  4. MQTT interface... time for some testing. Where are my experts?
55 Posts 6 Posters 25.0k Views 6 Watching
    I have this in my custom template for temperature:
    my_tasmota_sensor_temperature:
        type: ValueSensor
        init:
          - topic: "cmnd/%topic%/STATUS"
            payload: 10
            type: raw
        events:
          "tele/%topic%/SENSOR":
            "temperature_sensor.value":
            "temperature_sensor.units":
              expr: payload.TempUnit
          "stat/%topic%/STATUS10":
              expr: 'payload.StatusSNS[ source ?? "Global" ]?.Temperature'
              expr: payload.StatusSNS.TempUnit
    I can't figure out how to use init to acheive this using the stock template.
    I actually updated to 21326 before posting, following the docs for installation/upgrade but the version number in the template file says 21321 and has no notes of init
      The template file is not relevant for version number, look at MQTTController.js.
      Can you show me the rest of your config for this entity/Tasmota node?
      Also you don't need to make a custom template just to add init. You can use the stock template and put init in the configuration (e.g. next to uses_template).
        Ah, of cource.
        For now it's
        "pooltemp":
                  topic: "Pooltemp"
                  source: "DS18B20"
                  uses_template: my_tasmota_sensor_temperature
        Best guessing I've tried this
        "pooltemp":
                  topic: "Pooltemp"
                  source: "DS18B20"
                  init:
                      payload: 10
                      type: raw
          You need to make sure the response to that command actually includes the data you want. I've found that some Tasmota devices return incomplete state on this query. For example, I have a node set up with two relays, and this query does not provide the state of the two relays. The alternate choice, then, is to send cmnd/%topic%Power with no payload, and the node replies with a RESULT topic and the current state (which the template understands).
          My guess is this issue is moot, however, if you're using an MQTT broker that supports QoS and retain.
          X 1 Reply Last reply
            X Offline
            X Offline
            xAPPO
            wrote on last edited by xAPPO
            I'm really sorry but I'm failing getting this running - It seems to not be able to find the MQTT files on startup. Running in Docker and have created the correct directory structure with files. It can read my edited config yaml files from home/kevin/reactor/config OK. Permissions are OK.
            Have a lot of MQTT experience but not so hot on Linux/Docker this was my run command
            docker run --name reactor -d --restart on-failure -p 8111:8111 -v /home/kevin/reactor:/var/reactor  --mount type=bind,src=/etc/localtime,target=/etc/localtime toggledbits/reactor:latest-generic-amd64
            I have
            [latest-22004]2022-01-07T02:08:16.554Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
            [latest-22004]2022-01-07T02:08:16.560Z <MQTTController:null> Module MQTTController v21361
            [latest-22004]2022-01-07T02:08:16.561Z <Controller:CRIT> Controller: failed to load mqtt implementation file:///var/reactor/ext/MQTTController/MQTTController.js: [Error]Error: Cannot find module 'mqtt'
            Require stack:
            - /var/reactor/ext/MQTTController/MQTTController.js
            [latest-22004]2022-01-07T02:08:16.562Z <Controller:CRIT> Error: Cannot find module 'mqtt'
            Require stack:
            Require stack:
              Did you just drop it in the folder, or did you go through all the installation steps? The message logged suggests that step 5 wasn't completed.
              MQTTController - Reactor - Multi-Hub Automation
              • X Offline
                X Offline
                xAPPO
                I followed the instructions. Including step 5. I have a feeling I saw an error at some stage in that install so I will revisit that step and report back.
                • X xAPPO
                  X Offline
                  X Offline
                  xAPPO
                  #22
                  This is what I see when running step5 ./install.sh
                  Installing dependencies...
