Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
solved
    Yeah, this device is off. It's reporting Multilevel Switch for its generic class, and Motor Control Class C as the more specific, and usually this device class reports command class 38, Multilevel Switch. That's how your other iBlinds units that identify the same way (same 647 manufacturer ID, product type 4, product ID 114) work. But this particular unit does not appear to be advertising command class 38 Multilevel Switch, and is instead reporting command class 106 Window Covering, which is relatively new.
    Once you upload the data I PM'd you about, I'll be curious to see how the reporting firmware compares. But this new unit is definitely working differently from everything else you have, and it doesn't look like HA actually likes it any better -- I think that's why it's reporting the slats angle in HA as null; I bet it shows the same in their dashboard.
    I'll know more/confirm once I see you data. Probably won't get to that until Sunday or Monday at this point, though.
    @toggledbits file has been uploaded. This blind is in a guest room that's not in use currently - no rush.
    Do you think excluding/including with HA/ZWjs would have any effect? Could something have gone sideways during pairing that a complete redo might clear?
      ZWaveJSController version 23254 has been released. It should handle your oddball iBlinds unit. I'd love to know (not from you, from the manufacturer) what triggers the difference between reporting status in command class 38 versus command class 106 -- only this most recent unit of yours reports/controls via 106; all of the others use 38. And there's no difference in reported model or firmware version. No obvious configuration parameter that might trigger such a difference (e.g. some others, like some Aeotec devices, can change the reporting CC based on a config parameter). Just goes to show you that despite a fairly strict standard and specification, manufacturers can continue to make subtle choices that create headaches.
      G 2 Replies Last reply
        @toggledbits this was deployed and tests as working. Really appreciate it - I bought two new units and have held off installing the second until it was determined not to be a firmware problem (broken vs them just randomly changing something).
        Thank you!
          @toggledbits I contacted iblinds Support. This was their response:
          *We've had similar reports. I believe it is related to a recent update with Home Assistant supporting the Z-Wave Window Covering Command Class now. So when you add your new devices they are seen with the new command class. I would imagine if you excluded and included one of the older motors they would now be Window Covering devices as opposed to multi-level switches.
          We initially worked with the ZWaveJS developer when they added the Window Covering CC Support. But unfortunately, our HA in our lab is no longer working so we have been unable to test locally.
          We have been waiting to get a replacement RPi so hopefully we can do some testing on our end soon.
          I hope this helps.
          Best Regards,
          Eric B.
          The iblinds Team*
          Further, I just discovered if I do a reinterview on an existing blind via ZWaveJS in HA it switches to this new Window Covering mode.
            I hope this helps.
            Best Regards,
            Eric B.
            The iblinds Team*
            @gwp1 said in [SOLVED] New iblind and zwaveJScontroller/MSR not communicating:
            For what it's worth, I have both v2 and v3.1 iBlinds in my home. Reinterviewing only changes the type from multilevel switches to window covering on v3.1 blinds. Version 2 blinds remain multilevel switches after reinterviewing.
            The Window Covering class is supposedly better. The MLS class is designed for rolling blinds, so on/off will have the bllinds all the way open, or all the way off. With horizonal blinds, the 0/100 values are just 180 degree opposites of a closed blind. With Window Covering class, I believe there are values to tell the Z-Wave system what type of blind it is, and specify what is open versus closed. I dealt with iBlinds support maybe 4 or 5 months ago, and at the time, no Z-Wave system supported Window Covering. Zwave JS implemented the change shortly thereafter.
            • T tamorgen
              @tamorgen I'm poking at it now. It seems for the iblinds I can now use cover.close and the [0] NO (default) setting for direction vs having it set to [1] YES to make it tilt the way I want it to when closed.
              I was using power_switch.off previously to close my v3.1's.
              • T tamorgen
                UPDATE: after many lost hours last night/this morning (hello, 0230 ET, looking at you) I found cover.x and power_switch.x to be woefully unreliable after reinterviewing the blinds.
                What has proven reliable is position.set for which I use 0 for closed, 50 for open and have the blinds (as they were previously) set to [1] YES for Reverse Direction.
                  I've been using the ID hass>cover_blind_horizontal_slats_angle and x_hass_cover.open_cover_tilt or x_haas_cover.close_cover_tilt and it works flawlessly for open and close. If I want to set the position for partial close when the sun is glarring into the room, I use x_hass_cover.set_cover_tilt_position with the same ID, and set the tilt_position to whatever I want to reduce the glare.
