  4. Home Assistant add-on
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
30 Posts 7 Posters 10.3k Views 8 Watching
    mrw298
    I've done a bit of repackaging of MSR to make it work as an add-on under Home Assistant mostly for my own purposes but hopefully it makes it a bit easier to install and get going.
    GitHub - mrw298/hassio-reactor-addon
    Contribute to mrw298/hassio-reactor-addon development by creating an account on GitHub.
      RogerO
      Excellent, was hoping it would eventually come to HA. Will you be adding update instructions at some point?
        mrw298
        I'll nudge it along as updates to the MSR docker container are released, it's all using the HA addon framework so it should prompt you automatically to update the addon when an update is available.
        • F Offline
          I followed the link and installed the repo, but it's not showing up in HA. All other custom repos are visible, but not this one. Do you know why?
          M 1 Reply Last reply
          • F Fanan
            mrw298
            @Fanan I introduced a bug into the addon config when I added the other architectures, should be sorted now.
            F 1 Reply Last reply
            • M mrw298
              @mrw298 Thank you. It's now visible. Second problem... I'm running MSR under portainer in HA - so my MSR is on the same device (Home Assistant Blue) as HA. When I try to start your addon, after inserting the long lived access token, I get a error, because the port (8111) is already taken, by MSR:
              2c61d208-1e5b-408e-b15f-38963d55cbd2-image.png Is this obsticle even possible to overcome?
              Best regards,
                mrw298
                @Fanan i can’t think of an easy way in the add on framework. Might be easiest to change your published port for your existing instance in portainer (assuming you’re not using host networking)
                  wrote on last edited by Pabla
                  @Fanan changing the port for one of the MSR instances should fix your issue. Great work @mrw298 i may eventually run MSR on HA
                    Sorry if I'm being dense here this morning - this is to link an existing MSR installation to HA vs having to manually create the long-lived key and manually update configs?
                    *Hubitat C-7 2.5.0.135
                    Core 2026.5.0
                    MSR: latest-26127-726206dd
                      RogerO
                      @gwp1 If I understand your question correctly, this is to allow you to run MSR as a component of your HASS installation on the same hardware.
                      @mrw298 Does this contain the addons such as MQTT and zwavejs?
                      • R RogerO
                        @RogerO Yes, I believe you understand the ask. I already have HA and MSR on sep RPi's, linked via config, and even shared MSR within a HA dashboard. Was looking to see if this streamlined any of that but it sounds like it's not something I would need.
                        Core 2026.5.0
                        PablaP 1 Reply Last reply
                          @gwp1 It makes MSR more accessible for HA users since you won't need a second piece of HW to run MSR on if you are running HassOS
                            RogerO
                            Hello,
                            Trying to install this and getting the following in the logs:
                            2023-02-07 00:26:46,034 INFO exited: reactor (exit status 1; not expected)
                            2023-02-07 00:26:47,044 INFO spawned: 'reactor' with pid 3569
                            Using existing set-up
                            Reactor latest-23028-ddc3fb14 app 22364 configuration from /config/reactor
                            2023-02-07 00:26:48,154 INFO success: reactor entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
                            node:internal/fs/utils:345
                            throw err;
                            Error: ENOENT: no such file or directory, open '/config/reactor/logging.yaml'
                            at Object.openSync (node:fs:585:3)
                            at Object.readFileSync (node:fs:453:35)
                            at Function.loadConfig (/opt/reactor/server/lib/Configuration.js:226:68)
                            at Function.getInstance (/opt/reactor/server/lib/Configuration.js:144:66)
                            at Object.<anonymous> (/opt/reactor/app.js:105:97)
                            at Module._compile (node:internal/modules/cjs/loader:1105:14)
                            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
                            errno: -2,
                            syscall: 'open',
                            code: 'ENOENT',
                            path: '/config/reactor/logging.yaml'
                            Looked in the/opt directory and it was empty. Getting a bad gateway error when I try to load the page.
                            Thanks,
                            Roger
                            • R RogerO
                              Hello,
                              throw err;
                              errno: -2,
                              syscall: 'open',
                              code: 'ENOENT',
                              Thanks,
                              Roger
                              mrw298
                              wrote on last edited by mrw298
                              @RogerO somethings a bit odd has gone on. First time the container starts it copies the files from /opt/reactor/dist-config to /config/reactor and does a basic setup.
                              You should be able to stop the container, delete the /config/reactor directory and start it back up again to recreate the config.
                              That does rely on the dist-configs existing and it’s strange that /opt is empty. Do you know which architecture you’re running, perhaps there’s a difference between the images.
                                RogerO
                                Currently running HASSIO on a RPI4
                                Home Assistant 2023.2.2
                                Supervisor 2023.01.1
                                Operating System 9.5
                                Frontend 20230202.0 - latest
                                Uninstalled the addin and deleted the reactor.yaml file. Installed the addin and if choked because it couldn't find yaml file. Using winscp I created one and it will not start. /opt/ is empty.
                                  The /opt directory contents are inside the container and not visible without attaching to the container. I'm not surprised you don't see anything there; it's expected, actually. Beyond that, @mrw298 will need to respond for the add-on.
                                    RogerO
                                    oh yeah, forgot that part.
                                      RogerO
                                      @mrw298 Anything I can do to help you troubleshoot or do you have any ideas on how to get this resolved?
                                        RogerO
                                        Here is a file list from the container, Sorry that it is a screen shot. Don't want to f up my system by typing something stupid and not a docker expert. If there is a specific directory you want me to look at let me know
                                        Still getting 502 bad gateway from nginx
                                        • K Offline
                                          K Offline
                                          kellyjelly32
                                          I am using the addon for HA, running excellent.
                                          Finally my dream came true, using the excellent reactor engine to automate all my devices, mix and match rules and technologies.
                                          Will offload now finally from my rusty Vera Lite to HA...
                                          Two things: I keep getting the "reminder" to enter the last four digits despite having done it multiple times.
                                          Can I safely update MSR from within the addon or do I need to wait for an update to the addon?
                                            101.4k
                                          • Next Release?