                  make: Entering directory '/home/kevin/reactor/ext/MQTTController/node_modules/in        otify/build'
                    CXX(target) Release/obj.target/inotify/src/bindings.o
                  In file included from ../src/bindings.cc:2:0:
                  ../src/bindings.h:10:27: error: ‘Handle’ has not been declared
                      static void Initialize(Handle<Object> target);
                  ../src/bindings.h:10:33: error: expected ‘,’ or ‘...’ before ‘<’ token
                  ../src/bindings.cc:11:27: error: variable or field ‘Initialize’ declared void
                    void Inotify::Initialize(Handle<Object> exports) {
                  ../src/bindings.cc:11:27: error: ‘Handle’ was not declared in this scope
                  ../src/bindings.cc:11:27: note: suggested alternative: ‘rand_r’
                                             rand_r
                  ../src/bindings.cc:11:40: error: expected primary-expression before ‘>’ token
                  ../src/bindings.cc:11:42: error: ‘exports’ was not declared in this scope
                  ../src/bindings.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYP        E NodeInotify::Inotify::AddWatch(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/bindings.cc:146:43: error: no matching function for call to ‘v8::Value::T        oObject()’
                     Local<Object> args_ = info[0]->ToObject();
                  In file included from /home/kevin/.cache/node-gyp/12.20.0/include/node/node.h:67        :0,
                                   from ../src/node_inotify.h:5,
                                   from ../src/bindings.h:4,
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2672:44: note: candidate:        v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
                     V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2672:44: note:   candidate        expects 1 argument, 0 provided
                  In file included from /home/kevin/.cache/node-gyp/12.20.0/include/node/v8-intern        al.h:14:0,
                                   from /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:27,
                                   from /home/kevin/.cache/node-gyp/12.20.0/include/node/node.h:6        ,
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2686:31: note: candidate:        v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                                   Local<Object> ToObject(Isolate* isolate) const);
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8config.h:328:3: note: in defi        nition of macro ‘V8_DEPRECATED’
                     declarator __attribute__((deprecated(message)))
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2686:31: note:   candidate        expects 1 argument, 0 provided
                  ../src/bindings.cc:149:27: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                     if (!args_->Has(path_sym)) {
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3590:37: note: candidate:        v8::Maybe<bool> v8::Object::Has(v8::Local<v8::Context>, v8::Local<v8::Value>)
                     V8_WARN_UNUSED_RESULT Maybe<bool> Has(Local<Context> context,
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3590:37: note:   candidate        expects 2 arguments, 1 provided
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3596:37: note: candidate:        v8::Maybe<bool> v8::Object::Has(v8::Local<v8::Context>, uint32_t)
                     V8_WARN_UNUSED_RESULT Maybe<bool> Has(Local<Context> context, uint32_t index)        ;
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3596:37: note:   candidate        expects 2 arguments, 1 provided
                  ../src/bindings.cc:154:31: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                     if (!args_->Has(callback_sym) ||
                  ../src/bindings.cc:155:28: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                      !args_->Get(callback_sym)->IsFunction()) {
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3553:51: note: declared he        re
                     V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
                  ../src/bindings.cc:160:32: error: no matching function for call to ‘v8::Object::        Has(v8::Local<v8::String>&)’
                     if (!args_->Has(watch_for_sym)) {
                  ../src/bindings.cc:163:33: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                      if (!args_->Get(watch_for_sym)->IsInt32()) {
                  ../src/bindings.cc:166:36: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                      mask |= args_->Get(watch_for_sym)->Int32Value();
                  ../src/bindings.cc:166:50: error: no matching function for call to ‘v8::Value::I        nt32Value()’
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2709:40: note: candidate:        v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const
                     V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const        ;
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2709:40: note:   candidate        expects 1 argument, 0 provided
                  ../src/bindings.cc:172:45: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     String::Utf8Value path(args_->Get(path_sym));
                  ../src/bindings.cc:172:46: error: no matching function for call to ‘v8::String::        Utf8Value::Utf8Value(v8::Local<v8::Value>)’
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3135:5: note: candidate: v        8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
                       Utf8Value(Isolate* isolate, Local<v8::Value> obj);
                  /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3135:5: note:   candidate        expects 2 arguments, 1 provided
                  ../src/bindings.cc:182:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     inotify->handle()->Set(descriptor, args_->Get(callback_sym));
                  • X xAPPO
                                               rand_r
                    X Offline
                    X Offline
                    xAPPO
                    #23
                    IN two posts because was too long - sorry
                    ../src/bindings.cc:182:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:3499:22: note: declared he        re
                                     bool Set(Local<Value> key, Local<Value> value));
                    ../src/bindings.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYP        E NodeInotify::Inotify::RemoveWatch(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/bindings.cc:195:31: error: no matching function for call to ‘v8::Value::I        nt32Value()’
                       watch = info[0]->Int32Value();
                    ../src/bindings.cc: In static member function ‘static void NodeInotify::Inotify:        :Callback(uv_poll_t*, int, int)’:
                    ../src/bindings.cc:262:86: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                     >Set(Nan::New<String>("watch").ToLocalChecked(), Nan::New<Integer>(event->wd));
                    ../src/bindings.cc:263:87: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                     Set(Nan::New<String>("mask").ToLocalChecked(), Nan::New<Integer>(event->mask));
                    ../src/bindings.cc:264:91: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declaratio        ns]
