TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
zwavejs
51 Posts 10 Posters 14.9k Views 10 Watching
    If you are using Home Assistant with ZWave-JS, please let me know by reply or PM here.
    I'd like you to be part of my test and device integration team for Reactor's direct support of ZWave-JS. This would not change your Home Assistant configuration in any way, nor would it require you to change any automations. It will just publish new entities and capabilities in addition to what you are already seeing through Home Assistant.
    • E Offline
      E Offline
      eonnet
      I’m using HA with zwavejs2mqtt addon
        sender
        I use zwavejs in homeassistant with 80 devices. but I only know reactor by name... do I need it?
          RogerO
          Using HA with zwavejs2mqtt.
          • F Offline
            Count me in!
            • wmarcolinW Offline
              I do not use it, as we have talked about before, but if necessary I will install it and can be one more to help with tests.
              • V Offline
                V Offline
                I would be happy to assist. I am also using zwavejs2mqtt without the mqtt part activated.
                Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
                  apocalypsehobby
                  Sign me up 👍
                  • K Offline
                    K Offline
                    kellyjelly32
                    Running a HA with zwaveJS2 and an old Vera Lite with some not-yet-migrated devices. Reason for not migrating is that I love Reactor. On HA I was not able to get MSR to run yet.
                    • K kellyjelly32
                      @kellyjelly32 said in Who are my Home Assistant + ZWave-JS users?:
                      It's a pretty easy setup. If you've had trouble getting it done, I recommend opening a new thread for that discussion.
                      Ref: Docs: Configuration for Home Assistant
                        RogerO
                        @toggledbits Any info on what and when this is coming?
                        • 3 Offline
                          3 Offline
                          Had some issues with Aqara motion sensors falling off my Hubitat after a few hours. (Yes, the manufacturer is not supported on HE.) But this led me down a path to stand up HA in my docker. Which then led me down another path of getting the zwavejs2mqtt docker running and integrated. So I may be down for this.
                          Am I assuming that MSR will become my JS provider and I could possibly shutdown the zwavejs2mqtt docker?
                          • R RogerO
                            @rogero I got bogged down trying to get newer scene controllers to work, and I think I've got it now. Really nice, actually (using a Zooz ZEN32 for testing). Heck, I even got an ancient Everwave SC-7 working great, and it just wasn't reliable on Vera at all. The effort being put into Z-Wave JS really shows.
                            @3rdstng said in Who are my Home Assistant + ZWave-JS users?:
                            You'll either need to keep zwavejs2mqtt or install and run the zwave-js-server. I'm not doing a direct interface (i.e. library direct to serial port) just yet, but that's coming. The management tools of zwavejs2mqtt are pretty nice, so that's a good incentive to keep it.
                              RogerO
                              Excellent, I have a few of those installed and the Blueprints I found for them are not super dependable.
                                RogerO
                                @toggledbits Next you will be saying your Leviton scene controllers are working perfectly.
                                • R RogerO
                                  @rogero I've had those going good for a while on Vera, using a plugin I wrote but never published (a few people got it, though... were you one of them?). I don't expect much trouble from them on Z-WaveJS. Also testing Hank 4-button and Remotec ZRC-90.
                                    RogerO
                                    Yes, I was one of the people you shared it with. It did work very well. Replaced them with the ZEN32's but at my age I cannot remember what 4 pushes of the bottom left button does, etc. Need to tape a legend to the wall. Look forward to having them running in MSR.
                                      Haven't forgotten you all... I've been working furiously at putting this together, including a new build system (because I'll be doing this release on a separate track, not in latest). I'm trying to get something out this weekend for a first look.
                                      Do any/all/none of you all use Discord?
                                        RogerO
                                        I do not.
                                        • V Offline
                                          V Offline
                                          I don't, but I could if that's the way you want to communicate.
                                            2.1k
                                            3.8k
                                            3.3k
