  4. MSR Not Recognizing Old HASS on New VM
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
20 Posts 2 Posters 3.3k Views 2 Watching
    Try adding ignore_cert: true in the config section for HassController (after source and same indent level). You may additionally need to change the ws:// in the source to wss://. If that works, SSL/TLS is enabled in Hass and you are on a self-signed or invalid certificate (but no changes to Hass needed).
    Also, if your Hass http component configuration has ssl_certificate then SSL/TLS is enabled. That's another way to tell.
    PablaP 1 Reply Last reply
      wrote on last edited by Pabla
      @toggledbits tried setting ignore_cert: true and this is what came up in the logs tried both ws:// and wss//. I do not have the http component in my HA config file
      [latest-22258]2022-09-21T02:52:29.492Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:52:29.493Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:53:29.501Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:53:29.502Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:54:29.507Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:54:29.509Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:55:29.519Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:55:29.519Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:56:21.052Z <VeraController:INFO> VeraController#vera 0 dead entities older than 86400000s purged
      [latest-22258]2022-09-21T02:56:29.528Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:56:29.529Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:57:29.530Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.8.113:8123/api/websocket
      [latest-22258]2022-09-21T02:57:29.531Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [TypeError]TypeError [ERR_INVALID_PROTOCOL]: Protocol "http:" not supported. Expected "https:"
      [latest-22258]2022-09-21T02:58:20.106Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) starting evaluation; because timer-trigger Timer#rule-grpqldnna5
      [latest-22258]2022-09-21T02:58:20.107Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) evaluated; rule state transition from RESET to SET!
      [latest-22258]2022-09-21T02:58:20.124Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) starting evaluation; because data-changed Data#states:cs-rule-grpqldnna5
      [latest-22258]2022-09-21T02:58:20.124Z <Rule:INFO> "10 Min Light Polling" (Rule#rule-grpqldnna5) evaluation complete
      [latest-22258]2022-09-21T02:58:20.125Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) evaluated; trigger state unchanged (false); rule state remains RESET
      [latest-22258]2022-09-21T02:58:20.126Z <Rule:INFO> "45 Min Light Polling" (Rule#rule-l6whyfqd) evaluation complete
      [latest-22258]2022-09-21T02:58:20.126Z <Engine:INFO> Enqueueing ""10 Min Light Polling<SET>"" (rule-grpqldnna5:S)
      [latest-22258]2022-09-21T02:58:20.139Z <Engine:NOTICE> Starting reaction "10 Min Light Polling<SET>" (rule-grpqldnna5:S)
      [latest-22258]2022-09-21T02:58:20.140Z <HassController:null> HassController#hass: sending payload for x_hass_system.call_service on System#hass>system action: [Object]{ "type": "call_service", "service_data": { "entity_id": "light.island_lights" }, "domain": "zwave_js", "service": "refresh_value" }
      [latest-22258]2022-09-21T02:58:20.141Z <HassController:ERR> HassController#hass request 1663729100140<2022-09-20, 7:58:20 p.m.> (call_service) failed: [Error]Error: WebSocket not connected
      [latest-22258]2022-09-21T02:58:20.143Z <Engine:INFO> Resuming reaction "10 Min Light Polling<SET>" (rule-grpqldnna5:S) from step 1"
      Not sure if this is useful but here are some logs pertaining to web socket from HA Supervisor
      22-09-20 19:39:48 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
      22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
      22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_vscode
      22-09-20 19:58:33 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
      22-09-20 19:58:38 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
        The log snippet shows the ws:// result but no wss:// result. I'd like to see that, because it's probably a different message and maybe more useful. The messages you are showing clearly indicate it wants you to use wss://.
          @toggledbits logs attached using wss://
          [latest-22258]2022-09-21T02:38:34.723Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:38:34.723Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:38:34.723Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:38:39.737Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:38:54.745Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:38:54.745Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:38:54.746Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:38:59.748Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:39:14.751Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:39:14.752Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:39:14.752Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:39:19.759Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:39:28.763Z <VeraController:INFO> VeraController#vera 0 dead entities older than 86400000s purged
          [latest-22258]2022-09-21T02:39:34.765Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:39:34.765Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:39:34.765Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:39:39.771Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:39:54.776Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:39:54.777Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:39:54.777Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:40:04.779Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:40:19.786Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:40:19.787Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:40:19.788Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:40:34.791Z <HassController:NOTICE> HassController#hass connecting to wss://192.168.8.113:8123/api/websocket
          [latest-22258]2022-09-21T02:40:49.796Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:40:49.797Z <HassController:NOTICE> HassController#hass websocket to wss://192.168.8.113:8123/api/websocket closed during open/negotiation
          [latest-22258]2022-09-21T02:40:49.798Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error]Error: Opening handshake has timed out
          [latest-22258]2022-09-21T02:41:00.728Z <Rule:INFO> Inside Light Polling (Rule#rule-grpqlebtkk) starting evaluation; because timer-trigger Timer#rule-grpqlebtkk
            And that's also with ignore_cert: true, correct?
              @toggledbits correct
                OK. All I can suggest at this point is that maybe you have the old IP address of the previous system in Hass' configuration somewhere and it's messing things up. Beyond that, I'm out of ideas. Maybe shut down that VM, create a new one, install Hass fresh and clean without restoring the prior configuration, just use a default configuration, and see if you can connect to it. If you can, it's definitely something in the old config/restored install. If you can't, maybe something in the VM configuration... I don't know. This usually isn't much of a challenge, and HassController isn't doing anything tricky, it uses a standard Websocket library in wide use for its connections, so I'm doubtful there's suddenly some bug or incompatibility there.
                  @toggledbits Will try creating a new Hass install and see if I can get MSR to work. In terms of the existing config, none of the entities will get auto deleted since the controller is offline right? Also if I clear out he Hass config completely from MSR, restart MSR then reconfigure as if its the first time entering a Hass config in will this overwrite all my existing Hass entities?
                    Just use a different ID for the new HassController instance... so if you had id: hass in the first config, use hass2 in the second.
                    It probably won't matter anyway, as the IDs should be stable... the new entities would have the same IDs as the old, be of the same type, etc.
                      @toggledbits Just quickly set up a new Hass VM and am seeing the same errors. Tried with both ignore_cert: true and false no luck. This seems to be a VMware issue, I did do look through settings but couldn't really see anything that would stop MSR from connecting.
                        To be specific, you need to try ws:// (ignore_cert does not matter for this case), and wss:// with ignore_cert: true. Both cases.
                        Beyond that, I'm at a loss. Are you running Hass in docker? Are you running Reactor in docker? I'd look at all of that, too...
                          @toggledbits Neither are running in docker, both run on their own VM on the same host. Just the difference now is Reactor is running on a VirutalBox VM and MSR is on a VMware VM
                            @pabla said in MSR Not Recognizing Old HASS on New VM:
                            Huh?
                              Huh?
                              @toggledbit Lol whoops meant to say MSR is running on a VirtualBox VM and Hass is running on a WMware VM
                                So did a little research and it looks like Websocket is not supported in VMware workstation 16.. I just bought an ODROID cause I am tired of tinkering with all these issues I have had with VMs
                                  Just to close this thread up, it was a VMware issue as stated above. Moved over to an ODROID and MSR connected no problem.
                                    164.4k
