Hey,
I’m curating a list of smart home automation ideas, and here are 15+ ones (and still counting).
What do you think?
The smart home trend is dramatically evolving with at least 69% households in US owing at least one smart device.
So how could they ease your work and life?
I gathered and asked 15+ smart home professionals a same question:
“What’s your most favorite automation (ideas) for smart homes that is improving your life?”
Let’s check their ideas:
(source: https//www.leadsrating.com/security-cameras/smart-home-automation-ideas/)
Routine Checking Smart Curtain and Blinds Smart Interaction Smart LED String Lights Turn Outdoor Water On/Off Automation NFC Tags Automation Remote Control and Scenes Smart Interoperability Reducing Your Home Cleaning Job Light Control Automation Smart Blinds Light Management Adjusting Natural Light Automation Seamless Connectivity Simple Switch Bot Changing My Overall Everyday ProcessThe promise of "all available devices will be supported" gave me hope for including more Zigbee devices into to my home as Vera was not a good option for Zigbee devices.
Despite the support for new devices is extremely slow, the implementation of Zigbee has a lot to wish for and it seems a low priority at Ezlo I managed to include 22 of my 23 Zigbee devices as generic. But after 2 years of devices still missing attributes and randomly/every controller reboot loosing connection to the controller and had to be power cycled to connect again, and some even dropping off the network completely without any reason, I decided to give up.
The positive outcome of all this:
I bought a Sonoff Zigbee 3.0 USB Dongle Plus and installed Zigbee2MQTT and never been happier.
Suddenly the pairing were no pain and took a few seconds per device, all my devices were recognized, all capabilities of the devices were exposed and it never misses a signal to/from a device ever.
I'm surprised how stable and configurable my new setup is. I can set device parameters, offsets, send messages handled by the bulbs them self like effects, broadcast for groups, transition time for power on/off. I can handle debounce for MQTT messages, do OTA firmware update on devices and much more! Most of this is probably standard for the common branded hubs like Hue etc but I never had one so this is new to me.
A big plus for me is the MQTT part of Zigbee2MQTT as I'm migrating as much as possible to MQTT.
My Ezlo Plus is now serving as a modified WiFi access point to my network and only have the VistaCam 1203 Doorbell still connected for evaluation. Time will tell if I ever move my Z-wave devices to it.
Conclusion:
I could really recommend both the Sonoff 3.0 USB Dongle Plus and Zigbee2MQTT to anyone going the same path!
So cool to find the forum of all the banned vera gurus!
I've had a Vera Plus for about 6 years now, and have had a fairly problem free time with it compared to many other stories. The last years have however been lacking in progression in many fields i'd like to explore, so now i'm looking closely at Openluup.
Other systems have been tested as well, but i find that the community and plugins made for vera is kind of special, and something i'd like to contribute to as well. (getting older and not wanting to change to new stuff probably plays a part too!)
So, my stab at opeluup starts with an HP Chromebox 1 i got for free. Its a fairly powerfull thing, but as google wants to sell new ones, its now EOL.
I wiped it clean and installed debian, as it seems to be the closest thing to raspberry which many use for openluup.
Openluup installed fine, and i got the vera bridge working fairly well by bothering ppl at the vera forum with questions. Its now running OK, but there seems to be an issue with Icons?
Also at the devices tab:
I did the "GetFiles", and I see the /icons/ is populated, but no icons. In the luup log says that its trying to GET the icon, but returns no packages.
2020-09-15 17:04:30.818 openLuup.server:: GET /cmh/skins/default/img/devices/device_states/dimmable_light_off.png HTTP/1.1 tcp{client}: 0x55eca8d90cb8 2020-09-15 17:04:30.819 openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0x55eca8d90cb8I do have a UZB stick on the way, but before i go down that road i'd like to be sure that the installation is stable and sound.. Do I have all the nessecary packages/background processes? I did install cjson which helped on some things..
