  2. Blogs
  3. My Wandering
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
My Wandering
3 Posts 2 Posters 1.5k Views 1 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    wrote on last edited by Elcid
    3 Amazon Dots(gen2)
    1 NVR
    1 robot hover.
    1 Siren
    No windows PC.
      Hey @Elcid, I envy your electrician skills 😄
      I will talk more to you in the future about my plans, since I'm mostly a coder, I had my house built by electricians but sometimes it's very difficult for them to understand my requests - so I did myself a couple of things, since I'm handy.
      ElcidE 1 Reply Last reply
        ElcidE Offline
        ElcidE Offline
        Elcid
        @therealdb Always happy to help.
          156.1k
