  4. MQTTController map different values from same topic?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Scheduled Pinned Locked Moved Unsolved Multi-System Reactor
5 Posts 3 Posters 1.5k Views 3 Watching
    I have multiple sensors connected to via Bluetooth to a Tasmota device.
    All sensors report their values in the SENSOR topic, how do I map those to individual entities?
      This would be done the same way as mapping any other topic to an entity. I'm... not sure what the question is.
      • CrilleC Crille
        ArcherS
        @Crille I do not use the MSR (yet! 🙂 ), but I do have a Tasmota device reporting three Xiaomi Mi BLE devices to OpenLuup over Mqtt.
        They report the following:
        {"Time":"2021-11-24T16:00:25","ATC-6d5d44":{"Temperature":20.6,"Humidity":48.0,"DewPoint":9.2,"Battery":76,"RSSI":-89},"ATC-9446bf":{"Temperature":19.6,"Humidity":52.0,"DewPoint":9.5,"Battery":42,"RSSI":-84},"ATC-f159bf":{"Temperature":19.6,"Humidity":55.0,"DewPoint":10.3,"Battery":45,"RSSI":-84},"TempUnit":"C"}
        on the following topic:
        tele/TasmotaBLE/SENSOR
        The message contains all three devices each under their name.
        Not sure how about the syntax in MSR but in e.g. Home Assistant you write something in this direction in the config.yaml to retrieve the temperature for one device.
          - platform: mqtt
            state_topic: "tele/TasmotaCO2Ax/SENSOR"
            value_template: "{{value_json['ATC-6d5d44'].Temperature}}"
            device_class: temperature
            unit_of_measurement: "°C"
          There are templates documented for Tasmota devices reporting temperature, humidity, and battery. Any of them can be used as a model for dewpoint if that's needed. You set source in the entity configuration to pick which sensor (e.g. source: ATC-6d5d44 or source: ATC-9446bf), like this:
                  temp_sensor_1:
                     name: "Tasmota XXXX sensor 1"
                     topic: "tasmota_FFFFFF"
                     uses_template: tasmota_temperature_humidity
                     source: ATC-9d5d44
                  temp_sensor_2:
                     name: "Tasmota XXXX sensor 2"
                     source: ATC-9446bf
          etc...
            The issue is that the sensors do not report at the same time, one publish contains one or two devices and when source id is not found it's setting null values.
            Lets say I use source LYWSD03aa6def
            17:19:25.359 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:25","LYWSD03aa6def":{"mac":"a4c138aa6def","Temperature":7.0,"Humidity":98.0,"DewPoint":6.7,"Battery":24,"RSSI":-71},"Flora6cabfa":{"mac":"c47c8d6cabfa","Temperature":7.8,"Illuminance":265,"Moisture":20,"Fertility":85,"RSSI":-86}}
            17:19:26.372 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:26","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":8.6,"Illuminance":167,"Moisture":0,"Fertility":0,"RSSI":-81}}
            17:19:37.399 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:37","Switch1":"ON","Switch2":"ON","ENERGY":{"TotalStartTime":"2021-05-04T07:45:50","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":[ 0, 0],"Power":[ 0, 0],"ApparentPower":[ 0, 0],"ReactivePower":[ 0, 0],"Factor":[0.00,0.00],"Frequency": 0,"Voltage": 0,"Current":[0.000,0.000]},"ESP32":{"Temperature":40.0},"TempUnit":"C"}
            It maps the temperature and humidity on the first tele but applies null on the next ones.
            Also, what to put in init?
              164.0k
