  2. Blogs
  3. This is me
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
This is me
4 Posts 3 Posters 1.9k Views 2 Watching
    ElcidE DesTD 2 Replies Last reply
      ElcidE Offline
      ElcidE Offline
      Elcid
      @CatmanV2 said in This is me:
      Well said.
        DesTD Offline
        DesTD Offline
        DesT
        I got the red light that move on the front of my car a year ago 😉
        • DesTD DesT
          @DesT said in This is me:
          I would have been disowned from my former car 'club' I fear! And now with a shonky old Jag, it's not gonna look good 😄
