  2. Blogs
  3. My migration from Vera, or what I did on my holidays
Seeking Advice:
Blogs
L
Blogs
Finally gave up on my Ezlo Plus
Blogs
Another transition from Vera to OpenLuup And now to HASS - PerH
PerHP
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
105 Posts 6 Posters 78.0k Views 7 Watching
    It looks like it is missing the xml file. Have you imported the files from the vera? There is a command in the verabridge device to do just that. It will copy the content of the "cmh-lu" and "cmh-ludl" folders into the openluup "files" folder. If not, try importing them manually? Maybe you don't have the latest openLuup and verabridge version?
      I can't as the button doesn't exist.
      VeraBridge device still says 'No Vera' even thought the IP is most definitely correct, oh and I pulled the files direct
      so OpenLuup is 20.5.22
      VeraBridge is from Master 20.4.30
        Hmm will wait for @akbooer on this one. I have never seen this and since I no longer have a verabridge or a vera, I can't even check.
        Try copying the temperature xml file from the vera and put it in openLuup?
        Edit: I just checked, and mine was definitely imported. It maybe a chicken and egg problem caused by a file import failure. Maybe try importing the entire /etc/cmh-lu and /etc/cmh-ludl content and dump them in /etc/cmh-ludl/files on openLuup. I suspect something has changed at some point on the vera firmware making this import function fail.
          Yeah, that didn't help
          Still getting this as well:
          19/06/2020, 14:06:24 #4:VeraBridge:./openLuup/devices.lua:538: table index is nil
          I shall google while I wait for the esteemed @akbooer to enlighten me 🙂
            mrFarmer
            Hi Catman,
            Things you may need to install as well: cjson, dkjson, bit,.... jeez, I wish i made notes the last time i installed openLuup 😮
            CatmanV2C akbooerA 2 Replies Last reply
            • M mrFarmer
              Hi Catman,
              @mrFarmer said in My migration from Vera, or what I did on my holidays:
              Hi Catman,
              Rather why I'm doing this 😄
              So I have cjson and dkjson
              Did you mean something like 'bit' or was it a typo of 'but'?
              Nothing is different. I have deleted and re-installed the VeraBridge. Still says 'No Vera' even with the correct IP address, and only about 15 devices.
              Cheers
                Rather strange as your last error seem to indicate that the vera API returned an empty device table... Why would that be? Failing to decode json should have prompted another error but you already have that covered. All the files are in your openLuup installation folder right? (Mine is in /etc/cmh-ludl)
                  I have files in /etc/cmh/ludl however only the files that were installed but the Openluup script. Do you mean I should copy the .xml.lzo files to /etc/cmh-ludl (the same as my install?) or into /etc/cmh-ludl/files (where I copied them earlier)
                  Cheers
                    OpenLuup won’t decompress the lzo files. Therefore you would need to download them through UI7, one by one and then upload them in the openLuup installation. This is what the getverafiles does...
                    Otherwise you could also SCP into the vera and run an lzo decompress of all the files before downloading them.
                    The primary concern here though is why openLuup gets an empty device table from the vera now. It seems like you initially did get devices right? That’s why it was failing to create 10009 due to the missing xml file. This meant that it actually connected and that your vera device id 9 is a temperature sensor which openLuup was trying to mirror but was missing a file to do so.
                    Now your error seems to be altogether different: It seems to not see the vera’s returned json file and that puzzles me.
                    To decompress the files on the vera the command is:
                    pluto-lzo -d file.lzo newfilename
                      It also has the rooms correctly cloned, though none of the devices that do exist are in the correct rooms.
                      Assuming that the devices are created in numerical order makes no sense either as I have 10061 in OpenLuup for example
                      I also have 10041 which works, but is in the wrong room (a simple switch)
                      1009 is the temperature reading of a Fibaro 3-in-1
                      Migh highest ID on Openluup is 79, the control for my boiler, everything from that is missing. Everything down is there but faulty.
                      I think, given that part of the purpose here is to create a migration guide, I'll possess my sole in patience for @akbooer
                      It's probably user error 😉
                        I think they are missing because the xml files for these devices are missing from the openLuup installation which is the first problem you reported. This appears to indicate that the verabridge did connect. Why it failed to import the xml verafiles and why it subsequently shows that it can't connect is what is so strange.
                          Well I'm going to stop now before I get too far ahead of myself. I'm quite au fait with Linux and so far simples.
