  4. [Resolved] Determining if button is pushed
5 Posts 3 Posters 1.1k Views 3 Watching
  • 3 Offline
    3 Offline
    MSR latest-23010-7dd2c9e9 in a Docker image
    HE C7 hub on 2.3.4.130
    I'm trying to determine how to sense that a button has actually been pushed. I added a ThirdReality button to my hub and the current states don't release or reset after a function has been done. I/E: when I push the button, it sets the "pushed" state to 1. Same for all the other functions, double tap, hold, release. Nothing ever goes back to 0 or cleared out.
    If I write my trigger as when "button.pushed" == 1, the current value is already one and the rule stays true all the time. What I'm after is when the button is pushed, the action will toggle the light I want to control.
    I feel like I am missing something or maybe the States of the button are the issue. I can use Rule Machine in my HE and it sees the button as pushed, or held. But I would prefer to have all my logic in MSR.
    And for some reason, I cannot post images. The server keeps giving me a parsing error.
    • 3 Offline
      3 Offline
      Image of Trigger:
      https://www.mediafire.com/view/5t8ow66b7df1qqn/trigger.jpg/file
      Image of Entity:
      https://www.mediafire.com/view/b8q0a6aconesm27/entity.jpg/file
      S toggledbitsT 2 Replies Last reply
      • 3 3rdStng
        Image of Trigger:
        Image of Entity:
        @3rdStng I do not have the same device but I had to overcome this with my minimotes. Have you tried to set the x_hubitat_pushableButton.push back to 0 after your intended reaction. I cannot post images either for some reason or I would post an image of my Rule.
        3 1 Reply Last reply
        • 3 3rdStng
          Image of Trigger:
          Image of Entity:
          @3rdStng the button capability has a 'since' value. You add a condition to sense when it changes.
          • S SweetGenius
            3 Offline
            3 Offline
            @SweetGenius Thank you for the screenshot. I was trying to see if there was a way to "set" the value back to zero. I didn't even think about pushing button zero in my actions.
              162.3k
