  4. MQTT interface... time for some testing. Where are my experts?
55 Posts 6 Posters 25.0k Views 6 Watching
    Everyone, I'm going to hold off releasing this, not because it isn't ready, but because I'm not ready to handle install issues and questions for it (it's a separate add-on, and has its own all new configuration requirements, of course). The complication is that I'm travelling starting Friday morning on a college preview/visit for my older son, and I really need to give that (and him) my undivided attention.
    So, I'll push this out when I return, either Sunday night or Monday morning. Sorry for the delay.
      OK. MQTTController is now published. A few things to know:
      1. It's a separate component you need to download and install;
      2. Instructions for getting it, installing it, and configuring it are here;
      3. Please make sure your posts and new topics (especially questions and reports of possible bugs) follow the posting guidelines (see pinned post in this category).
        Am I correct to assume there's no support for authentication yet? I could not find anything about it in the documentation.
          Working on it, but not in that release.
            Turns out, you can do it with a workaround for now...
            After source, add options, with username and password, like this:
                  source: "mqtt://127.0.0.1:1883/"
                  options:
                    username: whoever
                    password: whatever
              Sweet, it's up and running!
                May I suggest that the init is an optional parameter set in reactor.yaml like unit in the templates for Tasmota devices, as openLuup ignores the retain flag so every device has to be polled at Reactor startup to not show null values.
                  It's done. It's that. I didn't announce the release, but init is in 21326 of MQTTController, here: https://reactor.toggledbits.com/download/extras/MQTTController/
                    I have this in my custom template for temperature:
                    my_tasmota_sensor_temperature:
                        type: ValueSensor
                        init:
                          - topic: "cmnd/%topic%/STATUS"
                            payload: 10
                            type: raw
                        events:
                          "tele/%topic%/SENSOR":
                            "temperature_sensor.value":
                            "temperature_sensor.units":
                              expr: payload.TempUnit
                          "stat/%topic%/STATUS10":
                              expr: 'payload.StatusSNS[ source ?? "Global" ]?.Temperature'
                              expr: payload.StatusSNS.TempUnit
                    I can't figure out how to use init to acheive this using the stock template.
                    I actually updated to 21326 before posting, following the docs for installation/upgrade but the version number in the template file says 21321 and has no notes of init
                      The template file is not relevant for version number, look at MQTTController.js.
                      Can you show me the rest of your config for this entity/Tasmota node?
                      Also you don't need to make a custom template just to add init. You can use the stock template and put init in the configuration (e.g. next to uses_template).
                        Ah, of cource.
                        For now it's
                        "pooltemp":
                                  topic: "Pooltemp"
                                  source: "DS18B20"
                                  uses_template: my_tasmota_sensor_temperature
                        Best guessing I've tried this
                        "pooltemp":
                                  topic: "Pooltemp"
                                  source: "DS18B20"
                                  init:
                                      payload: 10
                                      type: raw
                          You need to make sure the response to that command actually includes the data you want. I've found that some Tasmota devices return incomplete state on this query. For example, I have a node set up with two relays, and this query does not provide the state of the two relays. The alternate choice, then, is to send cmnd/%topic%Power with no payload, and the node replies with a RESULT topic and the current state (which the template understands).
                          My guess is this issue is moot, however, if you're using an MQTT broker that supports QoS and retain.
                          X 1 Reply Last reply
                            X Offline
                            X Offline
                            xAPPO
                            wrote on last edited by xAPPO
                            I'm really sorry but I'm failing getting this running - It seems to not be able to find the MQTT files on startup. Running in Docker and have created the correct directory structure with files. It can read my edited config yaml files from home/kevin/reactor/config OK. Permissions are OK.
                            Have a lot of MQTT experience but not so hot on Linux/Docker this was my run command
                            docker run --name reactor -d --restart on-failure -p 8111:8111 -v /home/kevin/reactor:/var/reactor  --mount type=bind,src=/etc/localtime,target=/etc/localtime toggledbits/reactor:latest-generic-amd64
                            I have
                            [latest-22004]2022-01-07T02:08:16.554Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                            [latest-22004]2022-01-07T02:08:16.560Z <MQTTController:null> Module MQTTController v21361
                            [latest-22004]2022-01-07T02:08:16.561Z <Controller:CRIT> Controller: failed to load mqtt implementation file:///var/reactor/ext/MQTTController/MQTTController.js: [Error]Error: Cannot find module 'mqtt'
                            Require stack:
                            - /var/reactor/ext/MQTTController/MQTTController.js
                            [latest-22004]2022-01-07T02:08:16.562Z <Controller:CRIT> Error: Cannot find module 'mqtt'
                            Require stack:
                            Require stack:
                              Did you just drop it in the folder, or did you go through all the installation steps? The message logged suggests that step 5 wasn't completed.
