  4. TypeError: Can't subscribe to object that is not Observable - Synology Docker
1 Posts 1 Posters 393 Views 1 Watching
    I noticed this error multiple times in the logs: TypeError: Can't subscribe to object that is not Observable ([object Object]) Looking through the older logs this has been there awhile. Any hints on what to look for to track down the cause?
    Synology Docker
    v22025
    [latest-22025]2022-01-28T02:23:53.685Z <Rule:INFO> Watch TV (Rule#rule-knm8t6w2) starting evaluation; because startup
    [latest-22025]2022-01-28T02:23:53.685Z <Rule:INFO> Wardrobe Light (Rule#rule-kmmos2n7) starting evaluation; because startup
    [latest-22025]2022-01-28T02:23:53.691Z <Rule:INFO> Bedroom Scentsy (Rule#rule-kxm5tblk) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.693Z <Rule:INFO> Basement Minimote (Rule#rule-krbebzmw) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.694Z <Rule:INFO> Driveway Lights 40 (Rule#rule-kp4tw7tq) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.696Z <Rule:INFO> Driveway Lights 100 (Rule#rule-kp4tmgu6) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.698Z <Rule:INFO> Garage Door Presence (Rule#rule-kqztn5y9) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.699Z <Rule:INFO> Steve’s Garage Door (Rule#rule-knaz3on5) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.700Z <Rule:INFO> Vicki’s Garage Door (Rule#rule-kpemuy7m) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.702Z <Rule:INFO> Sun Elevation (Rule#rule-kx9xfe1f) evaluated; rule state transition from RESET to SET!
    [latest-22025]2022-01-28T02:23:53.718Z <Rule:INFO> OATemp Set (Rule#rule-ku660ffy) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.719Z <Rule:INFO> Hubitat Weekly Reboot (Rule#rule-ktuxil18) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.720Z <Rule:INFO> SunTimes (Rule#rule-kstnjezi) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.725Z <Rule:INFO> UPS Power Restored (Rule#rule-krvblyyr) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.731Z <Rule:INFO> UPS Power Outage (Rule#rule-krvblruz) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.735Z <Rule:INFO> Ring Power Restored (Rule#rule-kq4hhtmg) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.739Z <Rule:INFO> Ring Power Outage (Rule#rule-kpery3cq) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.740Z <Rule:INFO> UPS Hubitat Shutdown (Rule#rule-kpyt9iei) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.741Z <Rule:INFO> Sticks (Rule#rule-kpbmbi2d) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.743Z <Rule:INFO> Low Light (Rule#rule-kulslls9) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.744Z <Rule:INFO> Living Room Scentsy (Rule#rule-kuanpjpf) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.746Z <Rule:INFO> Corner Lamp (Rule#rule-kt9d7daq) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.747Z <Rule:INFO> LED Strip (Rule#rule-kpd1bax4) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.748Z <Rule:INFO> Stairs Light Morning (Rule#rule-km7cdbq3) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.749Z <Rule:INFO> Stairs Light Evening (Rule#rule-km7asbhr) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.751Z <Rule:INFO> Stairs Light Late Night (Rule#rule-km7by6pt) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.752Z <Rule:INFO> Battery Level Notification (Rule#rule-kwsrtrm4) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.752Z <Rule:INFO> Roomba Bin Full Notify (Rule#rule-kot9hprp) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.753Z <Rule:INFO> Hass Update Notify (Rule#rule-kmcuosts) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.754Z <Rule:INFO> Hubitat DB Size Notifiy (Rule#rule-kwcw80sf) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.754Z <Rule:INFO> Office Minimote (Rule#rule-kq5udrzr) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.756Z <Rule:CRIT> TypeError: Can't subscribe to object that is not Observable ([object Object])
        at Rule.subscribe (/opt/reactor/server/lib/Observer.js:77:19)
        at Rule.subscribeAsDependency (/opt/reactor/server/lib/Rule.js:602:249)
        at RulePredicateContext.subscribeAsDependency (/opt/reactor/server/lib/RulePredicateContext.js:56:67)
        at Predicate._evaluateCondition (/opt/reactor/server/lib/Predicate.js:670:155)
        at Predicate._evaluateGroup (/opt/reactor/server/lib/Predicate.js:1021:103)
        at Predicate._evaluateCondition (/opt/reactor/server/lib/Predicate.js:628:47)
        at Predicate.evaluate (/opt/reactor/server/lib/Predicate.js:334:38)
        at Rule._evaluate (/opt/reactor/server/lib/Rule.js:826:56)
        at async /opt/reactor/server/lib/Rule.js:782:17
    [latest-22025]2022-01-28T02:23:53.757Z <Rule:CRIT> TypeError: Can't subscribe to object that is not Observable ([object Object])
    [latest-22025]2022-01-28T02:23:53.758Z <Rule:INFO> Patio Light On (Rule#rule-kpsdnu42) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.759Z <Rule:INFO> String Light Timed Off (Rule#rule-krybhbjp) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.759Z <Rule:INFO> Pantry Light (Rule#rule-kpw0p0rl) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.760Z <Rule:INFO> Landscape Lights (Rule#rule-kpc0wep6) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.761Z <Rule:CRIT> TypeError: Can't subscribe to object that is not Observable ([object Object])
    [latest-22025]2022-01-28T02:23:53.762Z <Rule:CRIT> TypeError: Can't subscribe to object that is not Observable ([object Object])
    [latest-22025]2022-01-28T02:23:53.762Z <Rule:INFO> Porch Light On (Rule#rule-kmtyzj5f) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.763Z <Rule:CRIT> TypeError: Can't subscribe to object that is not Observable ([object Object])
    [latest-22025]2022-01-28T02:23:53.764Z <Rule:INFO> Dog Lights On (Rule#rule-kyxq7no4) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.764Z <Rule:INFO> Good Night with Checks (Rule#rule-kxbbbjbr) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.765Z <Rule:INFO> Bedtime (Rule#rule-knmbhl4t) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.766Z <Rule:INFO> Blink Motion Disable (Rule#rule-kut0f7me) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.766Z <Rule:INFO> Motion Overide Auto Off (Rule#rule-kpd3stki) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.766Z <Rule:INFO> Sleep Time (Rule#rule-knqotlgu) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.769Z <Rule:INFO> String Lights Auto Off (Rule#rule-kwmscbwj) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.769Z <Rule:INFO> Trouble (Rule#rule-kso26jyb) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.770Z <Rule:INFO> Watch TV (Rule#rule-knm8t6w2) evaluated; trigger state unchanged (false); rule state remains RESET
    [latest-22025]2022-01-28T02:23:53.770Z <Rule:INFO> Wardrobe Light (Rule#rule-kmmos2n7) evaluated; trigger state unchanged (true); rule state remains SET
    [latest-22025]2022-01-28T02:23:53.773Z <Engine:INFO> Enqueueing "Sun Elevation<SET>" (rule-kx9xfe1f:S)
    [latest-22025]2022-01-28T02:23:53.777Z <httpapi:NOTICE> HTTP API v1 22021 base URL http://192.168.1.21:8111; listening
    [latest-22025]2022-01-28T02:23:53.789Z <app:NOTICE> HTTP server running; registering proxy endpoints.
    [latest-22025]2022-01-28T02:23:53.790Z <app:NOTICE> Starting WSAPI...
    [latest-22025]2022-01-28T02:23:53.791Z <wsapi:NOTICE> wsapi: starting version 21334