Also fairly new at linux in general, so bear with me. 😉
Roadmap:
Get the openluup/AltUI running smoothly
Transfer Z-wave devices
Transfer 433 devices (RFXtrx plugin)
Transfer Zigbee devices (Vera or mabye ezlo plus? zigbee stick?)
more questions will follow!
In a quest to further stabilize my Vera before I'll move to Z-Way+openLuup or something else later this year (I'm tempted to go the Home Assistant route, since all my friends are here, apparently), I've spent a couple of days removing HTTP calls from the system and I'm now fully using the UDP sender @akbooer has written in the past, to push all variables (and custom events/request as well) to my MQTT broker, then to some code doing the actual work.
Responsiveness seems to be at its maximum now, and stability has improved. There's still a lot of code locally on my Vera, but it's mainly doing variables comparison/scenes, while all notifications and heavy logic are now running in my linux box.
So, maybe, not insisting on the sockets and just use the same UDP server is the way to go for me.
Well here we go. A slow, considered migration from Vera to something (I hope) more reliable.
Hopefully we'll end up with a decent documented process for people as right now I'm still not quite clear 🙂
Starting point:
I have a 'mature' Mios set up running on an extrooted Vera Plus with roughly 100 devices, both physical and virtual
Integration with Alexa both voice control and TTS
iPhones for Geolocation
Volumio devices for music playing around the house.
I have no user defined scenes, all automation is run from Reactor.
My impetus is final dissatisfaction with the quality of UI7 software delivery and operational rigour (for full disclosure I am a senior IT Operations leader with circa 20 years experience delivering properly stable systems, so I probably have un-realistic expectations 😄 )
So initial steps:
Raspberry Pi 3 B+ (I think this is my 5, and 6th Pi in total. I may have a problem) Raspbian OpenLuup VerabridgeThat I think is stage 1
...but I now only have house mode scenes left on Vera. All other automation is by Reactor and Switchboard / Alexa routines.
WAF may be low tomorrow if it doesn't work 😄
I am a Electrician. I installed hundreds of smart devices for others prior to having my own home automation. In 2013 I bought a new house and decided to make it smart. I did some homework and settled on Z-wave and VeraPlus.
My installation comprises of
25 Z-wave dimmer/switch inserts
3 Z-wave door sensors
10 sonoff devices(basics,TH16 and Mini) ,
4 Tuya(lamps and RGB strips) ,
6 shellys(connected to motion sensors and 2 controlling dead DIY bolts )
3 Amazon Dots(gen2)
2 Broadlink (RMPro's)
4 DIY RF Venetian Blinds
2 Multi button DIY remotes
1 NVR
1 Network drive/Media server/ftp server.
1 smart thermostat heating and hot water
4 wired 240v/battery Aico smoke and heat detectors (connect to zwave via Relays)
1 robot hover.
1 Siren
Node-red server running on android.
Testing openluup on android.
Automate App running on andorid Boxes/phones.
All tv's are connected to android boxes.
No windows PC.
Debian running on android box.
Plugins Reactor, AlexaTTS, Switchboard and Virtual HTTP Switch.
I can control all of my devices from anyone of these platforms Vera/OpenLuup, Node-red, Automate(phone/tv box) or Alexa.
All devices have a standard/manual switch for anyone to control, and can be controlled even if my VeraPlus stopped working or internet out. My system is stable and may get a luup reload every couple of weeks.
None of my sonoff's or tuya have been flashed. I found Shelly very late into game and will be using these more now i found them, as they offer local control.
I have some coding knowledge from the 90's, but have never worked in the industry.
Well, if I see further, it's because I stand of the shoulders of giants. I've got where I got because of the experts here. I started about 15 years ago with some really basic X10 stuff. When we moved in 2011 for some reason it simply would not work in the new house, so z-wave was the thing. Vera lite then Vera Plus.
