  4. Sending numbers as payload type in actions enhancement
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
4 Posts 2 Posters 619 Views 2 Watching
  • J Offline
    J Offline
    jouke
    wrote on last edited by jouke
    I'm controlling a HVAC device through the MQTTController. While setting up the entity config in reactor.yaml, I started with this on the action block:
                  set_setpoint:
                    topic: "ezlo_mqtt/set/item/%topic%/set/Tsetpoint"
                    payload:
                      expr: "parameters.setpoint"
                      type: raw
    However, as the setpoint is a number in the UI, things were not fully parseable as a number and nothing was outputted to mqtt.
    So I've added this code to MQTTController.js at line 1449 to add the payload type 'number':
                } else if ( 'number' === act.payload.type ) {
                    payload = String( payload );
                } else if (''raw' !== ( act.payload.type || 'raw' ) ) {
    After this change, I was able to set the payload type to number:
                  set_setpoint:
                    payload:
                      type: number
    And things worked as intended, being able to send numbers in the actions bit of a rule set.
      You can just send it raw, which has the same effect as your (unnecessary) code addition. In fact, you can just send it JSON, too, since a JSON-ified number is just the number as a string, same-same. Alternately, you can also use:
          payload:
            expr: "str(parameters.setpoint)"
      • J Offline
        J Offline
        jouke
        I was expecting raw to work, however using raw throws an error in my reactor.log file:
        [stable-23078]2023-05-16T11:27:22.250Z <MQTTController:WARN> expression has run, result 20
        [stable-23078]2023-05-16T11:27:22.250Z <MQTTController:INFO> MQTTController#mqtt perform hvac_cooling_unit.set_setpoint on MHI_AC_1: publishing ezlo_mqtt/set/item/MHI-AC-Woonkamer/set/Tsetpoint 20
        [stable-23078]2023-05-16T11:27:22.254Z <wsapi:CRIT> TypeError: The "string" argument must be of type string or an instance of Buffer or ArrayBuffer. Received type number (20) [-]
        TypeError [ERR_INVALID_ARG_TYPE]: The "string" argument must be of type string or an instance of Buffer or ArrayBuffer. Received type number (20)
            at new NodeError (node:internal/errors:372:5)
            at Function.byteLength (node:buffer:735:11)
            at publish (/var/reactor/ext/MQTTController/node_modules/mqtt-packet/writeToStream.js:334:51)
            at Object.generate [as writeToStream] (/var/reactor/ext/MQTTController/node_modules/mqtt-packet/writeToStream.js:34:14)
            at sendPacket (/var/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:176:29)
            at MqttClient._sendPacket (/var/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:1250:7)
            at publishProc (/var/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:659:14)
            at MqttClient.publish (/var/reactor/ext/MQTTController/node_modules/mqtt/lib/client.js:665:74)
            at /var/reactor/ext/MQTTController/MQTTController.js:616:25
            at new Promise (<anonymous>)
        As you can see, I try to publish the raw value 20 to topic ezlo/.../Tsetpoint which fails as the number is not a string (so far for untyped behaviour of js..)
        Both your alternatives, using json or raw with the str() expression work flawlessly. I'll remove my unneeded changes in the code!
          OK. I can address the error message. Best of both worlds.
            98.0k
          • Next Release?
            1.0k
