  4. Release 22021 Windows Bare-metal won't load
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
7 Posts 2 Posters 860 Views 2 Watching
  • wmarcolinW Offline
    I have the same situation as the Reactor interface wouldn't load in the browser, I use Windows bare-metal installation.
    Unlike the previous comment, looking at the log file I have no error, everything is loaded, and I see that the Reactor is operating, the actions are happening, only the interface in the browser that does not open.
      @wmarcolin did you run npm to update the dependencies for this release? Documented here.
      wmarcolinW 1 Reply Last reply
        @toggledbits yes, I even saw in the manual that in the installation process you updated the command to Windows bare-metal.
        The first attempt was to follow the procedure of overwriting files from the current installation with the new version, and run the NPM process as you put in the update note. I noticed that the MSR ran, there was no error in the log, but the browse would not open.
        The second attempt, was a fresh installation, just copying from the old installation the config and storage directory, again browse did not open.
        The third action was then to do a completely new installation, copy the new config files from dist-config, update the IP and remove the Dynamic Group block because I did not put any controllers.
        IT WORKED PERFECTLY! I see the new About page and the new Status with the new Widget, new toy 🙂
        I stopped the MSR, and then copied the config and storage directories from the old version (22004), and it booted up again.
        I am no expert, but it seems to me that something in the old version might be blocking the browse from working. I have several copies of each attempt, if you want me to send you some log, or information, or make new attempts please send me a message and I will pass you the materials.
        Sorry for the boldness, but I would like to make a suggestion for the Widgets, would it be possible to remove the technical name of the rule from the logs (rule-kxhekauro)? I believe that everyone puts a name on their actions and this information may not be very useful).
        NOW IT IS VERY GOOD! One less item on the wishlist
        Once again thank you very much for all your dedication!
          If MSR starts but the browser won't open, that's often just one of the controllers being slow to start for some reason (usually communication with the hub). You have to wait over 60 seconds before declaring a problem, because that's how long it takes for the controller to time out. All controllers have to start up or time out before the HTTP API starts and the UI can come up. This is described in the Troubleshooting section of the docs.
            Yes, I know this instruction, I even increased the time to 90 seconds two versions ago, so I wait.
            Well it is working now, but I started from a new installation, and only then copied the directories as I described above.
            I have another lab machine and will try to reproduce the problem. I remember some post that you comment on where we can see better the boot log, with more details, can you remind me where you have this information? Thanks.
              On Windows, I don't know where it logs. That may be a good exploration for you... I would think the Windows Event Log would be the right place to start. Not sure what section, though...
              • wmarcolinW wmarcolin
                @wmarcolin said in Release 22021 Windows Bare-metal won't load:
                THANKS BOSS!! New version 22022 worked!!
                  2.0k
                  3.8k
                  3.3k