                  My only problem now is that I use mushroom for my dashboard in Home Assistant, and the templates for covers hasn't caught up with the new Window Covering class. It makes adjusting the blinds more problematic from HA.
                    Can you please be more descriptive here? I don't have these devices, so I can't test them, but that doesn't mean I'm not interested in getting them working reliably. But the description given isn't enough for me to do any troubleshooting at all.
                      @toggledbits of course, no problem! I cannot seem to upload images into this response. I've uploaded to your Dropbox shared folder a pair of images.
                      Using the iblind I sent you logs and such for previously as the example, I have a blind called Beach Blind (two guest rooms, one is named Ocean, the other Beach). I use the commands from the ID Beach Blind from zwavejs. As @tamorgen notes, there is also a new one (with the changes HA made) from my HASS controller called Beach Blind Horizontal Slates Angle which has a few less commands including those mentioned starting with x_hass_*.
                      I use the ZwaveJSController commands.
                      cover.open
                      cover.close
                      power_switch.on
                      power_switch.off
                      position.set
                      zwave_device.refresh
                      zwave_device.set_config
                      These are the ones I most commonly use to open, close, and tilt the blinds. refresh is used to force HA to update dasheboards with any changes and set_config I use less often, weekly, to recalibrate the blinds as they do wander sometimes and "open" becomes "open-ish".
                      I'd been using power_switch.on to open and cover.close to close. The blinds have been happiest that way. With these new changes from HA, these commands have become hit/miss. In the HA ZWaveJS plugin the status would reflect 0/closed but the blind was clearly wide open.
                      Last night/this morning I opted to use position.set and it's been pretty solid from what I've seen throughout the day.
                      position.set = 0 nets me a closed blind, position.set = .5 nets me a wide open/"slates level with the ground" blind. I used position.set = .2 or .3 to tilt the sun away during specific dayparts based on sun azimuth.
                      I did not grab MSR logs during those tests - apologies, it was 0200 ET and I just wanted the blinds closed for the night. I have amassed 13 of these iblinds over the past couple years.
                      If you wish, I'll set some time tonight or tomorrow night and generate some MSR logs.
                        cover.open
                        cover.close
                        power_switch.on
                        power_switch.off
                        position.set
                        To be precise, it's not so much a change from HA, but from ZWaveJS. They're recognizing a new command class that the developers at iBlinds actually recommend.
                        I don't believe the old power switch commands work with the new command class. When I go into a specific device in ZwaveJS, the switch type devices are greyed out.
                        if you go into the switch, it shows it as unavailable.
                        I would guess the power on/off cover.close / cover.open are remnants and probably need to be removed.
                        • T tamorgen
                          @tamorgen said in [SOLVED] New iblind and zwaveJScontroller/MSR not communicating:
                          I noticed this as well. I've also noticed that tapping into the dialogue you're showing (how did you copy/paste images, I keep getting a parsing server error...) nets a slider in HA that does nothing. It literally says UNKNOWN at the top where a percentage would be display of openness or closure.
                            #22
                            @gwp1
                            It seems to me that something may be missing from this command class integration. I know iBlinds was working with the ZWaveJS developers. I'm curious is this is what they expected.
                            When I look at the entities in MSR, there are a lot of entries that have null or unknown. I'm not sure if this is coming from MSR expecting entries in a specific command class or if ZWaveJs is providing it to MSR that way.
                            Of all the actions in that window, the cover.xxx don't seem to work for me. The only ones that seem to work are:
                            x_hass_cover.close_cover_tilt
                            Others may work, but these are the one's I know specifically work and from an automation perspective meet my needs.
                            • T tamorgen
                              @gwp1
                              @tamorgen Yep. The ZWaveJSController from @toggledbits was doing the same and that's what started this thread. He reviewed data from my system and updated his ZWaveJSController to work with those command classes.
                                Okay, gotcha. I did verify that the cover.open using the zwavejscontroller entries does work on my system with the updated release. Curious that the cover.open command does not work using the equivalent haas entity.
                                • T tamorgen
                                  @tamorgen cover.open and cover.close worked for me intermittently, eventually degrading to not at all. position.set seems to be working pretty well.
                                    @toggledbits I conducted some tests tonight.
                                    MSR's ZWaveJSController
                                    HA ZWaveJSController Plugin via HA
                                    Sending you an image since I can't upload any here for some reason (parser error) via your file share.
