  4. Home Assistant add-on
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
30 Posts 7 Posters 15.8k Views 8 Watching
    wrote on last edited by Pabla
    @Fanan changing the port for one of the MSR instances should fix your issue. Great work @mrw298 i may eventually run MSR on HA
      Sorry if I'm being dense here this morning - this is to link an existing MSR installation to HA vs having to manually create the long-lived key and manually update configs?
        RogerO
        @gwp1 If I understand your question correctly, this is to allow you to run MSR as a component of your HASS installation on the same hardware.
        @mrw298 Does this contain the addons such as MQTT and zwavejs?
        • R RogerO
          @RogerO Yes, I believe you understand the ask. I already have HA and MSR on sep RPi's, linked via config, and even shared MSR within a HA dashboard. Was looking to see if this streamlined any of that but it sounds like it's not something I would need.
          PablaP 1 Reply Last reply
            @gwp1 It makes MSR more accessible for HA users since you won't need a second piece of HW to run MSR on if you are running HassOS
              RogerO
              Hello,
              Trying to install this and getting the following in the logs:
              2023-02-07 00:26:46,034 INFO exited: reactor (exit status 1; not expected)
              2023-02-07 00:26:47,044 INFO spawned: 'reactor' with pid 3569
              Using existing set-up
              Reactor latest-23028-ddc3fb14 app 22364 configuration from /config/reactor
              2023-02-07 00:26:48,154 INFO success: reactor entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
              node:internal/fs/utils:345
              throw err;
              Error: ENOENT: no such file or directory, open '/config/reactor/logging.yaml'
              at Object.openSync (node:fs:585:3)
              at Object.readFileSync (node:fs:453:35)
              at Function.loadConfig (/opt/reactor/server/lib/Configuration.js:226:68)
              at Function.getInstance (/opt/reactor/server/lib/Configuration.js:144:66)
              at Object.<anonymous> (/opt/reactor/app.js:105:97)
              at Module._compile (node:internal/modules/cjs/loader:1105:14)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
              errno: -2,
              syscall: 'open',
              code: 'ENOENT',
              path: '/config/reactor/logging.yaml'
              Looked in the/opt directory and it was empty. Getting a bad gateway error when I try to load the page.
              Thanks,
              Roger
              M 1 Reply Last reply
              • R RogerO
                Hello,
                throw err;
                errno: -2,
                syscall: 'open',
                code: 'ENOENT',
                Thanks,
                Roger
                mrw298
                wrote on last edited by mrw298
                @RogerO somethings a bit odd has gone on. First time the container starts it copies the files from /opt/reactor/dist-config to /config/reactor and does a basic setup.
                You should be able to stop the container, delete the /config/reactor directory and start it back up again to recreate the config.
                That does rely on the dist-configs existing and it’s strange that /opt is empty. Do you know which architecture you’re running, perhaps there’s a difference between the images.
                  RogerO
                  Currently running HASSIO on a RPI4
                  Home Assistant 2023.2.2
                  Supervisor 2023.01.1
                  Operating System 9.5
                  Frontend 20230202.0 - latest
                  Uninstalled the addin and deleted the reactor.yaml file. Installed the addin and if choked because it couldn't find yaml file. Using winscp I created one and it will not start. /opt/ is empty.
                    The /opt directory contents are inside the container and not visible without attaching to the container. I'm not surprised you don't see anything there; it's expected, actually. Beyond that, @mrw298 will need to respond for the add-on.
                      RogerO
                      oh yeah, forgot that part.
                        RogerO
                        @mrw298 Anything I can do to help you troubleshoot or do you have any ideas on how to get this resolved?
                          RogerO
                          Here is a file list from the container, Sorry that it is a screen shot. Don't want to f up my system by typing something stupid and not a docker expert. If there is a specific directory you want me to look at let me know
                          Still getting 502 bad gateway from nginx
                          • K Offline
                            K Offline
                            kellyjelly32
                            I am using the addon for HA, running excellent.
