  4. TypeError: Cannot set properties of undefined (setting '__suppress_dependencies') when setting variables
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
13 Posts 3 Posters 1.4k Views 3 Watching
    I've just updated to 23218 and now I'm getting this:
    There seems to be related to global variables. The first and last ones are global reactions, while the second is a normal one. All are setting global variables.
      I forgot to @mention @toggledbits. No changes on my part, just an update of MSR.
        @therealdb @toggledbits I'm seeing the same for API calls that write to global expressions.
        *Hubitat C-7 2.4.3.177
        Core 2026.1.1
        MSR: latest-26011-c621bbc7
          I need to see log snippets, please.
            @toggledbits said in TypeError: Cannot set properties of undefined (setting '__suppress_dependencies') when setting variables:
            I rolled back as I was heading out the door. I'll try Monday to redeploy and grab some logs if @therealdb hasn't done so already.
            Core 2026.1.1
              @toggledbits Reference the Ambient API poll.
              [latest-23218]2023-08-07T04:05:00.003Z <Rule:WARN> Predicate#rule-ktha6jsp/trig cond condd5k394j interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.003Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.004Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.029Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.030Z <Engine:INFO> Enqueueing "API poll Ambient<SET>" (rule-ktha6jsp:S)
              [latest-23218]2023-08-07T04:05:00.033Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because timer-trigger Timer#rule-l2gdh04j
              [latest-23218]2023-08-07T04:05:00.034Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.035Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.059Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
              [latest-23218]2023-08-07T04:05:00.061Z <Engine:INFO> Enqueueing "The Internet is up<SET>" (rule-l2gdh04j:S)
              [latest-23218]2023-08-07T04:05:00.063Z <Engine:NOTICE> Starting reaction API poll Ambient<SET> (rule-ktha6jsp:S)
              [latest-23218]2023-08-07T04:05:00.065Z <Engine:INFO> API poll Ambient<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.082Z <Engine:NOTICE> Starting reaction The Internet is up<SET> (rule-l2gdh04j:S)
              [latest-23218]2023-08-07T04:05:00.086Z <Engine:INFO> Enqueueing "API - Ambient API poll" (re-l5se4iyv)
              [latest-23218]2023-08-07T04:05:00.088Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because timer-trigger Timer#rule-l2f9yuad
              [latest-23218]2023-08-07T04:05:00.089Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
              [latest-23218]2023-08-07T04:05:00.089Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23218]2023-08-07T04:05:00.090Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
              [latest-23218]2023-08-07T04:05:00.091Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) starting evaluation; because timer-trigger Timer#rule-kve17jsm
              [latest-23218]2023-08-07T04:05:00.092Z <Rule:WARN> Predicate#rule-kve17jsm/trig cond condf2b4k3i interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.092Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.093Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.107Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.108Z <Engine:INFO> Enqueueing "API poll OpenWxMap<SET>" (rule-kve17jsm:S)
              [latest-23218]2023-08-07T04:05:00.109Z <Engine:NOTICE> Starting reaction API - Ambient API poll (re-l5se4iyv)
              [latest-23218]2023-08-07T04:05:00.117Z <Engine:NOTICE> Starting reaction API poll OpenWxMap<SET> (rule-kve17jsm:S)
              [latest-23218]2023-08-07T04:05:00.117Z <Engine:INFO> API poll OpenWxMap<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.134Z <Engine:INFO> Enqueueing "API - OpenWxMap API poll" (re-l5selx6n)
              [latest-23218]2023-08-07T04:05:00.137Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) starting evaluation; because timer-trigger Timer#rule-l1hyybyj
              [latest-23218]2023-08-07T04:05:00.137Z <Rule:WARN> Predicate#rule-l1hyybyj/trig cond condd5k394j interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.138Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.138Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.152Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.154Z <Engine:INFO> Enqueueing "API poll Visual Crossing<SET>" (rule-l1hyybyj:S)
              [latest-23218]2023-08-07T04:05:00.155Z <Engine:NOTICE> Starting reaction API - OpenWxMap API poll (re-l5selx6n)
              [latest-23218]2023-08-07T04:05:00.157Z <Engine:NOTICE> Starting reaction API poll Visual Crossing<SET> (rule-l1hyybyj:S)
              [latest-23218]2023-08-07T04:05:00.158Z <Engine:INFO> API poll Visual Crossing<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.175Z <Engine:INFO> Enqueueing "API - Visual Crossing API poll" (re-l5sebznv)