I'm a child of the 70s. I want the car on the drive to be KITT and my lounge a cross between the bridge of the enterprise and the Lars farm on Tattoine.
Not there yet, but with about 250 devices (virtual and real) things are fun (when they work!)
The absolute killer app for me is Alexa bi directional speech. To the extent that I've walked into hotel rooms and said 'Alexa turn the lights on....'
I'm within a spit of never buying another control and doing everything via Alexa and Reactor (had to drop that in)
So that's pretty much me.
Let start maybe something useful for others. Maybe it will give you some idea!
Here's a summary of my setup!
I'm having :
VM#1 that runs openLuup VM#2 that runs Zway 1x raspberry that I use to connect the RaZberry board using socat/ser2net to send "raw data" to the VM#2, this setup allow me to have all my stuff in the data center in the basement while having my zwave antenna on the first floor and send back the data! A couple of pine64 and raspberry around the house, most of the pine64 are use for "smart display" around the house that show data from various source (will post picture later). I have also a raspberry that I used for openSprinkler in the "Shed" Each room in the house + Garage + on the patio is having a SONOS speaker that I use for music of course but that I use with the TTS to send some notification around the house based on the presence!For example, I can welcome people on the front door based on motion detection + IP camera motion!
I decided a long time ago that all "sensors" will be handle by the DSC alarm. Currently I'm having over 40 sensors in/out divided in 5 partition (main/2nd floor, basement, office and shed and a partition for non-alarm sensor)I connected my DSC using the DSC plugin from Vera to handle all that traffic that of course is send to openLuup!
On the zwave network, I would say that I'm having every room in/out done!
I'm using also this setup to welcome kids in the morning based on motion detection in each room and I have some time-based reminder using TTS mostly for the kids.
We also "named/called" our Home, SARAH, based on the TV Show Eureka that means "Self Actuated Residential Automated Habitat".
** openLuup handle ALL the logic, I have no scene and logic in Vera and Smarthome/Zway
More to come...
That's our main screen in the center of the house!
Inside the main screen, I'm having a bunch of stuff, like 2 Veraplus, and a RaZberry and of course a pine64 for the screen!
That's an uncomplete setup in the kitchen for screen #2, need to finish the "wood" part!
That's the touch screen monitor in the basement, so kids can use the Sonos app to play some music in the basement! The wood part is done, need to finish some "paint"!
My migration from Vera, or what I did on my holidays
Starting point:
I have no user defined scenes, all automation is run from Reactor.My impetus is final dissatisfaction with the quality of UI7 software delivery and operational rigour (for full disclosure I am a senior IT Operations leader with circa 20 years experience delivering properly stable systems, so I probably have un-realistic expectations )
So initial steps:
- Raspberry Pi 3 B+ (I think this is my 5, and 6th Pi in total. I may have a problem)
- Raspbian
- OpenLuup
- Verabridge
Well I'm going to stop now before I get too far ahead of myself. I'm quite au fait with Linux and so far simples.
(I'm doing this on an Intel NUC I have lying around just for simplicity before the Pi arrives next week)
Assuming you have a nice, up to date Debian install, and using the documentation here:
First install Lua:
# apt-get update # apt-get install lua5.1 # apt-get install lua-socket # apt-get install lua-filesystem # apt-get install lua-sec
Create your cmh-ludl directory. I used /etc/cmh-ludl for backwards compatability with Vera
#mkdir /etc/cmh-ludl
cd into that directory and then
#wget https://github.com/akbooer/openLuup/raw/master/Utilities/openLuup_install.lua
from the same directory:
# lua5.1 openLuup_install.lua
I had a momentary gotcha as lua5.1 is not in my $PATH. I might add it later but I had to use:
#/usr/bin/lua openLuup_install.luaAssuming that all looks good check
http://you_ip_address:3480 with a browser and be amazed that AltUI is already up and running.
Next steps are to make OpenLuup start at boot. There are several documented ways. I went with systemctl for consistency.
