  4. Reactor Update Shell Script *Use at your Own Risk*
6 Posts 3 Posters 1.4k Views 3 Watching
    wrote on last edited by Pabla
    Hello all, just thought I'd share my shells script I created to streamline the update process for MSR. Please use this at your own risk.
    Here's what you gotta put into your .sh file:
    #!/bin/bash
    sudo cp -r {path_to_reactor_folder} {path_to_backup_location}-$(date +'%Y_%m_%d_%H:%M')
    FILE=$(find {path_to_directory_above_reactor_folder} -maxdepth 1 -type f)
    sudo systemctl stop reactor
    sleep 5s
    cd {path_to_directory_above_reactor_folder}
    tar xzvf $FILE
    sleep 30s
    sudo find {path_to_reactor_folder} -name "package-lock.json" -delete
    sleep 10s
    cd {path_to_reactor_filder}
    npm run deps
    sleep 30s
    sudo systemctl restart reactor
    The only requirement is that you have drop the updated Reactor .tar.gz file in the directory above your Reactor folder and then run the script. Once that is done run the script you created above (remember to update the paths) and everything should take care of itself. I added the sleep command in a few lines but don't think it's needed.
    Edit: I also added in the first line of the script a copy command. This will backup your reactor directory to whatever location you'd like and also name it with the date and time. I have my NAS mounted so that is where reactor gets backed up to. Ideally you'd want to backup your Reactor directly off-site just in case your RPi craps out.
      This is very similar to a cheat sheet I keep handy. However, I ran into this:
      gzip: stdin: not in gzip format
      tar: Child returned status 1
      tar: Error is not recoverable: exiting now
      *Hubitat C-7 2.5.2.135
      Core 2026.10.1
      MSR: latest-26287-0a7107d5
      PablaP 1 Reply Last reply
        @gwp1 Where are you placing the Reactor update tar.gz file?
          If you use $1 instead of $FILE in the script the path to the Reactor build could just be given on the command line and the script won't have to assume/enforce a location.
            @Pabla Folder that contains the reactor folder, ie "folder above".
            Core 2026.10.1
              @gwp1 If your reactor folder is /home/user/documents/reactor your tar.gz file should be in home/user/documents. But thats not what the error is showing, looks like the Reactor update file isn't in .gz compressed format, I know with certain browsers like Safari they will auto decompress downloaded files.
                146.6k
