  4. Release 22021 Windows Bare-metal won't load
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 2 Posters 1.4k Views 2 Watching
  • wmarcolinW Offline
    I have the same situation as the Reactor interface wouldn't load in the browser, I use Windows bare-metal installation.
    Unlike the previous comment, looking at the log file I have no error, everything is loaded, and I see that the Reactor is operating, the actions are happening, only the interface in the browser that does not open.
      @wmarcolin did you run npm to update the dependencies for this release? Documented here.
      wmarcolinW 1 Reply Last reply
        @toggledbits yes, I even saw in the manual that in the installation process you updated the command to Windows bare-metal.
        The first attempt was to follow the procedure of overwriting files from the current installation with the new version, and run the NPM process as you put in the update note. I noticed that the MSR ran, there was no error in the log, but the browse would not open.
        The second attempt, was a fresh installation, just copying from the old installation the config and storage directory, again browse did not open.
        The third action was then to do a completely new installation, copy the new config files from dist-config, update the IP and remove the Dynamic Group block because I did not put any controllers.
        IT WORKED PERFECTLY! I see the new About page and the new Status with the new Widget, new toy 🙂
        I stopped the MSR, and then copied the config and storage directories from the old version (22004), and it booted up again.
        I am no expert, but it seems to me that something in the old version might be blocking the browse from working. I have several copies of each attempt, if you want me to send you some log, or information, or make new attempts please send me a message and I will pass you the materials.
        Sorry for the boldness, but I would like to make a suggestion for the Widgets, would it be possible to remove the technical name of the rule from the logs (rule-kxhekauro)? I believe that everyone puts a name on their actions and this information may not be very useful).
        NOW IT IS VERY GOOD! One less item on the wishlist
        Once again thank you very much for all your dedication!
          If MSR starts but the browser won't open, that's often just one of the controllers being slow to start for some reason (usually communication with the hub). You have to wait over 60 seconds before declaring a problem, because that's how long it takes for the controller to time out. All controllers have to start up or time out before the HTTP API starts and the UI can come up. This is described in the Troubleshooting section of the docs.
            Yes, I know this instruction, I even increased the time to 90 seconds two versions ago, so I wait.
            Well it is working now, but I started from a new installation, and only then copied the directories as I described above.
            I have another lab machine and will try to reproduce the problem. I remember some post that you comment on where we can see better the boot log, with more details, can you remind me where you have this information? Thanks.
              On Windows, I don't know where it logs. That may be a good exploration for you... I would think the Windows Event Log would be the right place to start. Not sure what section, though...
              • wmarcolinW wmarcolin
                @wmarcolin said in Release 22021 Windows Bare-metal won't load:
                THANKS BOSS!! New version 22022 worked!!
                  164.3k