                                    Results of my tests:
                                    MSR's ZWJSC: no response
                                    HA ZWJSC plugin: no response from any command other than x_hass_cover.set_cover_tilt_position
                                    [latest-23242]2023-09-17T23:34:45.311Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.312Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.313Z <Rule:INFO> HTTP Failed Alerts (rule-l2kd6w6k in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.313Z <Rule:INFO> MSR Update Notifier (rule-l9vf6nai in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.316Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) starting evaluation; because entity-changed System#reactor_system>system
                                    [latest-23242]2023-09-17T23:34:45.317Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) starting evaluation; because entity-changed System#reactor_system>system
                                    [latest-23242]2023-09-17T23:34:45.317Z <Rule:INFO> HTTP Failed Alerts (rule-l2kd6w6k in Reactor Alerts and Checks) starting evaluation; because entity-changed System#reactor_system>system
                                    [latest-23242]2023-09-17T23:34:45.317Z <Rule:INFO> MSR Update Notifier (rule-l9vf6nai in Reactor Alerts and Checks) starting evaluation; because entity-changed System#reactor_system>system
                                    [latest-23242]2023-09-17T23:34:45.318Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:45.318Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:45.320Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:45.320Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:45.321Z <Rule:INFO> HTTP Failed Alerts (rule-l2kd6w6k in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:45.321Z <Rule:INFO> HTTP Failed Alerts (rule-l2kd6w6k in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:45.322Z <Rule:INFO> MSR Update Notifier (rule-l9vf6nai in Reactor Alerts and Checks) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:45.323Z <Rule:INFO> MSR Update Notifier (rule-l9vf6nai in Reactor Alerts and Checks) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:45.323Z <Rule:INFO> The Internet is up (rule-l2gdh04j in Notifications) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.323Z <Rule:INFO> Check Internet Status (rule-l2f9yuad in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.324Z <Rule:INFO> HTTP Failed Alerts (rule-l2kd6w6k in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.324Z <Rule:INFO> MSR Update Notifier (rule-l9vf6nai in Reactor Alerts and Checks) evaluation complete
                                    [latest-23242]2023-09-17T23:34:45.346Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) starting evaluation; because entity-changed ValueSensor#hass>sensor_john_iphone_battery_status
                                    [latest-23242]2023-09-17T23:34:45.349Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:45.349Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:45.350Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluation complete
                                    [latest-23242]2023-09-17T23:34:50.341Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) starting evaluation; because entity-changed ValueSensor#hass>sensor_john_iphone_battery_status
                                    [latest-23242]2023-09-17T23:34:50.347Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:50.348Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:50.349Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluation complete
                                    [latest-23242]2023-09-17T23:34:51.559Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 1405 (Sun Position); device not enumerated by Maker API
                                    [latest-23242]2023-09-17T23:34:51.600Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 1405 (Sun Position); device not enumerated by Maker API
                                    [latest-23242]2023-09-17T23:34:51.662Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 1405 (Sun Position); device not enumerated by Maker API
                                    [latest-23242]2023-09-17T23:34:55.352Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) starting evaluation; because entity-changed ValueSensor#hass>sensor_john_iphone_battery_status
                                    [latest-23242]2023-09-17T23:34:55.357Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) trigger evaluation result is false (previously false)
                                    [latest-23242]2023-09-17T23:34:55.357Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluated; trigger state unchanged (false); rule state remains RESET
                                    [latest-23242]2023-09-17T23:34:55.359Z <Rule:INFO> Change to Night (via ESPresense) (rule-kwc6rmci in Mode Triggers) evaluation complete
                                    [latest-23242]2023-09-17T23:34:55.426Z <Engine:INFO> Enqueueing "Blinds DR Open" (re-kx6a2k13)
                                    **[latest-23242]2023-09-17T23:34:55.429Z <Engine:NOTICE> Starting reaction Blinds DR Open (re-kx6a2k13)**