                          (I'm doing this on an Intel NUC I have lying around just for simplicity before the Pi arrives next week)
                          Assuming you have a nice, up to date Debian install, and using the documentation here:
                          openLuup/Documentation/openLuup User Guide.pdf at master · akbooer/openLuup
                          a pure-Lua open-source emulation of the Vera Luup environment - akbooer/openLuup
                          First install Lua:
                          # apt-get update
                          # apt-get install lua5.1
                          # apt-get install lua-socket
                          # apt-get install lua-filesystem
                          # apt-get install lua-sec
                          Create your cmh-ludl directory. I used /etc/cmh-ludl for backwards compatability with Vera
                          #mkdir /etc/cmh-ludl
                          cd into that directory and then
                          #wget https://github.com/akbooer/openLuup/raw/master/Utilities/openLuup_install.lua
                          from the same directory:
                          # lua5.1 openLuup_install.lua
                          I had a momentary gotcha as lua5.1 is not in my $PATH. I might add it later but I had to use:
                          #/usr/bin/lua openLuup_install.lua
                          Assuming that all looks good check
                          http://you_ip_address:3480 with a browser and be amazed that AltUI is already up and running.
                          Next steps are to make OpenLuup start at boot. There are several documented ways. I went with systemctl for consistency.
                          This is documented here
                          http://forum.micasaverde.com/index.php/topic,48431.0.html
                          However:
                          sudo nano /etc/cmh-ludl/run_openLuup.sh
                          Then
                          #!/bin/bash
                          echo "Starting openLuup server"
                          echo "To see tail of logfile: tail -f ./out.log"
                          cd /etc/cmh-ludl
                          sudo rm ./out.log
                          nohup ./openLuup_reload >> out.log 2>&1 &
                          Make it executable
                          sudo chmod +x run_openLuup.sh
                          Create the service
                          sudo nano /etc/systemd/system/openluup.service
                          Add this code
                          [Unit]
                          Description=openLuup and AltUI Server for Vera 3
                          Wants=network.target
                          After=network.target
                          [Service]
                          Type=forking
                          WorkingDirectory=/etc/cmh-ludl
                          ExecStart=/bin/bash /etc/cmh-ludl/run_openLuup.sh
                          [Install]
                          WantedBy=multi-user.target
                          Then enable it and make it so it starts at boot:
                          sudo systemctl enable openluup
                          sudo systemctl start openluu
                          Reboot to check and it's all good
                          So far so simple!
                          @CatmanV2 said in My migration from Vera, or what I did on my holidays:
                          Not seen this before, either. I’ll check the code, but, meantime, it’s not an issue with security settings on Vera, is it? Need to allow some ‘unsafe’ actions, IIRC.
                          • M mrFarmer
                            Hi Catman,
                            There's nothing you need to install.
                            dkjson is actually loaded by the openLuup_install script.
                              @CatmanV2
                              This is the moment to look at the logs:
                              • Startup log
                              • Standard log, at the the start of it, after a system startup.
                              These most easily available from the openLuup console Logs menu, or directly from:
                              http://IP:3480/openLuup?page=log
                              and
                              http://IP:3480/openLuup?page=startup_log
                              ...I'm confused by the 'Vera is running but No Vera shown'.
                                Thanks @akbooer
                                Startup log and Lua log don't tell me anything that I find useful
                                2020-06-19 15:57:41.027   :: openLuup STARTUP :: /etc/cmh-ludl
                                2020-06-19 15:57:41.027   openLuup.init::        version 2020.05.01  @akbooer
                                2020-06-19 15:57:41.041   openLuup.scheduler::   version 2020.01.25  @akbooer
                                2020-06-19 15:57:41.051   openLuup.wsapi::       version 2019.08.12  @akbooer
                                2020-06-19 15:57:41.051   openLuup.servlet::     version 2020.01.29  @akbooer
                                2020-06-19 15:57:41.051   openLuup.client::      version 2019.10.14  @akbooer
                                2020-06-19 15:57:41.052   openLuup.io::          version 2019.11.29  @akbooer
                                2020-06-19 15:57:41.052   openLuup.server::      version 2020.03.20  @akbooer
                                2020-06-19 15:57:41.055   openLuup.scenes::      version 2020.03.16  @akbooer
                                2020-06-19 15:57:41.056   openLuup.chdev::       version 2020.03.07  @akbooer
                                2020-06-19 15:57:41.056   openLuup.userdata::    version 2020.03.31  @akbooer
                                2020-06-19 15:57:41.057   openLuup.requests::    version 2020.04.15  @akbooer
                                2020-06-19 15:57:41.057   openLuup.gateway::     version 2020.03.08  @akbooer
                                2020-06-19 15:57:41.058   openLuup.smtp::        version 2018.04.12  @akbooer
                                2020-06-19 15:57:41.060   openLuup.historian::   version 2020.02.12  @akbooer
                                2020-06-19 15:57:41.061   openLuup.luup::        version 2020.03.21  @akbooer
                                2020-06-19 15:57:41.061   openLuup.pop3::        version 2018.04.23  @akbooer
                                2020-06-19 15:57:41.062   openLuup.compression:: version 2016.06.30  @akbooer
                                2020-06-19 15:57:41.062   openLuup.timers::      version 2019.05.03  @akbooer
                                2020-06-19 15:57:41.062   openLuup.logs::        version 2018.03.25  @akbooer
                                2020-06-19 15:57:41.062   openLuup.json::        version 2020.05.20  @akbooer
