zwavejs
51 Posts 10 Posters 22.8k Views 10 Watching
    If you are using Home Assistant with ZWave-JS, please let me know by reply or PM here.
    I'd like you to be part of my test and device integration team for Reactor's direct support of ZWave-JS. This would not change your Home Assistant configuration in any way, nor would it require you to change any automations. It will just publish new entities and capabilities in addition to what you are already seeing through Home Assistant.
    • E Offline
      E Offline
      eonnet
      I’m using HA with zwavejs2mqtt addon
        sender
        I use zwavejs in homeassistant with 80 devices. but I only know reactor by name... do I need it?
          RogerO
          Using HA with zwavejs2mqtt.
          • F Offline
            Count me in!
            • wmarcolinW Offline
              I do not use it, as we have talked about before, but if necessary I will install it and can be one more to help with tests.
              • V Offline
                V Offline
                I would be happy to assist. I am also using zwavejs2mqtt without the mqtt part activated.
                  apocalypsehobby
                  Sign me up 👍
                  • K Offline
                    K Offline
                    kellyjelly32
                    Running a HA with zwaveJS2 and an old Vera Lite with some not-yet-migrated devices. Reason for not migrating is that I love Reactor. On HA I was not able to get MSR to run yet.
                    • K kellyjelly32
                      @kellyjelly32 said in Who are my Home Assistant + ZWave-JS users?:
                      It's a pretty easy setup. If you've had trouble getting it done, I recommend opening a new thread for that discussion.
                      Ref: Docs: Configuration for Home Assistant
                        RogerO
                        @toggledbits Any info on what and when this is coming?
                        • 3 Offline
                          3 Offline
                          Had some issues with Aqara motion sensors falling off my Hubitat after a few hours. (Yes, the manufacturer is not supported on HE.) But this led me down a path to stand up HA in my docker. Which then led me down another path of getting the zwavejs2mqtt docker running and integrated. So I may be down for this.
                          Am I assuming that MSR will become my JS provider and I could possibly shutdown the zwavejs2mqtt docker?
                          • R RogerO
                            @rogero I got bogged down trying to get newer scene controllers to work, and I think I've got it now. Really nice, actually (using a Zooz ZEN32 for testing). Heck, I even got an ancient Everwave SC-7 working great, and it just wasn't reliable on Vera at all. The effort being put into Z-Wave JS really shows.
                            @3rdstng said in Who are my Home Assistant + ZWave-JS users?:
                            You'll either need to keep zwavejs2mqtt or install and run the zwave-js-server. I'm not doing a direct interface (i.e. library direct to serial port) just yet, but that's coming. The management tools of zwavejs2mqtt are pretty nice, so that's a good incentive to keep it.
                              RogerO
                              Excellent, I have a few of those installed and the Blueprints I found for them are not super dependable.
                                RogerO
                                @toggledbits Next you will be saying your Leviton scene controllers are working perfectly.
                                • R RogerO
                                  @rogero I've had those going good for a while on Vera, using a plugin I wrote but never published (a few people got it, though... were you one of them?). I don't expect much trouble from them on Z-WaveJS. Also testing Hank 4-button and Remotec ZRC-90.
                                    RogerO
                                    Yes, I was one of the people you shared it with. It did work very well. Replaced them with the ZEN32's but at my age I cannot remember what 4 pushes of the bottom left button does, etc. Need to tape a legend to the wall. Look forward to having them running in MSR.
                                      Haven't forgotten you all... I've been working furiously at putting this together, including a new build system (because I'll be doing this release on a separate track, not in latest). I'm trying to get something out this weekend for a first look.
                                      Do any/all/none of you all use Discord?
                                        RogerO
                                        I do not.
                                        • V Offline
                                          V Offline
                                          I don't, but I could if that's the way you want to communicate.
                                            155.6k
