  4. MSR Not Recognizing Old HASS on New VM
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
20 Posts 2 Posters 3.3k Views 2 Watching
    OK. All I can suggest at this point is that maybe you have the old IP address of the previous system in Hass' configuration somewhere and it's messing things up. Beyond that, I'm out of ideas. Maybe shut down that VM, create a new one, install Hass fresh and clean without restoring the prior configuration, just use a default configuration, and see if you can connect to it. If you can, it's definitely something in the old config/restored install. If you can't, maybe something in the VM configuration... I don't know. This usually isn't much of a challenge, and HassController isn't doing anything tricky, it uses a standard Websocket library in wide use for its connections, so I'm doubtful there's suddenly some bug or incompatibility there.
    PablaP 1 Reply Last reply
      @toggledbits Will try creating a new Hass install and see if I can get MSR to work. In terms of the existing config, none of the entities will get auto deleted since the controller is offline right? Also if I clear out he Hass config completely from MSR, restart MSR then reconfigure as if its the first time entering a Hass config in will this overwrite all my existing Hass entities?
        Just use a different ID for the new HassController instance... so if you had id: hass in the first config, use hass2 in the second.
        It probably won't matter anyway, as the IDs should be stable... the new entities would have the same IDs as the old, be of the same type, etc.
          @toggledbits Just quickly set up a new Hass VM and am seeing the same errors. Tried with both ignore_cert: true and false no luck. This seems to be a VMware issue, I did do look through settings but couldn't really see anything that would stop MSR from connecting.
            To be specific, you need to try ws:// (ignore_cert does not matter for this case), and wss:// with ignore_cert: true. Both cases.
            Beyond that, I'm at a loss. Are you running Hass in docker? Are you running Reactor in docker? I'd look at all of that, too...
              @toggledbits Neither are running in docker, both run on their own VM on the same host. Just the difference now is Reactor is running on a VirutalBox VM and MSR is on a VMware VM
                @pabla said in MSR Not Recognizing Old HASS on New VM:
                Huh?
                  Huh?
                  @toggledbit Lol whoops meant to say MSR is running on a VirtualBox VM and Hass is running on a WMware VM
                    So did a little research and it looks like Websocket is not supported in VMware workstation 16.. I just bought an ODROID cause I am tired of tinkering with all these issues I have had with VMs
                      Just to close this thread up, it was a VMware issue as stated above. Moved over to an ODROID and MSR connected no problem.
                        164.4k
