  4. Home Assistant add-on
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
30 Posts 7 Posters 15.9k Views 8 Watching
    mrw298
    I've done a bit of repackaging of MSR to make it work as an add-on under Home Assistant mostly for my own purposes but hopefully it makes it a bit easier to install and get going.
    GitHub - mrw298/hassio-reactor-addon
    Contribute to mrw298/hassio-reactor-addon development by creating an account on GitHub.
      RogerO
      Excellent, was hoping it would eventually come to HA. Will you be adding update instructions at some point?
        mrw298
        I'll nudge it along as updates to the MSR docker container are released, it's all using the HA addon framework so it should prompt you automatically to update the addon when an update is available.
        • F Offline
          I followed the link and installed the repo, but it's not showing up in HA. All other custom repos are visible, but not this one. Do you know why?
          M 1 Reply Last reply
          • F Fanan
            mrw298
            @Fanan I introduced a bug into the addon config when I added the other architectures, should be sorted now.
            F 1 Reply Last reply
            • M mrw298
              @mrw298 Thank you. It's now visible. Second problem... I'm running MSR under portainer in HA - so my MSR is on the same device (Home Assistant Blue) as HA. When I try to start your addon, after inserting the long lived access token, I get a error, because the port (8111) is already taken, by MSR:
              2c61d208-1e5b-408e-b15f-38963d55cbd2-image.png Is this obsticle even possible to overcome?
              Best regards,
                mrw298
                @Fanan i can’t think of an easy way in the add on framework. Might be easiest to change your published port for your existing instance in portainer (assuming you’re not using host networking)
                  wrote on last edited by Pabla
                  @Fanan changing the port for one of the MSR instances should fix your issue. Great work @mrw298 i may eventually run MSR on HA
                    Sorry if I'm being dense here this morning - this is to link an existing MSR installation to HA vs having to manually create the long-lived key and manually update configs?
                      RogerO
                      @gwp1 If I understand your question correctly, this is to allow you to run MSR as a component of your HASS installation on the same hardware.
                      @mrw298 Does this contain the addons such as MQTT and zwavejs?
                      • R RogerO
                        @RogerO Yes, I believe you understand the ask. I already have HA and MSR on sep RPi's, linked via config, and even shared MSR within a HA dashboard. Was looking to see if this streamlined any of that but it sounds like it's not something I would need.
                        PablaP 1 Reply Last reply
                          @gwp1 It makes MSR more accessible for HA users since you won't need a second piece of HW to run MSR on if you are running HassOS
                            RogerO
                            Hello,
                            Trying to install this and getting the following in the logs:
                            2023-02-07 00:26:46,034 INFO exited: reactor (exit status 1; not expected)
                            2023-02-07 00:26:47,044 INFO spawned: 'reactor' with pid 3569
                            Using existing set-up
                            Reactor latest-23028-ddc3fb14 app 22364 configuration from /config/reactor
                            2023-02-07 00:26:48,154 INFO success: reactor entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
                            node:internal/fs/utils:345
                            throw err;
                            Error: ENOENT: no such file or directory, open '/config/reactor/logging.yaml'
                            at Object.openSync (node:fs:585:3)
                            at Object.readFileSync (node:fs:453:35)
                            at Function.loadConfig (/opt/reactor/server/lib/Configuration.js:226:68)
                            at Function.getInstance (/opt/reactor/server/lib/Configuration.js:144:66)
                            at Object.<anonymous> (/opt/reactor/app.js:105:97)
                            at Module._compile (node:internal/modules/cjs/loader:1105:14)
                            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
                            errno: -2,
                            syscall: 'open',
                            code: 'ENOENT',
                            path: '/config/reactor/logging.yaml'
                            Looked in the/opt directory and it was empty. Getting a bad gateway error when I try to load the page.
                            Thanks,
                            Roger
                            • R RogerO
                              Hello,
                              throw err;
                              errno: -2,
                              syscall: 'open',
                              code: 'ENOENT',
                              Thanks,
                              Roger
                              mrw298
                              wrote on last edited by mrw298
                              @RogerO somethings a bit odd has gone on. First time the container starts it copies the files from /opt/reactor/dist-config to /config/reactor and does a basic setup.
                              You should be able to stop the container, delete the /config/reactor directory and start it back up again to recreate the config.
                              That does rely on the dist-configs existing and it’s strange that /opt is empty. Do you know which architecture you’re running, perhaps there’s a difference between the images.
                                RogerO
                                Currently running HASSIO on a RPI4
                                Home Assistant 2023.2.2
                                Supervisor 2023.01.1
                                Operating System 9.5
                                Frontend 20230202.0 - latest
                                Uninstalled the addin and deleted the reactor.yaml file. Installed the addin and if choked because it couldn't find yaml file. Using winscp I created one and it will not start. /opt/ is empty.
                                • toggledbitsT Online
                                  toggledbitsT Online
                                  The /opt directory contents are inside the container and not visible without attaching to the container. I'm not surprised you don't see anything there; it's expected, actually. Beyond that, @mrw298 will need to respond for the add-on.
                                    RogerO
                                    oh yeah, forgot that part.
                                      RogerO
                                      @mrw298 Anything I can do to help you troubleshoot or do you have any ideas on how to get this resolved?
                                        RogerO
                                        Here is a file list from the container, Sorry that it is a screen shot. Don't want to f up my system by typing something stupid and not a docker expert. If there is a specific directory you want me to look at let me know
                                        Still getting 502 bad gateway from nginx
                                        • K Offline
                                          K Offline
                                          kellyjelly32
                                          I am using the addon for HA, running excellent.
                                          Finally my dream came true, using the excellent reactor engine to automate all my devices, mix and match rules and technologies.
                                          Will offload now finally from my rusty Vera Lite to HA...
                                          Two things: I keep getting the "reminder" to enter the last four digits despite having done it multiple times.
                                          Can I safely update MSR from within the addon or do I need to wait for an update to the addon?
                                            164.0k
