  4. [Solved] Column width for Entities in MSR UI
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 2 Posters 1.5k Views 2 Watching
  • CrilleC Online
    CrilleC Online
    I could not find a post or PR for this so apologies if it has been answered.
    There seems to be a fixed width for the columns in the Entities page making it impossible to see the full Canonical ID of long ID's and a lot of white space in the Entity Name column.
    I tried to adjust the width in Chrome and Edge without success, is it a feature or or am I doing it wrong?
    latest-22004-6d6c6b7 bare metal.
    • CrilleC Online
      CrilleC Online
      The width is in percent? so it does not matter if I switch to a bigger monitor. I can not drag the column divider or select the value and drag to "scroll" the column either. Only solution to get the full ID is to expand the Entity.
      Is it possible to adjust the width by user or by design? to easier locate a device for example referred to as member in a Dynamic Group.
      • CrilleC Online
        CrilleC Online
        The automatic width seems to be fixed in 22021? I see less white space in Entity Name and full ID in Canonical ID now!
          Yes, I did adjust the columns a little bit. Also note that if you hover over the canonical ID, it shows the full ID in a tooltip, and if you click on the canonical ID, it selects the entire ID ready for a copy to clipboard.
          • CrilleC Online
            CrilleC Online
            Sweet, thank you!
              Ultimately I'd like to make these all adjustable, but that's going to take a good bit more work. I tried, and it wasn't a quick and easy job, and I was mostly focused on the grid for the Status on the UI side of this release. More to follow...
                162.3k
                1.3k