              [latest-23218]2023-08-07T04:05:00.177Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) starting evaluation; because timer-trigger Timer#rule-ktha6jsp
              [latest-23218]2023-08-07T04:05:00.178Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.178Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.191Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.192Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because timer-trigger Timer#rule-l2gdh04j
              [latest-23218]2023-08-07T04:05:00.193Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.193Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.207Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
              [latest-23218]2023-08-07T04:05:00.207Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because timer-trigger Timer#rule-l2f9yuad
              [latest-23218]2023-08-07T04:05:00.210Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
              [latest-23218]2023-08-07T04:05:00.210Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23218]2023-08-07T04:05:00.211Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
              [latest-23218]2023-08-07T04:05:00.212Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) starting evaluation; because timer-trigger Timer#rule-kve17jsm
              [latest-23218]2023-08-07T04:05:00.213Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.213Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.226Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.227Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) starting evaluation; because timer-trigger Timer#rule-l1hyybyj
              [latest-23218]2023-08-07T04:05:00.227Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.228Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.241Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.242Z <Engine:NOTICE> Starting reaction API - Visual Crossing API poll (re-l5sebznv)
              [latest-23218]2023-08-07T04:05:00.302Z <HubitatController:INFO> HubitatController#hubitat action power_switch.on([Object]{  }) on Switch#hubitat>797 succeeded
              [latest-23218]2023-08-07T04:05:00.303Z <Engine:INFO> Resuming reaction The Internet is up<SET> (rule-l2gdh04j:S) from step 2
              [latest-23218]2023-08-07T04:05:00.304Z <Engine:INFO> The Internet is up<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.324Z <Engine:INFO> Resuming reaction API - OpenWxMap API poll (re-l5selx6n) from step 1
              [latest-23218]2023-08-07T04:05:00.325Z <Engine:INFO> API - OpenWxMap API poll all actions completed.
              [latest-23218]2023-08-07T04:05:00.415Z <Engine:ERR> [Engine]Engine#1 reaction API - Ambient API poll step 0 HTTP request failed to store ambient_api(global): [TypeError] Cannot set properties of undefined (setting '__suppress_dependencies') [-]
              [latest-23218]2023-08-07T04:05:00.427Z <Rule:INFO> Cooling (rule-l2izxacm in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.427Z <Rule:INFO> Cooling Night (rule-l2izx1ej in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.428Z <Rule:INFO> Heating (rule-l2izxgk3 in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.428Z <Rule:INFO> Heating Night (rule-l2izxnnf in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.429Z <Rule:INFO> Retry API poll Ambient retry (rule-l5se2bll in API Wx calls) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.429Z <Rule:INFO> Status Indicator Ambient API  (rule-kve46f7q in API Wx calls) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.430Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23218]2023-08-07T04:05:00.430Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because entity-changed System#reactor_system>system
              Core 2026.1.1
                Can't seem to find any trace in the logs, since hours have passed. It stopped and it seems to work now, after a couple of reboots, so maybe it was something spurious related to the update, IDK.
                UPDATE: not really, it's still failing but logs are similar to the ones reported by @gwp1
                  OK. I think I may have it. I re-spun the release in place, so download new package (or docker image, whichever you use) and try again.
                    @toggledbits Well this is new... two attempts to download result in the file being deleted by MSFT Defender as "contains virus". 🤷♂
                    Core 2026.1.1
                      False pos. I rebuilt and uploaded from same sources. Try again.
                        @toggledbits Yep, successful download. Moving on to deployment in the next few.
                        Core 2026.1.1
                          @toggledbits Looks good, no more errors - thank you for the quick turnaround. @therealdb fyi.
                          Core 2026.1.1
                            Yup, many thanks to @toggledbits for the quick fix!
                              551
                              3.6k
                              3.2k
                              791