                                2020-06-19 15:57:41.062   openLuup.init:: using Cjson 2.1.0 for fast decoding
                                2020-06-19 15:57:41.062   luup.create_device:: [1] D_ZWaveNetwork.xml /  /    ()
                                2020-06-19 15:57:41.062   openLuup.chdev:: ERROR: unable to read XML file I_ZWave.xml
                                2020-06-19 15:57:41.068   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
                                2020-06-19 15:57:41.068   openLuup.init:: loading configuration user_data.json
                                2020-06-19 15:57:41.068   openLuup.userdata:: loading user_data json...
                                2020-06-19 15:57:41.072   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                                2020-06-19 15:57:41.072   openLuup.userdata:: loading rooms...
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#1 'MiOS-50103066'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#2 'Garden'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#3 'Driveway'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#4 'Hall'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#5 'Living Room'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#6 'Server Room'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#7 'Porch'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#8 'ReactorCore'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#9 'Garage'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#10 'Master Bedroom'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#11 'Media_Centre'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#12 'Office'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#13 'X-Lab'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#14 'Dining Room'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#15 'Greenhouse'
                                2020-06-19 15:57:41.072   openLuup.userdata:: room#16 'Kitchen'
                                2020-06-19 15:57:41.072   openLuup.userdata:: ...room loading completed
                                2020-06-19 15:57:41.072   openLuup.userdata:: loading devices...
                                2020-06-19 15:57:41.073   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                                2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
                                2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
                                2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
                                2020-06-19 15:57:41.113   openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
                                2020-06-19 15:57:41.113   luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                                2020-06-19 15:57:41.117   luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
                                2020-06-19 15:57:41.123   luup.create_device:: [7] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json   (VeraBridge)
                                2020-06-19 15:57:41.123   luup.create_device:: [10002] D_ZigbeeNetwork.xml /  /    ()
                                2020-06-19 15:57:41.123   openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml
                                2020-06-19 15:57:41.123   luup.create_device:: [10003] D_BluetoothNetwork.xml /  /    ()
                                2020-06-19 15:57:41.123   openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml
                                2020-06-19 15:57:41.123   luup.create_device:: [10004] D_SceneController1.xml /  /    ()
                                2020-06-19 15:57:41.124   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
                                2020-06-19 15:57:41.124   luup.create_device:: [10006] D_SceneController1.xml /  /    ()
                                2020-06-19 15:57:41.125   luup.create_device:: [10007] D_SceneController1.xml /  /    ()
                                2020-06-19 15:57:41.125   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
                                2020-06-19 15:57:41.126   luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                                2020-06-19 15:57:41.127   luup.create_device:: [10009] D_TemperatureSensor1.xml /  /    ()
                                2020-06-19 15:57:41.127   openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
                                2020-06-19 15:57:41.127   luup.create_device:: [10010] D_LightSensor1.xml /  /    ()
                                2020-06-19 15:57:41.127   openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml
                                2020-06-19 15:57:41.130   luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.131   luup.create_device:: [10015] D_DimmableLight1.xml /  /    ()
                                2020-06-19 15:57:41.131   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
                                2020-06-19 15:57:41.132   luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.134   luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.136   luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.137   luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                                2020-06-19 15:57:41.138   luup.create_device:: [10026] D_DayTime.xml /  /    ()
                                2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml
                                2020-06-19 15:57:41.138   luup.create_device:: [10027] D_HouseModes.xml /  /    ()
                                2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml
                                2020-06-19 15:57:41.138   luup.create_device:: [10031] D_DigitalSecurityCamera2.xml /  /    ()
                                2020-06-19 15:57:41.138   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
                                2020-06-19 15:57:41.138   luup.create_device:: [10033] D_DigitalSecurityCamera2.xml /  /    ()
                                2020-06-19 15:57:41.140   luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.141   luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.143   luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                2020-06-19 15:57:41.144   luup.create_device:: [10061] D_DimmableLight1.xml /  /    ()
                                2020-06-19 15:57:41.144   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
                                2020-06-19 15:57:41.144   luup.create_device:: [10062] D_DimmableLight1.xml /  /    ()
                                2020-06-19 15:57:41.144   luup.create_device:: [10079] D_Heater1.xml /  /    ()
                                2020-06-19 15:57:41.144   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
                                2020-06-19 15:57:41.145   openLuup.userdata:: loading scenes...