                              MQTTController - Reactor - Multi-Hub Automation
                              • X Offline
                                X Offline
                                xAPPO
                                I followed the instructions. Including step 5. I have a feeling I saw an error at some stage in that install so I will revisit that step and report back.
                                • X xAPPO
                                  X Offline
                                  X Offline
                                  xAPPO
                                  #22
                                  This is what I see when running step5 ./install.sh
                                  Installing dependencies...
                                  make: Entering directory '/home/kevin/reactor/ext/MQTTController/node_modules/in        otify/build'
                                    CXX(target) Release/obj.target/inotify/src/bindings.o
                                  In file included from ../src/bindings.cc:2:0:
                                  ../src/bindings.h:10:27: error: ‘Handle’ has not been declared
                                      static void Initialize(Handle<Object> target);
                                  ../src/bindings.h:10:33: error: expected ‘,’ or ‘...’ before ‘<’ token
                                  ../src/bindings.cc:11:27: error: variable or field ‘Initialize’ declared void
                                    void Inotify::Initialize(Handle<Object> exports) {
                                  ../src/bindings.cc:11:27: error: ‘Handle’ was not declared in this scope
                                  ../src/bindings.cc:11:27: note: suggested alternative: ‘rand_r’
                                                             rand_r
                                  ../src/bindings.cc:11:40: error: expected primary-expression before ‘>’ token
                                  ../src/bindings.cc:11:42: error: ‘exports’ was not declared in this scope
                                  ../src/bindings.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYP        E NodeInotify::Inotify::AddWatch(Nan::NAN_METHOD_ARGS_TYPE)’:
                                  ../src/bindings.cc:146:43: error: no matching function for call to ‘v8::Value::T        oObject()’
                                     Local<Object> args_ = info[0]->ToObject();
                                  In file included from /home/kevin/.cache/node-gyp/12.20.0/include/node/node.h:67        :0,
                                                   from ../src/node_inotify.h:5,
                                                   from ../src/bindings.h:4,
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2672:44: note: candidate:        v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
                                     V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2672:44: note:   candidate        expects 1 argument, 0 provided
                                  In file included from /home/kevin/.cache/node-gyp/12.20.0/include/node/v8-intern        al.h:14:0,
                                                   from /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:27,
                                                   from /home/kevin/.cache/node-gyp/12.20.0/include/node/node.h:6        ,
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2686:31: note: candidate:        v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                                                   Local<Object> ToObject(Isolate* isolate) const);
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8config.h:328:3: note: in defi        nition of macro ‘V8_DEPRECATED’
                                     declarator __attribute__((deprecated(message)))
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2686:31: note:   candidate        expects 1 argument, 0 provided
                                  ../src/bindings.cc:149:27: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                                     if (!args_->Has(path_sym)) {
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3590:37: note: candidate:        v8::Maybe<bool> v8::Object::Has(v8::Local<v8::Context>, v8::Local<v8::Value>)
                                     V8_WARN_UNUSED_RESULT Maybe<bool> Has(Local<Context> context,
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3590:37: note:   candidate        expects 2 arguments, 1 provided
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3596:37: note: candidate:        v8::Maybe<bool> v8::Object::Has(v8::Local<v8::Context>, uint32_t)
                                     V8_WARN_UNUSED_RESULT Maybe<bool> Has(Local<Context> context, uint32_t index)        ;
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3596:37: note:   candidate        expects 2 arguments, 1 provided
                                  ../src/bindings.cc:154:31: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                                     if (!args_->Has(callback_sym) ||
                                  ../src/bindings.cc:155:28: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      !args_->Get(callback_sym)->IsFunction()) {
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3553:51: note: declared he        re
                                     V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
                                  ../src/bindings.cc:160:32: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                                     if (!args_->Has(watch_for_sym)) {
                                  ../src/bindings.cc:163:33: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      if (!args_->Get(watch_for_sym)->IsInt32()) {
                                  ../src/bindings.cc:166:36: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                      mask |= args_->Get(watch_for_sym)->Int32Value();
                                  ../src/bindings.cc:166:50: error: no matching function for call to ‘v8::Value::I        nt32Value()’
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2709:40: note: candidate:        v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const
