  4. Reactor as tab in Hass sidebar
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
  • W wokwon
    So, following:
    cd \path\to\reactor
    node tools\install_reactor_windows_service.js -u .
    del /s /f node_modules
    npm rm -g node-windows
    npm uninstall node-windows
    npm uninstall -g node-windows
    npm install -g node-windows@1.0.0-beta.6
    npm link node-windows
    ...extract the Reactor.zip over the old directory...
    node tools\install_reactor_windows_service.js -i .
    I'm now running fine with Reactor (Multi-hub) stable-22136.
    Thank you @toggledbits for your support and amazing product.
    Bonus is the SSL now works too (CertifytheWeb with LetsEncrypt will renew it and drop the key files in the correct location). That means I can have Reactor as a tab in the Hass sidebar (previously https Hass --> http reactor would not work).
    Ractor.yaml:
    99a5f802-c3e4-4bfa-9a29-975de1da4d28-image.png CertifyTheWeb:
    621270ab-242f-47c4-a7ee-d547ce9eb4cf-image.png Browser:
    MatohlM Offline
    MatohlM Offline
    Matohl
    panel_iframe in configuration.yaml. If you access MSR with HTTP it works in HA with HTTP to Reactor and HTTPS to HTTPS obviously.
    configuration.yaml
    # ============ SIDEBAR ============
    panel_iframe:
      reactor:
        title: "Reactor"
        url: "http://192.168.0.23:8111/reactor/sv-SE/"
    MatohlM G 2 Replies Last reply
    • MatohlM Matohl
      configuration.yaml
      panel_iframe:
        reactor:
          title: "Reactor"
      MatohlM Offline
      MatohlM Offline
      Matohl
      • MatohlM Matohl
        configuration.yaml
        panel_iframe:
          reactor:
            title: "Reactor"
        @matohl Thank you for this.
          Quick question: how to add an icon next to it?
          MatohlM 1 Reply Last reply
            MatohlM Offline
            MatohlM Offline
            Matohl
            @gwp1
            panel_iframe:
              reactor:
                title: "Reactor"
                icon: 'mdi:wrench'
            • MatohlM Matohl
              @gwp1
              panel_iframe:
                reactor:
                  title: "Reactor"
                  icon: 'mdi:wrench'
              @matohl Yessir - figured that out way too late into the night to reply 😉 Also used this to add my two Hubitats to the mix.
                164.2k