                                2020-06-19 15:57:41.145   openLuup.userdata:: number of scenes = 0
                                2020-06-19 15:57:41.145   openLuup.userdata:: ...scene loading completed
                                2020-06-19 15:57:41.145   openLuup.userdata:: loading installed plugin info...
                                2020-06-19 15:57:41.145   openLuup.userdata:: [openLuup] openLuup (20.5.22)
                                2020-06-19 15:57:41.145   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                                2020-06-19 15:57:41.145   openLuup.userdata:: [VeraBridge] VeraBridge (20.4.30)
                                2020-06-19 15:57:41.145   openLuup.userdata:: [8246] Alternate UI (2.49b.)
                                2020-06-19 15:57:41.145   openLuup.userdata:: [Z-Way] Z-Way (not.installed)
                                2020-06-19 15:57:41.145   openLuup.userdata:: [Arduino] MySensors (not.installed)
                                2020-06-19 15:57:41.145   openLuup.userdata:: ...user_data loading completed
                                2020-06-19 15:57:41.145   openLuup.init:: running _openLuup_STARTUP_
                                2020-06-19 15:57:41.145   luup_log:0: startup code completed
                                2020-06-19 15:57:41.145   openLuup.init:: init phase completed
                                2020-06-19 15:57:41.145   :: openLuup LOG ROTATION :: (runtime 0.0 days)
                                Is the start up log. There are no immediate errrors in the Lua log, but happy to poke it.
                                What I mean by 'No Vera shown' is that the VeraBridge insists that there no Vera on the ip address:
                                I'd attach a screenshot but I can't see how!
                                  Thanks @akbooer
                                  It’s not errors that I’m specifically looking for just now, but startup sequences and versions. The first few hundred lines should suffice.
                                    OK, after getting the log requested above, can you just try updating openLuup from the Plugins page, by pressing the update button on the openLuup Console Plugins page.
                                      Whatever you say, boss. this was after a Luup reload.
                                      2020-06-20 20:40:04.474   :: openLuup LOG ROTATION :: (runtime 0.0 days)
                                      2020-06-20 20:40:04.474   openLuup.init:: init phase completed
                                      2020-06-20 20:40:04.474   openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x2683d34
                                      2020-06-20 20:40:04.474   openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x2685da4
                                      2020-06-20 20:40:04.474   openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x2688224
                                      2020-06-20 20:40:04.475   openLuup.historian:: starting data historian
                                      2020-06-20 20:40:04.475   openLuup.historian:: using memory cache size (per-variable): 1024
                                      2020-06-20 20:40:04.475   openLuup.scheduler:: starting
                                      2020-06-20 20:40:04.475   openLuup.scheduler:: [2]     openLuup device startup
                                      2020-06-20 20:40:04.475   luup_log:2: v20.5.22
                                      2020-06-20 20:40:04.475   luup_log:2: sync in 115.5 s
                                      2020-06-20 20:40:04.475   luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode
                                      2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local
                                      2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local
                                      2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local
                                      2020-06-20 20:40:04.475   luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local
                                      2020-06-20 20:40:04.475   luup.chdev.append:: [AltAppStore] Alternate App Store
                                      2020-06-20 20:40:04.475   luup.chdev.sync:: [2]     openLuup, syncing children
                                      2020-06-20 20:40:04.476   luup_log:2: 3Mb, 0.1%cpu, 0.0days
                                      2020-06-20 20:40:04.476   openLuup.scheduler:: [2]     openLuup device startup completed: status=true, msg=sync in 115.5 s, name=L_openLuup
                                      2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup
                                      2020-06-20 20:40:04.476   luup_log:3: ALTUI: initstatus(3) starting version: v2.49b
                                      2020-06-20 20:40:04.476   openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name=
                                      2020-06-20 20:40:04.476   openLuup.scheduler:: [7] VeraBridge device startup
                                      2020-06-20 20:40:04.476   luup_log:7: VeraBridge
                                      2020-06-20 20:40:04.476   luup_log:7: 2020.04.30
                                      2020-06-20 20:40:04.476   luup_log:7: 192.168.70.6
                                      2020-06-20 20:40:04.476   luup_log:7: device clone numbering starts at 10000
                                      2020-06-20 20:40:04.476   luup_log:7: VeraBridge maps remote Zwave controller
                                      2020-06-20 20:40:04.476   luup_log:7: v20.4.30
                                      2020-06-20 20:40:04.644   luup_log:7: Vera info received!