This is documented here
http://forum.micasaverde.com/index.php/topic,48431.0.htmlHowever:
sudo nano /etc/cmh-ludl/run_openLuup.sh
Then
#!/bin/bash echo "Starting openLuup server" echo "To see tail of logfile: tail -f ./out.log" cd /etc/cmh-ludl sudo rm ./out.log nohup ./openLuup_reload >> out.log 2>&1 &
Make it executable
sudo chmod +x run_openLuup.sh
Create the service
sudo nano /etc/systemd/system/openluup.service
Add this code
[Unit] Description=openLuup and AltUI Server for Vera 3 Wants=network.target After=network.target [Service] Type=forking WorkingDirectory=/etc/cmh-ludl ExecStart=/bin/bash /etc/cmh-ludl/run_openLuup.sh [Install] WantedBy=multi-user.target
Then enable it and make it so it starts at boot:
sudo systemctl enable openluup sudo systemctl start openluu
Reboot to check and it's all good
So far so simple!
Next we need to bridge to the Vera by installing Vera bridge from the Altui plugins
In AltUI go to More>Plugins and hit the update button which is the chasing arrows next to the 'x' for delete. This will automatically install.
When that's done head to the devices tab and hit the fresh and shiny Vera Bridge icon.
Press 'Attributes' and look for the 'IP' box.
Enter in there the IP of your physical Vera box (I typoed it the first time)
When prompted, save the configuration and go to Misc>Reload LuupNow when you go to Devices you should see all your existing devices cloned in there.
Not should as this is my first issue. Not all of mine have come over. And some of the ones that have are incomplete (e.g. switches that don't have a switch....)
Errors in the LuaLogs example:
2020-06-19 13:33:19.815 luup.create_device:: [10009] D_TemperatureSensor1.xml / / () 2020-06-19 13:33:19.815 openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
Any thoughts as to where to go next?
Also I have no 'GetVeraFiles' as the VeraBridge says clearly 'No Vera'
I can see clearly communication to it in the log....
2020-06-19 13:30:08.905 luup_log:5: http://192.168.70.6/port_3480/data_request?id=action&DeviceNum=41&newTargetValue=0&action=SetTarget&serviceId=urn:upnp-org:serviceId:SwitchPower1 2020-06-19 13:30:09.237 openLuup.server:: request completed (2479 bytes, 1 chunks, 8189 ms) tcp{client}: 0x146b964
Browsing some other posts I also have
4 2020-06-19 13:33:20.332 5 5 Abort 0.199 4 plugin: VeraBridge ./openLuup/devices.lua:538: table index is nil
Which might help
TIA!
It looks like it is missing the xml file. Have you imported the files from the vera? There is a command in the verabridge device to do just that. It will copy the content of the "cmh-lu" and "cmh-ludl" folders into the openluup "files" folder. If not, try importing them manually? Maybe you don't have the latest openLuup and verabridge version?
Hmm will wait for @akbooer on this one. I have never seen this and since I no longer have a verabridge or a vera, I can't even check.
Try copying the temperature xml file from the vera and put it in openLuup?Edit: I just checked, and mine was definitely imported. It maybe a chicken and egg problem caused by a file import failure. Maybe try importing the entire /etc/cmh-lu and /etc/cmh-ludl content and dump them in /etc/cmh-ludl/files on openLuup. I suspect something has changed at some point on the vera firmware making this import function fail.
@mrFarmer said in My migration from Vera, or what I did on my holidays:
Hi Catman,
Things you may need to install as well: cjson, dkjson, bit,.... jeez, I wish i made notes the last time i installed openLuup
Rather why I'm doing this
So I have cjson and dkjson
Did you mean something like 'bit' or was it a typo of 'but'?
Nothing is different. I have deleted and re-installed the VeraBridge. Still says 'No Vera' even with the correct IP address, and only about 15 devices.