                                    [latest-23242]2023-09-17T23:34:56.685Z <ZWaveJSController:5:ZWaveJSController.js:798> ZWaveJSController#zwavejs handling node event statistics updated entity Cover#zwavejs>22-0
                                    [latest-23242]2023-09-17T23:34:56.767Z <ZWaveJSController:5:ZWaveJSController.js:798> ZWaveJSController#zwavejs handling node event value updated entity Cover#zwavejs>22-0
                                    [latest-23242]2023-09-17T23:34:56.769Z <ZWaveJSController:5:ZWaveJSController.js:994> ZWaveJSController#zwavejs update node 22 value "0:106:targetValue:23" data [Object]{ "source": "node", "event": "value updated", "nodeId": 22, "args": { "commandClassName": "Window Covering", "commandClass": 106, "endpoint": 0, "property": "targetValue", "propertyKey": 23, "newValue": 50, "prevValue": 0, "propertyName": "targetValue", "propertyKeyName": "Horizontal Slats Angle" } }
                                    [latest-23242]2023-09-17T23:34:56.770Z <ZWaveJSController:5:ZWaveJSController.js:1006> ZWaveJSController#zwavejs updating attributes for node 22 value "0:106:targetValue:23"=50: [Array][  ]
                                    [latest-23242]2023-09-17T23:34:56.771Z <ZWaveJSController:5:ZWaveJSController.js:1025> ZWaveJSController#zwavejs setting Cover#zwavejs>22-0.x_zwave_values.Window_Covering_targetValue_23 to 50
                                    [latest-23242]2023-09-17T23:34:56.782Z <ZWaveJSController:5:ZWaveJSController.js:798> ZWaveJSController#zwavejs handling node event value updated entity Cover#zwavejs>22-0
                                    [latest-23242]2023-09-17T23:34:56.783Z <ZWaveJSController:5:ZWaveJSController.js:994> ZWaveJSController#zwavejs update node 22 value "0:106:currentValue:23" data [Object]{ "source": "node", "event": "value updated", "nodeId": 22, "args": { "commandClassName": "Window Covering", "commandClass": 106, "property": "currentValue", "propertyKey": 23, "endpoint": 0, "newValue": 50, "prevValue": 0, "propertyName": "currentValue", "propertyKeyName": "Horizontal Slats Angle" } }
                                    [latest-23242]2023-09-17T23:34:56.785Z <ZWaveJSController:5:ZWaveJSController.js:1006> ZWaveJSController#zwavejs updating attributes for node 22 value "0:106:currentValue:23"=50: [Array][ "cover.state", "position.value" ]
                                    [latest-23242]2023-09-17T23:34:56.787Z <ZWaveJSController:5:ZWaveJSController.js:1013> ZWaveJSController#zwavejs updating attribute cover.state with [Object]{ "entity": "22-0", "impl": { "expr": "!(value == 0 || value >= 99)", "valueId": "106:currentValue:23" } }
                                    [latest-23242]2023-09-17T23:34:56.787Z <ZWaveJSController:5:ZWaveJSController.js:947> ZWaveJSController#zwavejs _apply_value entity Cover#zwavejs>22-0 cover.state
                                    [latest-23242]2023-09-17T23:34:56.788Z <ZWaveJSController:5:ZWaveJSController.js:987> ZWaveJSController#zwavejs _apply_value cover.state=true
                                    [latest-23242]2023-09-17T23:34:56.789Z <ZWaveJSController:5:ZWaveJSController.js:1013> ZWaveJSController#zwavejs updating attribute position.value with [Object]{ "entity": "22-0", "impl": { "expr": "round( value / 99, 2 )", "valueId": "106:currentValue:23" } }
                                    [latest-23242]2023-09-17T23:34:56.790Z <ZWaveJSController:5:ZWaveJSController.js:947> ZWaveJSController#zwavejs _apply_value entity Cover#zwavejs>22-0 position.value
                                    [latest-23242]2023-09-17T23:34:56.791Z <ZWaveJSController:5:ZWaveJSController.js:987> ZWaveJSController#zwavejs _apply_value position.value=0.51
                                    [latest-23242]2023-09-17T23:34:56.792Z <ZWaveJSController:5:ZWaveJSController.js:1025> ZWaveJSController#zwavejs setting Cover#zwavejs>22-0.x_zwave_values.Window_Covering_currentValue_23 to 50
                                    [latest-23242]2023-09-17T23:34:56.807Z <HassController:INFO> HassController#hass action x_hass_cover.set_cover_tilt_position([Object]{ "tilt_position": 50 }) on Cover#hass>cover_dining_room2_horizontal_slats_angle succeeded
                                    [latest-23242]2023-09-17T23:34:56.809Z <Engine:INFO> Resuming reaction Blinds DR Open (re-kx6a2k13) from step 1
                                    [latest-23242]2023-09-17T23:34:56.810Z <Engine:NOTICE> Blinds DR Open delaying until 1694993697809<9/17/2023, 7:34:57 PM>
                                    [latest-23242]2023-09-17T23:34:56.930Z <ZWaveJSController:5:ZWaveJSController.js:798> ZWaveJSController#zwavejs handling node event statistics updated entity Cover#zwavejs>22-0
                                    [latest-23242]2023-09-17T23:34:57.811Z <Engine:INFO> Resuming reaction Blinds DR Open (re-kx6a2k13) from step 2
                                    [latest-23242]2023-09-17T23:34:57.812Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing zwave_device.refresh on Cover#zwavejs>7-0 with [Object]{  }
                                    [latest-23242]2023-09-17T23:34:57.814Z <ZWaveJSController:5:ZWaveJSController.js:1750> ZWaveJSController#zwavejs no implementation mapped; attempting default
