021-10-16T14:42:48.786Z <app:NOTICE> Starting HTTP server and API...
    [latest-21286]2021-10-16T14:42:48.791Z <app:NOTICE> Starting Reaction Engine...
    [latest-21286]2021-10-16T14:42:48.792Z <Engine:INFO> Reaction Engine starting
    [latest-21286]2021-10-16T14:42:48.792Z <Engine:INFO> Checking rule sets...
    [latest-21286]2021-10-16T14:42:48.798Z <Engine:INFO> Checking rules...
    local_hubitat_devices.yaml:
      OK. That's a sequencing issue in HubitatController. I can fix that and release a build later today.
      Also, I opened PR 261 to memorialize it.
      S 1 Reply Last reply
        @toggledbits Confirming Build 21292 fixed the issue. Thank You
          165.6k