Cheers
Rather strange as your last error seem to indicate that the vera API returned an empty device table... Why would that be? Failing to decode json should have prompted another error but you already have that covered. All the files are in your openLuup installation folder right? (Mine is in /etc/cmh-ludl)
OpenLuup won’t decompress the lzo files. Therefore you would need to download them through UI7, one by one and then upload them in the openLuup installation. This is what the getverafiles does...
Otherwise you could also SCP into the vera and run an lzo decompress of all the files before downloading them.
The primary concern here though is why openLuup gets an empty device table from the vera now. It seems like you initially did get devices right? That’s why it was failing to create 10009 due to the missing xml file. This meant that it actually connected and that your vera device id 9 is a temperature sensor which openLuup was trying to mirror but was missing a file to do so.
Now your error seems to be altogether different: It seems to not see the vera’s returned json file and that puzzles me.To decompress the files on the vera the command is:
pluto-lzo -d file.lzo newfilename
It also has the rooms correctly cloned, though none of the devices that do exist are in the correct rooms.
Assuming that the devices are created in numerical order makes no sense either as I have 10061 in OpenLuup for example
I also have 10041 which works, but is in the wrong room (a simple switch)
1009 is the temperature reading of a Fibaro 3-in-1Migh highest ID on Openluup is 79, the control for my boiler, everything from that is missing. Everything down is there but faulty.
I think, given that part of the purpose here is to create a migration guide, I'll possess my sole in patience for @akbooer
It's probably user errorC
I think they are missing because the xml files for these devices are missing from the openLuup installation which is the first problem you reported. This appears to indicate that the verabridge did connect. Why it failed to import the xml verafiles and why it subsequently shows that it can't connect is what is so strange.
@CatmanV2 said in My migration from Vera, or what I did on my holidays:
I shall google while I wait for the esteemed @akbooer to enlighten me
Not seen this before, either. I’ll check the code, but, meantime, it’s not an issue with security settings on Vera, is it? Need to allow some ‘unsafe’ actions, IIRC.
This is the moment to look at the logs:
- Startup log
- Standard log, at the the start of it, after a system startup.
These most easily available from the openLuup console Logs menu, or directly from:
and
...I'm confused by the 'Vera is running but No Vera shown'.
Thanks @akbooer
Startup log and Lua log don't tell me anything that I find useful
2020-06-19 15:57:41.027 :: openLuup STARTUP :: /etc/cmh-ludl 2020-06-19 15:57:41.027 openLuup.init:: version 2020.05.01 @akbooer 2020-06-19 15:57:41.041 openLuup.scheduler:: version 2020.01.25 @akbooer 2020-06-19 15:57:41.051 openLuup.wsapi:: version 2019.08.12 @akbooer 2020-06-19 15:57:41.051 openLuup.servlet:: version 2020.01.29 @akbooer 2020-06-19 15:57:41.051 openLuup.client:: version 2019.10.14 @akbooer 2020-06-19 15:57:41.052 openLuup.io:: version 2019.11.29 @akbooer 2020-06-19 15:57:41.052 openLuup.server:: version 2020.03.20 @akbooer 2020-06-19 15:57:41.055 openLuup.scenes:: version 2020.03.16 @akbooer 2020-06-19 15:57:41.056 openLuup.chdev:: version 2020.03.07 @akbooer 2020-06-19 15:57:41.056 openLuup.userdata:: version 2020.03.31 @akbooer 2020-06-19 15:57:41.057 openLuup.requests:: version 2020.04.15 @akbooer 2020-06-19 15:57:41.057 openLuup.gateway:: version 2020.03.08 @akbooer 2020-06-19 15:57:41.058 openLuup.smtp:: version 2018.04.12 @akbooer 2020-06-19 15:57:41.060 