                     Nan::New<String>("cookie").ToLocalChecked(), Nan::New<Integer>(event->cookie));
                    ../src/bindings.cc:267:104: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>,        v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarati        ons]
                     ing>("name").ToLocalChecked(), Nan::New<String>(event->name).ToLocalChecked());
                    ../src/bindings.cc:275:66: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Lo        cal<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         Local<Value> value = handle->Get(Nan::New<Integer>(event->wd));
                    ../src/bindings.cc:279:34: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(v8        ::Local<v8::Object>, int, v8::Local<v8::Value>*) const’ is deprecated [-Wdepreca        ted-declarations]
                         callback.Call(handle, 1, argv);
                    In file included from ../src/node_inotify.h:14:0,
                    ../../nan/nan.h:1722:3: note: declared here
                       Call(v8::Local<v8::Object> target
                    ../src/bindings.cc:285:34: error: no matching function for call to ‘v8::Value::T        oString()’
                          handle->Delete(wd->ToString());
                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2668:44: note: candidate:        v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
                       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2668:44: note:   candidate        expects 1 argument, 0 provided
                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2684:31: note: candidate:        v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                                     Local<String> ToString(Isolate* isolate) const);
                    /home/kevin/.cache/node-gyp/12.20.0/include/node/v8.h:2684:31: note:   candidate        expects 1 argument, 0 provided
                    inotify.target.mk:112: recipe for target 'Release/obj.target/inotify/src/binding        s.o' failed
                    make: *** [Release/obj.target/inotify/src/bindings.o] Error 1
                    make: Leaving directory '/home/kevin/reactor/ext/MQTTController/node_modules/ino        tify/build'
                    kevin@NUC50:~/reactor/ext/MQTTController$
                      #24
                      Seems like something is broken or out of date in your nodejs installation. How did you install node? And what version is it (run node -v)
                      • X Offline
                        X Offline
                        xAPPO
                        Its a docker install so I thought that was part of the container .. on the host OS my version is v12.20.0 - should I update that ?
                          Yeah, that's going to be a problem. Version 16.13 is the current, I believe, and would be a good choice.
                          • X Offline
                            X Offline
                            xAPPO
                            Thankyou - that's worked. I had assumed the appropriate version of node was part of the Docker container.
                            So pleased to have found this as I use HA, MQTT, Hubitat extensively plus OpenHAB and Homey to a lesser extent so glad you are intending to support those two eventually.
                              It is part of the container, but you are not running in the container. That is a possibility, though, and I tried it, it seems to work, so an alternative to installing (or upgrading) nodejs outside of the container seems to be:
                              docker exec -it reactor /bin/sh
                              cd /var/reactor/ext/MQTTController
                              ./install.sh
                              exit
                              I'll add this to the installation docs for MQTTController.
                                ./install.sh
                                exit
                                X Offline
                                X Offline
                                xAPPO
                                #29
                                All working well. However in the topic structure for echoed devices (from Hubitat anyway) the <entity-id> is used. Is it possible to instead or even better as well as, include the entity-name ?
                                reactor/<mqtt-id>/<ctrl-id>/<entity-id>/state/<capability-name>
                                perhaps
                                reactor/<mqtt-id>/<ctrl-id>/<entity-name>/<entity-id>/state/<capability-name>
                                  The entity name can be changed or duplicated and is not an appropriate unique identifier for a device.
                                  • X Offline
                                    X Offline
                                    xAPPO
                                    Topic hierarchy segments don't have to be unique - in fact I would say most aren't. Keeping the <entity-id> then within the hierarchy would ensure the topic remains unique. Having no easily human identifiable topic is not helpful to other integrations.
                                    • X xAPPO
                                      @xappo OK. And what about receiving messages for inbound action requests? Same entity-name/entity-id construction? If you know the correct entity ID to form that message, what value is the name? If you don't know the ID and only use the name, how do you specify that, and what if the name isn't unique then? And what if the name and ID conflict, or an entity can be found for one but not the other (i.e. they don't match)? I'm not opposed to what you're proposing, but I want you to help me think through the consequences of it.
                                      @xappo said in MQTT interface... time for some testing. Where are my experts?:
                                      I think that's a bit of a reach. The whole MQTT environment is so unstructured and freeform, with so many inconsistencies between players, that things like unique IDs (or MAC addresses or other cryptic and "hard to read" identifiers) are a regular occurrence, and anybody who uses MQTT a lot is used to it.
                                      • X Offline
                                        X Offline
                                        xAPPO
                                        #33
                                        The incoming action request message to a topic must be complete with all segments as you can't wildcard a publish command. So the <entity-id> will always be unique and present there. You could should you wish subscribe to the topic from your code ignoring any <entity-name> segment with a + wildcard as you don't process it. So that should work fine.
                                        Human readability.. I agree it's a bit of a reach but my whole system is MQTT based with over 10K topics and 1K+ devices - remembering what they all are and linking to or from those topics from other controllers requires some hints as to what those devices are. Later examination of logic requires understanding what devices are related. Having to refer back to Reactor config each time to identify a device isn't practical (or user friendly).
                                          Good stuff. Let me see what I can cook up.
                                            159.7k