                                     V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const        ;
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2709:40: note:   candidate        expects 1 argument, 0 provided
                                  ../src/bindings.cc:172:45: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     String::Utf8Value path(args_->Get(path_sym));
                                  ../src/bindings.cc:172:46: error: no matching function for call to ‘v8::String::        Utf8Value::Utf8Value(v8::Local<v8::Value>)’
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3135:5: note: candidate: v        8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
                                       Utf8Value(Isolate* isolate, Local<v8::Value> obj);
                                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3135:5: note:   candidate        expects 2 arguments, 1 provided
                                  ../src/bindings.cc:182:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     inotify->handle()->Set(descriptor, args_->Get(callback_sym));
                                  • X xAPPO
                                                               rand_r
                                    X Offline
                                    X Offline
                                    xAPPO
                                    #23
                                    IN two posts because was too long - sorry
                                    ../src/bindings.cc:182:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3499:22: note: declared he        re
                                                     bool Set(Local<Value> key, Local<Value> value));
                                    ../src/bindings.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYP        E NodeInotify::Inotify::RemoveWatch(Nan::NAN_METHOD_ARGS_TYPE)’:
                                    ../src/bindings.cc:195:31: error: no matching function for call to ‘v8::Value::I        nt32Value()’
                                       watch = info[0]->Int32Value();
                                    ../src/bindings.cc: In static member function ‘static void NodeInotify::Inotify:        :Callback(uv_poll_t*, int, int)’:
                                    ../src/bindings.cc:262:86: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                                     >Set(Nan::New<String>("watch").ToLocalChecked(), Nan::New<Integer>(event->wd));
                                    ../src/bindings.cc:263:87: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                                     Set(Nan::New<String>("mask").ToLocalChecked(), Nan::New<Integer>(event->mask));
                                    ../src/bindings.cc:264:91: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                                     Nan::New<String>("cookie").ToLocalChecked(), Nan::New<Integer>(event->cookie));
                                    ../src/bindings.cc:267:104: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarati        ons]
                                     ing>("name").ToLocalChecked(), Nan::New<String>(event->name).ToLocalChecked());
                                    ../src/bindings.cc:275:66: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                         Local<Value> value = handle->Get(Nan::New<Integer>(event->wd));
                                    ../src/bindings.cc:279:34: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(v8        ::Local<v8::Object>, int, v8::Local<v8::Value>*) const’ is deprecated [-Wdepreca        ted-declarations]
                                         callback.Call(handle, 1, argv);
                                    In file included from ../src/node_inotify.h:14:0,
                                    ../../nan/nan.h:1722:3: note: declared here
                                       Call(v8::Local<v8::Object> target
                                    ../src/bindings.cc:285:34: error: no matching function for call to ‘v8::Value::T        oString()’
                                          handle->Delete(wd->ToString());
                                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2668:44: note: candidate:        v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
                                       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2668:44: note:   candidate        expects 1 argument, 0 provided
                                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2684:31: note: candidate:        v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                                                     Local<String> ToString(Isolate* isolate) const);
                                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2684:31: note:   candidate        expects 1 argument, 0 provided
                                    inotify.target.mk:112: recipe for target 'Release/obj.target/inotify/src/binding        s.o' failed
                                    make: *** [Release/obj.target/inotify/src/bindings.o] Error 1
                                    make: Leaving directory '/home/kevin/reactor/ext/MQTTController/node_modules/ino        tify/build'
                                    kevin@NUC50:~/reactor/ext/MQTTController$
                                      #24
                                      Seems like something is broken or out of date in your nodejs installation. How did you install node? And what version is it (run node -v)
                                      • X Offline
                                        X Offline
                                        xAPPO
                                        Its a docker install so I thought that was part of the container .. on the host OS my version is v12.20.0 - should I update that ?
                                          Yeah, that's going to be a problem. Version 16.13 is the current, I believe, and would be a good choice.
                                            159.7k