                            Finally my dream came true, using the excellent reactor engine to automate all my devices, mix and match rules and technologies.
                            Will offload now finally from my rusty Vera Lite to HA...
                            Two things: I keep getting the "reminder" to enter the last four digits despite having done it multiple times.
                            Can I safely update MSR from within the addon or do I need to wait for an update to the addon?
                            • K kellyjelly32
                              #21
                              @kellyjelly32 said in Home Assistant add-on:
                              Off the top of my head, it sounds like you may not be entering it correctly? They aren't just digits, usually. Check to make sure your browser settings to allow cookies. Also generally, if you're reporting a problem like this, you should include the version information for the browser you are running, and in fact, you should go review the posting guidelines for this category because your post generally doesn't meet the requirements. This question should be separate from your other question in its own thread, also.
                              K 1 Reply Last reply
                                K Offline
                                K Offline
                                kellyjelly32
                                I am running the addon in v0.0.7 (2023-02-20) [which is using Reactor build 23049 as per changelog] with:
                                Home Assistant 2023.3.1
                                Supervisor 2023.03.1
                                Frontend 20230302.0 - latest
                                I was more trying to reach @mrw298 as he is the creator of the addon. Judging from the changelog, I can´t update MSR that simple and need to wait for a new version of his addon to be pushed.
                                The reminder pops up in any browser I tried so far, probably because it can´t really create a cookie. It even pops up in the HA mobile app. But I think the reactor front-end was never designed to run in such an environment. It is a minor cosmetic nuisance.
                                  mrw298
                                  @kellyjelly32 I sometimes lag a bit behind @toggledbits packaging it up for HA (especially if I don't notice a new version), I've just pushed a new version of the addon with Reactor build 23063 in it.
                                  I've noticed that prompt coming back too, it's probably something to do with how I've wedged reactor into an HA addon, will see if I can figure out what needs tweaking to make it go away.
                                  • R RogerO
                                    mrw298
                                    @RogerO sorry for the delay responding, if the files are in dist-config I'm not quite certain how it's going wrong!
                                    On startup it copies those files from /opt/reactor/dist-config -> /config/reactor if the /config/reactor directory doesn't exist.
                                    hassio-reactor-addon/reactor/run.sh at main · mrw298/hassio-reactor-addon
                                    Contribute to mrw298/hassio-reactor-addon development by creating an account on GitHub.
                                    If it can't find logging.yaml that steps failed and stopping the addon, deleting /config/reactor and restarting it should get it to retry.
                                    The addon logs of that first start would hopefully contain any error messages.
                                    • K Offline
                                      K Offline
                                      kellyjelly32
                                      After doing some tinkering again this weekend on my HA real-life system, I noticed that the "global expressions" are not persistent when rebooting / restarting the MSR addon for HA. "global reactions" survive a reboot, as do all the rules (with their reactions / untested with local expressions). Ultimately it is probably an issue with the addon, not with MSR. Just want to see/hear from @toggledbits if there is something special about how the global expressions are saved vs the other stuff.
                                      • K kellyjelly32
                                        Not sure what this means. Can you explain in more detail?
                                        Reactions are stateless. There's no need for them to "survive a reboot" because there's nothing to survive. Again, not sure what this means, and detail would be helpful.
                                        • K Offline
                                          K Offline
                                          kellyjelly32
                                          "Global Expressions" aka those things you can define and use for variables and calculations don't survive a reboot. After a reboot they are gone. The whole page with global variables is empty. I need to define them again. All rules which use one of these "global expressions" have a little yellow warning triangle and in the rule, be it conditions or actions or reactions, they are stated as "missing".
                                          As my system usually runs extremely stable I never noticed it as it never rebooted. Until this weekend when I physically had to shut it down and reboot a few times.
                                          I think it is a HA addon issue from @mrw298 not from MSR itself.
                                            163.1k