                                      2020-06-20 20:40:04.644   luup_log:7: MiOS-50103066
                                      2020-06-20 20:40:04.644   luup_log:7: new room number: 1
                                      2020-06-20 20:40:04.644   luup_log:7: PK_AccessPoint = 50103066
                                      2020-06-20 20:40:04.644   luup_log:7: BuildVersion = *1.7.4833*
                                      2020-06-20 20:40:04.644   luup_log:7: number of remote devices = 117
                                      2020-06-20 20:40:04.644   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                                      2020-06-20 20:40:04.645   luup.create_device:: [10002] D_ZigbeeNetwork.xml /  /    ()
                                      2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_ZigbeeNetwork.xml
                                      2020-06-20 20:40:04.645   luup.create_device:: [10003] D_BluetoothNetwork.xml /  /    ()
                                      2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_BluetoothNetwork.xml
                                      2020-06-20 20:40:04.645   luup.create_device:: [10004] D_SceneController1.xml /  /    ()
                                      2020-06-20 20:40:04.645   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
                                      2020-06-20 20:40:04.646   luup.create_device:: [10006] D_SceneController1.xml /  /    ()
                                      2020-06-20 20:40:04.646   openLuup.chdev:: ERROR: unable to read XML file D_SceneController1.xml
                                      2020-06-20 20:40:04.646   luup.create_device:: [10007] D_SceneController1.xml /  /    ()
                                      2020-06-20 20:40:04.648   luup.create_device:: [10008] D_MotionSensor1.xml / X / D_MotionSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                                      2020-06-20 20:40:04.648   luup.create_device:: [10009] D_TemperatureSensor1.xml /  /    ()
                                      2020-06-20 20:40:04.648   openLuup.chdev:: ERROR: unable to read XML file D_TemperatureSensor1.xml
                                      2020-06-20 20:40:04.649   luup.create_device:: [10010] D_LightSensor1.xml /  /    ()
                                      2020-06-20 20:40:04.649   openLuup.chdev:: ERROR: unable to read XML file D_LightSensor1.xml
                                      2020-06-20 20:40:04.650   luup.create_device:: [10011] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.650   luup.create_device:: [10015] D_DimmableLight1.xml /  /    ()
                                      2020-06-20 20:40:04.650   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
                                      2020-06-20 20:40:04.652   luup.create_device:: [10018] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.654   luup.create_device:: [10019] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.655   luup.create_device:: [10020] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.657   luup.create_device:: [10023] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                                      2020-06-20 20:40:04.657   luup.create_device:: [10026] D_DayTime.xml /  /    ()
                                      2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DayTime.xml
                                      2020-06-20 20:40:04.657   luup.create_device:: [10027] D_HouseModes.xml /  /    ()
                                      2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_HouseModes.xml
                                      2020-06-20 20:40:04.657   luup.create_device:: [10031] D_DigitalSecurityCamera2.xml /  /    ()
                                      2020-06-20 20:40:04.657   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
                                      2020-06-20 20:40:04.658   luup.create_device:: [10033] D_DigitalSecurityCamera2.xml /  /    ()
                                      2020-06-20 20:40:04.658   openLuup.chdev:: ERROR: unable to read XML file D_DigitalSecurityCamera2.xml
                                      2020-06-20 20:40:04.659   luup.create_device:: [10037] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.661   luup.create_device:: [10041] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.662   luup.create_device:: [10057] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                      2020-06-20 20:40:04.663   luup.create_device:: [10061] D_DimmableLight1.xml /  /    ()
                                      2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_DimmableLight1.xml
                                      2020-06-20 20:40:04.663   luup.create_device:: [10062] D_DimmableLight1.xml /  /    ()
                                      2020-06-20 20:40:04.663   luup.create_device:: [10079] D_Heater1.xml /  /    ()
                                      2020-06-20 20:40:04.663   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
                                      2020-06-20 20:40:04.664   luup.create_device:: [10080] D_Heater1.xml /  /    ()
                                      2020-06-20 20:40:04.664   openLuup.chdev:: ERROR: unable to read XML file D_Heater1.xml
                                      2020-06-20 20:40:04.664   openLuup.context_switch::  ERROR: [dev #7] ./openLuup/devices.lua:538: table index is nil
                                      2020-06-20 20:40:04.664   openLuup.scheduler:: job aborted : ./openLuup/devices.lua:538: table index is nil
                                      2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup
                                      2020-06-20 20:40:04.664   luup_log:4: AltAppStore : starting...
