  4. TypeError: Cannot set properties of undefined (setting '__suppress_dependencies') when setting variables
13 Posts 3 Posters 2.2k Views 3 Watching
    I've just updated to 23218 and now I'm getting this:
    There seems to be related to global variables. The first and last ones are global reactions, while the second is a normal one. All are setting global variables.
      I forgot to @mention @toggledbits. No changes on my part, just an update of MSR.
        @therealdb @toggledbits I'm seeing the same for API calls that write to global expressions.
        *Hubitat C-7 2.5.2.135
        Core 2026.10.1
        MSR: latest-26287-0a7107d5
          I need to see log snippets, please.
            @toggledbits said in TypeError: Cannot set properties of undefined (setting '__suppress_dependencies') when setting variables:
            I rolled back as I was heading out the door. I'll try Monday to redeploy and grab some logs if @therealdb hasn't done so already.
            Core 2026.10.1
              @toggledbits Reference the Ambient API poll.
              [latest-23218]2023-08-07T04:05:00.003Z <Rule:WARN> Predicate#rule-ktha6jsp/trig cond condd5k394j interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.003Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.004Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.029Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.030Z <Engine:INFO> Enqueueing "API poll Ambient<SET>" (rule-ktha6jsp:S)
              [latest-23218]2023-08-07T04:05:00.033Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because timer-trigger Timer#rule-l2gdh04j
              [latest-23218]2023-08-07T04:05:00.034Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.035Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.059Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
              [latest-23218]2023-08-07T04:05:00.061Z <Engine:INFO> Enqueueing "The Internet is up<SET>" (rule-l2gdh04j:S)
              [latest-23218]2023-08-07T04:05:00.063Z <Engine:NOTICE> Starting reaction API poll Ambient<SET> (rule-ktha6jsp:S)
              [latest-23218]2023-08-07T04:05:00.065Z <Engine:INFO> API poll Ambient<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.082Z <Engine:NOTICE> Starting reaction The Internet is up<SET> (rule-l2gdh04j:S)
              [latest-23218]2023-08-07T04:05:00.086Z <Engine:INFO> Enqueueing "API - Ambient API poll" (re-l5se4iyv)
              [latest-23218]2023-08-07T04:05:00.088Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because timer-trigger Timer#rule-l2f9yuad
              [latest-23218]2023-08-07T04:05:00.089Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
              [latest-23218]2023-08-07T04:05:00.089Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23218]2023-08-07T04:05:00.090Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
              [latest-23218]2023-08-07T04:05:00.091Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) starting evaluation; because timer-trigger Timer#rule-kve17jsm
              [latest-23218]2023-08-07T04:05:00.092Z <Rule:WARN> Predicate#rule-kve17jsm/trig cond condf2b4k3i interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.092Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.093Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.107Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.108Z <Engine:INFO> Enqueueing "API poll OpenWxMap<SET>" (rule-kve17jsm:S)
              [latest-23218]2023-08-07T04:05:00.109Z <Engine:NOTICE> Starting reaction API - Ambient API poll (re-l5se4iyv)
              [latest-23218]2023-08-07T04:05:00.117Z <Engine:NOTICE> Starting reaction API poll OpenWxMap<SET> (rule-kve17jsm:S)
              [latest-23218]2023-08-07T04:05:00.117Z <Engine:INFO> API poll OpenWxMap<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.134Z <Engine:INFO> Enqueueing "API - OpenWxMap API poll" (re-l5selx6n)
              [latest-23218]2023-08-07T04:05:00.137Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) starting evaluation; because timer-trigger Timer#rule-l1hyybyj
              [latest-23218]2023-08-07T04:05:00.137Z <Rule:WARN> Predicate#rule-l1hyybyj/trig cond condd5k394j interval trigger was delayed 85800s
              [latest-23218]2023-08-07T04:05:00.138Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) trigger evaluation result is true (previously false)
              [latest-23218]2023-08-07T04:05:00.138Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluated; rule state transition from RESET to SET!