                                    [latest-23242]2023-09-17T23:34:57.815Z <ZWaveJSController:5:ZWaveJSController.js:751> ZWaveJSController#zwavejs sending #1694993697815<9/17/2023, 7:34:57 PM>: [Object]{ "command": "node.refresh_values", "nodeId": 7, "messageId": 1694993697815 }
                                    [latest-23242]2023-09-17T23:34:57.830Z <ZWaveJSController:5:ZWaveJSController.js:778> ZWaveJSController#zwavejs command result error: [Object]{ "type": "result", "success": false, "messageId": 1694993697815, "errorCode": "node_not_found", "args": { "nodeId": 7 } }
                                    [latest-23242]2023-09-17T23:34:57.832Z <ZWaveJSController:ERR> ZWaveJSController#zwavejs request 1694993697815<9/17/2023, 7:34:57 PM> (node.refresh_values) failed: [Error] node_not_found [-]
                                    [latest-23242]2023-09-17T23:34:57.834Z <Engine:INFO> Resuming reaction Blinds DR Open (re-kx6a2k13) from step 3
                                    [latest-23242]2023-09-17T23:34:57.835Z <Engine:INFO> Blinds DR Open all actions completed.
                                    If you'd like the whole log I can upload that as well or anything else you need for review.
                                      #27
                                      Yeah, a clean log would be good to review. In your logging.yaml, please add the following (if there's already a section for ZWaveJSController, just modify it to make it look like this):
                                        ZWaveJSController:
                                          level: 5
                                          streams:
                                            - type: file
                                              keep: 2
                                              level: 999
                                              recycle: true
                                      Restart Reactor and run a test (or a few) of cover.open and cover.close and position.set. Then copy just the zwavejs.log file up together with your latest zwavejs_devices_initial.json to link I sent you earlier. Thank you!
                                      G T 2 Replies Last reply
                                          ZWaveJSController:
                                            level: 5
                                            streams:
                                              - type: file
                                                keep: 2
                                                level: 999
                                                recycle: true
                                        @toggledbits I actually had that logging enabled already and didn't realize/remember it.
                                        Scenarios tested:
                                        Test #1: 22-0 ~10:20 ET
                                        ZWJSC, cover.close
                                        Result: blind closed, "inside down"
                                        ZWJSC, cover.open
                                        Result: blind opened, position=50%
                                        Repeated, same results
                                        Test #2: 22-0
                                        ZWJSC, position.set = 0
                                        Result: blind closed, "inside up"
                                        ZWJSC, position.set = .5
                                        Test #3: 22-0
                                        ZWJSC, cover.close
                                        ZWJSC, cover.open
                                        Unfortunately, everything WAI. Kinda frustrated at the moment. Same blind as last night's testing when nothing responded. Log being uploaded momentarily.
                                            ZWaveJSController:
                                              level: 5
                                              streams:
                                                - type: file
                                                  keep: 2
                                                  level: 999
                                                  recycle: true
                                          @gwp1 ,
                                          Not to steal your thread, but out of curiosity, have you noticed any issues with battery life lately? I've noticed that a few of my iBlinds are draining very rapidly, ending in a unresponsive state. I've charged them, then less than a week later, they are dead and unresponsive.
                                          They all appear to be the older v2 iBlinds, so it could just be that the batteries are ending their useful life, however, it's also possible that the new configuration and command class is affecting them in some way. I'm gradually replacing them, as I've found the v3.1 iBlinds to be much more reliable. I haven't noticed this behavior in the v3.1 iBlinds.
                                          I'm just curious if you've seen this as well. If you are seeing it, it could be an issue with how ZWaveJS is communicating with the iBlinds due to this new roleout.
                                            164.0k
