  4. Docker container update - documentation
4 Posts 2 Posters 965 Views 2 Watching
    Proposing the following instruction text when upgrading MSR Docker container on Synology:
    Upgrading the Container
    To update to the latest version of MSR and the toggledbits/reactor container using the Synology docker client, go to the Docker app in Synology.
    1. On the Container tab stop the existing MSR container (Select the container, then Action > Stop).
    2. Edit the existing container and change its name to MSR-old.
    3. Go to the Image tab. Note the tag of the Docker image you have been using.
    4. Go to the Registry tab and find toggledbits/reactor. Choose the same tag that you saw in the step above.
    5. Download the new image
    6. When the image download is complete, go to the Container tab and select MSR-old then click Settings - Duplicate settings.
    7. Rename the container MSR.
    8. When “Use the same network as Docker host” is NOT selected in Network settings:
    • in the Port settings of the OLD container, change local & container ports “8111” to “8112” (also disable “auto-restart” just in case)
    • in the Port settings of the NEW container, change local port “Auto” to “8111”
    1. Start the (new) MSR container.
    2. Delete the MSR-old container once you have confirmed everything is working.
    S 1 Reply Last reply
      @tunnus
      The existing documentation for upgrading a Synology Docker container works well and is lot less steps. Have you tried this method?
      From the docs:
      When new versions of the image are released, you can upgrade your container as follows:
      1. Open Docker by clicking the "Open" button under the Docker item in the Package Center of your NAS.
      2. In the Docker app, go to the Registry, and search for "toggledbits". The listing for toggledbits/reactor should come up. Click that row, and then click the "Download" button.
      3. Go to the "Containers" list.
      4. Click on your Reactor container.
      5. Choose "Reset" from the "Action" dropdown (this is "Clear" on Docker packages earlier than 20.10.3-0554)
      6. Start the container.
      • S SweetGenius
        @tunnus
        From the docs:
        @sweetgenius I'm aware of that instruction. And yes, it does work, but if there would be issues with the upgrade, using this more lengthy process enables smooth rollback
          @toggledbits, any thoughts?
            155.5k