                                      2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0
                                      2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was:  now:  #hooks:0
                                      2020-06-20 20:40:04.664   luup_log:4: AltAppStore : v20.3.30
                                      2020-06-20 20:40:04.664   luup.set_failure:: status = 0
                                      2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                                      2020-06-20 20:40:04.664   luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                      2020-06-20 20:40:04.664   openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
                                      2020-06-20 20:40:05.372   openLuup.io.server:: HTTP:3480 connection from 192.168.70.251 tcp{client}: 0x27493a4
                                      2020-06-20 20:40:05.373   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=578672005&Timeout=60&MinimumDelay=1500&_=1592671339440 HTTP/1.1 tcp{client}: 0x27493a4
                                      2020-06-20 20:40:05.602   openLuup.server:: request completed (128491 bytes, 9 chunks, 228 ms) tcp{client}: 0x27493a4
                                      2020-06-20 20:40:05.602   luup_log:3: ALTUI: startupDeferred, called on behalf of device:3
                                      2020-06-20 20:40:05.606   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49b now: v2.49b #hooks:0
                                      2020-06-20 20:40:05.649   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... #hooks:0
                                      2020-06-20 20:40:05.650   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"key":"nodeid","type":"number","default... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was:  now:  #hooks:0
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was:  now:  #hooks:0
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was:  now:  #hooks:0
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0
                                      2020-06-20 20:40:05.651   luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0)
                                      2020-06-20 20:40:05.651   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now:  #hooks:0
                                      2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was: [] now:  #hooks:0
                                      2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsVariableBag was:  now:  #hooks:0
                                      2020-06-20 20:40:05.652   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.WorkflowsActiveState was:  now: [] #hooks:0
                                      2020-06-20 20:40:05.652   luup.register_handler:: global_function_name=myALTUI_Handler, request=ALTUI_Handler
                                      2020-06-20 20:40:05.654   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
                                      2020-06-20 20:40:05.654   luup.register_handler:: global_function_name=ALTUI_LuaRunHandler, request=ALTUI_LuaRunHandler
                                      2020-06-20 20:40:05.655   luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
                                      2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was:  now: [] #hooks:0
                                      2020-06-20 20:40:05.656   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.PendingReset was: 0 now: 0 #hooks:0
                                      2020-06-20 20:40:05.662   luup.set_failure:: status = 0
                                      2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                                      2020-06-20 20:40:05.662   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                                      2020-06-20 20:40:05.662   luup_log:3: ALTUI: startup completed
                                      2020-06-20 20:40:05.669   openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=578663463&_=1592671339441 HTTP/1.1 tcp{client}: 0x27493a4
                                      2020-06-20 20:40:05.857   openLuup.server:: request completed (179603 bytes, 12 chunks, 187 ms) tcp{client}: 0x27493a4
                                      2020-06-20 20:40:07.905   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008955&Timeout=60&MinimumDelay=1500&_=1592671339442 HTTP/1.1 tcp{client}: 0x27493a4
                                      2020-06-20 20:40:08.014   openLuup.server:: request completed (20870 bytes, 2 chunks, 108 ms) tcp{client}: 0x27493a4
                                      2020-06-20 20:40:08.166   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=682008971&Timeout=60&MinimumDelay=1500&_=1592671339443 HTTP/1.1 tcp{client}: 0x27493a4
                                      2020-06-20 20:41:08.520   openLuup.server:: request completed (363 bytes, 1 chunks, 60353 ms) tcp{client}: 0x27493a4
                                      Hit update. Showing 2.4.30 No change in the devices (I don't have an update button on the console page, but I did it from AltUI)
                                        Can you update openLuup from the development branch, and try again?
                                          Happy to, but, ummm, how?
                                          Cheers
                                            158.9k