              [latest-23218]2023-08-07T04:05:00.152Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.154Z <Engine:INFO> Enqueueing "API poll Visual Crossing<SET>" (rule-l1hyybyj:S)
              [latest-23218]2023-08-07T04:05:00.155Z <Engine:NOTICE> Starting reaction API - OpenWxMap API poll (re-l5selx6n)
              [latest-23218]2023-08-07T04:05:00.157Z <Engine:NOTICE> Starting reaction API poll Visual Crossing<SET> (rule-l1hyybyj:S)
              [latest-23218]2023-08-07T04:05:00.158Z <Engine:INFO> API poll Visual Crossing<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.175Z <Engine:INFO> Enqueueing "API - Visual Crossing API poll" (re-l5sebznv)
              [latest-23218]2023-08-07T04:05:00.177Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) starting evaluation; because timer-trigger Timer#rule-ktha6jsp
              [latest-23218]2023-08-07T04:05:00.178Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.178Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.191Z <Rule:INFO> API poll Ambient (rule-ktha6jsp in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.192Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because timer-trigger Timer#rule-l2gdh04j
              [latest-23218]2023-08-07T04:05:00.193Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.193Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.207Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
              [latest-23218]2023-08-07T04:05:00.207Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because timer-trigger Timer#rule-l2f9yuad
              [latest-23218]2023-08-07T04:05:00.210Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
              [latest-23218]2023-08-07T04:05:00.210Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23218]2023-08-07T04:05:00.211Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
              [latest-23218]2023-08-07T04:05:00.212Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) starting evaluation; because timer-trigger Timer#rule-kve17jsm
              [latest-23218]2023-08-07T04:05:00.213Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.213Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.226Z <Rule:INFO> API poll OpenWxMap (rule-kve17jsm in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.227Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) starting evaluation; because timer-trigger Timer#rule-l1hyybyj
              [latest-23218]2023-08-07T04:05:00.227Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) trigger evaluation result is false (previously true)
              [latest-23218]2023-08-07T04:05:00.228Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluated; rule state transition from SET to RESET!
              [latest-23218]2023-08-07T04:05:00.241Z <Rule:INFO> API poll Visual Crossing (rule-l1hyybyj in API Wx calls) evaluation complete
              [latest-23218]2023-08-07T04:05:00.242Z <Engine:NOTICE> Starting reaction API - Visual Crossing API poll (re-l5sebznv)
              [latest-23218]2023-08-07T04:05:00.302Z <HubitatController:INFO> HubitatController#hubitat action power_switch.on([Object]{  }) on Switch#hubitat>797 succeeded
              [latest-23218]2023-08-07T04:05:00.303Z <Engine:INFO> Resuming reaction The Internet is up<SET> (rule-l2gdh04j:S) from step 2
              [latest-23218]2023-08-07T04:05:00.304Z <Engine:INFO> The Internet is up<SET> all actions completed.
              [latest-23218]2023-08-07T04:05:00.324Z <Engine:INFO> Resuming reaction API - OpenWxMap API poll (re-l5selx6n) from step 1
              [latest-23218]2023-08-07T04:05:00.325Z <Engine:INFO> API - OpenWxMap API poll all actions completed.
              [latest-23218]2023-08-07T04:05:00.415Z <Engine:ERR> [Engine]Engine#1 reaction API - Ambient API poll step 0 HTTP request failed to store ambient_api(global): [TypeError] Cannot set properties of undefined (setting '__suppress_dependencies') [-]
              [latest-23218]2023-08-07T04:05:00.427Z <Rule:INFO> Cooling (rule-l2izxacm in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.427Z <Rule:INFO> Cooling Night (rule-l2izx1ej in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.428Z <Rule:INFO> Heating (rule-l2izxgk3 in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.428Z <Rule:INFO> Heating Night (rule-l2izxnnf in HVAC:  Visual Crossing API) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.429Z <Rule:INFO> Retry API poll Ambient retry (rule-l5se2bll in API Wx calls) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.429Z <Rule:INFO> Status Indicator Ambient API  (rule-kve46f7q in API Wx calls) starting evaluation; because expression-state-changed GlobalExpression#ambient_api
              [latest-23218]2023-08-07T04:05:00.430Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23218]2023-08-07T04:05:00.430Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because entity-changed System#reactor_system>system
              Core 2026.10.1
                Can't seem to find any trace in the logs, since hours have passed. It stopped and it seems to work now, after a couple of reboots, so maybe it was something spurious related to the update, IDK.
                UPDATE: not really, it's still failing but logs are similar to the ones reported by @gwp1
                  OK. I think I may have it. I re-spun the release in place, so download new package (or docker image, whichever you use) and try again.
                    @toggledbits Well this is new... two attempts to download result in the file being deleted by MSFT Defender as "contains virus". 🤷♂
                    Core 2026.10.1
                      False pos. I rebuilt and uploaded from same sources. Try again.
                        @toggledbits Yep, successful download. Moving on to deployment in the next few.
                        Core 2026.10.1
                          @toggledbits Looks good, no more errors - thank you for the quick turnaround. @therealdb fyi.
                          Core 2026.10.1
                            Yup, many thanks to @toggledbits for the quick fix!
                              148.8k
