  2. Blogs
  3. Not so much a blog
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
Not so much a blog
6 Posts 3 Posters 3.6k Views 3 Watching
    WAF may be low tomorrow if it doesn't work 😄
      But I am sure it will!!! Next step: Port the Reactors to openLuup 😉
        If it doesn't work, it certainly won't be the software's fault!
        Can I really buy another pi :D. That'll be 5 in the server cupboard and one under the sofa!
        And I still need Alexa, but yes, crawling progress
          Hmm, she's still talking to me. One routine not quite working, but it's the one that tells me where she is, and it's an Alexa issue (She's working at the dining room table!)
            @CatmanV2 said in Not so much a blog:
            ...so this is running under openLuup, yes?
            ...so the question is “why”?
            Perhaps this I s this just work in progress, not the final configuration?
              @akbooer said in Not so much a blog:
              No this is still UI7
              Perhaps. I haven't got anything to run openLuup on (right now) and the device transfer still worries me.
              The big sticking point is going to be Alexa skill. It's pretty much the only way we interact with Vera now. The keypads are most unused.