openLuup.historian:: version 2020.02.12 @akbooer 2020-06-19 15:57:41.061 openLuup.luup:: version 2020.03.21 @akbooer 2020-06-19 15:57:41.061 openLuup.pop3:: version 2018.04.23 @akbooer 2020-06-19 15:57:41.062 openLuup.compression:: version 2016.06.30 @akbooer 2020-06-19 15:57:41.062 openLuup.timers:: version 2019.05.03 @akbooer 2020-06-19 15:57:41.062 openLuup.logs:: version 2018.03.25 @akbooer 2020-06-19 15:57:41.062 openLuup.json:: version 2020.05.20 @akbooer 2020-06-19 15:57:41.062 openLuup.init:: using Cjson 2.1.0 for fast decoding 2020-06-19 15:57:41.062 luup.create_device:: [1] D_ZWaveNetwork.xml / / () 2020-06-19 15:57:41.062 openLuup.chdev:: ERROR: unable to read XML file I_ZWave.xml 2020-06-19 15:57:41.068 luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json (openLuup) 2020-06-19 15:57:41.068 openLuup.init:: loading configuration user_data.json 2020-06-19 15:57:41.068 openLuup.userdata:: loading user_data json... 2020-06-19 15:57:41.072 luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0 2020-06-19 15:57:41.072 openLuup.userdata:: loading rooms... 2020-06-19 15:57:41.072 openLuup.userdata:: room#1 'MiOS-50103066' 2020-06-19 15:57:41.072 openLuup.userdata:: room#2 'Garden' 2020-06-19 15:57:41.072 openLuup.userdata:: room#3 'Driveway' 2020-06-19 15:57:41.072 openLuup.userdata:: room#4 'Hall' 2020-06-19 15:57:41.072 openLuup.userdata:: room#5 'Living Room' 2020-06-19 15:57:41.072 openLuup.userdata:: room#6 'Server Room' 2020-06-19 15:57:41.072 openLuup.userdata:: room#7 'Porch' 2020-06-19 15:57:41.072 openLuup.userdata:: room#8 'ReactorCore' 2020-06-19 15:57:41.072 openLuup.userdata:: room#9 'Garage' 2020-06-19 15:57:41.072 openLuup.userdata:: room#10 'Master Bedroom' 2020-06-19 15:57:41.072 openLuup.userdata:: room#11 'Media_Centre' 2020-06-19 15:57:41.072 openLuup.userdata:: room#12 'Office' 2020-06-19 15:57:41.072 openLuup.userdata:: room#13 'X-Lab' 2020-06-19 15:57:41.072 openLuup.userdata:: room#14 'Dining Room' 2020-06-19 15:57:41.072 openLuup.userdata:: room#15 'Greenhouse' 2020-06-19 15:57:41.072 openLuup.userdata:: room#16 'Kitchen' 2020-06-19 15:57:41.072 openLuup.userdata:: ...room loading completed 2020-06-19 15:57:41.072 openLuup.userdata:: loading devices... 2020-06-19 15:57:41.073 luup.create_device:: [1] D_ZWaveNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1) 2020-06-19 15:57:41.113 openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value) 2020-06-19 15:57:41.113 openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value) 2020-06-19 15:57:41.113 openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value) 2020-06-19 15:57:41.113 openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value) 2020-06-19 15:57:41.113 luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1) 2020-06-19 15:57:41.117 luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json (urn:schemas-upnp-org:device:AltAppStore:1) 2020-06-19 15:57:41.123 luup.create_device:: [7] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json (VeraBridge) 2020-06-19 15:57:41.123 luup.create_device:: [10002] D_ZigbeeNetwork.xml / / () 2020-06-19 15:57:41.123 openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml 2020-06-19 15:57:41.123 luup.create_device:: [10003] D_BluetoothNetwork.xml / / () 2020-06-19 15:57:41.123 openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml 2020-06-19 15:57:41.123 luup.create_device:: [10004] D_SceneController1.xml / / () 2020-06-19 15:57:41.124 openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml 2020-06-19 15:57:41.124 luup.create_device:: [10006] D_SceneController1.xml / / () 2020-06-19 15:57:41.124 openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml 2020-06-19 15:57:41.125 luup.create_device:: [10007] D_SceneController1.xml / / () 2020-06-19 15:57:41.125 openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml 2020-06-19 15:57:41.126 luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json (urn:schemas-micasaverde-com:device:MotionSensor:1) 2020-06-19 15:57:41.127 luup.create_device:: [10009] D_TemperatureSensor1.xml / / () 2020-06-19 15:57:41.127 openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml 2020-06-19 15:57:41.127 luup.create_device:: [10010] D_LightSensor1.xml / / () 2020-06-19 15:57:41.127 openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml 2020-06-19 15:57:41.130 luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.131 luup.create_device:: [10015] D_DimmableLight1.xml / / () 2020-06-19 15:57:41.131 openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml 2020-06-19 15:57:41.132 luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.134 luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.136 luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.137 luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1) 2020-06-19 15:57:41.138 luup.create_device:: [10026] D_DayTime.xml / / () 2020-06-19 15:57:41.138 openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml 2020-06-19 15:57:41.138 luup.create_device:: [10027] D_HouseModes.xml / / () 2020-06-19 15:57:41.138 openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml 2020-06-19 15:57:41.138 luup.create_device:: [10031] D_DigitalSecurityCamera2.xml / / () 2020-06-19 15:57:41.138 openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml 2020-06-19 15:57:41.138 luup.create_device:: [10033] D_DigitalSecurityCamera2.xml / / () 2020-06-19 15:57:41.138 openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml 2020-06-19 15:57:41.140 luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.141 luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.143 luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2020-06-19 15:57:41.144 luup.create_device:: [10061] D_DimmableLight1.xml / / () 2020-06-19 15:57:41.144 openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml 2020-06-19 15:57:41.144 luup.create_device:: [10062] D_DimmableLight1.xml / / () 2020-06-19 15:57:41.144 openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml 2020-06-19 15:57:41.144 luup.create_device:: [10079] D_Heater1.xml / / () 2020-06-19 15:57:41.144 openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml 2020-06-19 15:57:41.145 openLuup.userdata:: loading scenes... 2020-06-19 15:57:41.145 openLuup.userdata:: number of scenes = 0 2020-06-19 15:57:41.145 openLuup.userdata:: ...scene loading completed 2020-06-19 15:57:41.145 openLuup.userdata:: loading installed plugin info... 2020-06-19 15:57:41.145 openLuup.userdata:: [openLuup] openLuup (20.5.22) 2020-06-19 15:57:41.145 openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30) 2020-06-19 15:57:41.145 openLuup.userdata:: [VeraBridge] VeraBridge (20.4.30) 2020-06-19 15:57:41.145 openLuup.userdata:: [8246] Alternate UI (2.49b.) 2020-06-19 15:57:41.145 openLuup.userdata:: [Z-Way] Z-Way (not.installed) 2020-06-19 15:57:41.145 openLuup.userdata:: [Arduino] MySensors (not.installed) 2020-06-19 15:57:41.145 openLuup.userdata:: ...user_data loading completed 2020-06-19 15:57:41.145 openLuup.init:: running _openLuup_STARTUP_ 2020-06-19 15:57:41.145 luup_log:0: startup code completed 2020-06-19 15:57:41.145 openLuup.init:: init phase completed 2020-06-19 15:57:41.145 :: openLuup LOG ROTATION :: (runtime 0.0 days)
Is the start up log. There are no immediate errrors in the Lua log, but happy to poke it.
What I mean by 'No Vera shown' is that the VeraBridge insists that there no Vera on the ip address:
I'd attach a screenshot but I can't see how!
It’s not errors that I’m specifically looking for just now, but startup sequences and versions. The first few hundred lines should suffice.
