  2. Blogs
  3. Half-way migration from Vera
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Blogs
My Home Automation Story
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
4 Posts 3 Posters 2.0k Views 3 Watching
    B 1 Reply Last reply
      That's good to know. Certainly, you can't really get lower overhead than UDP, and after having monitored millions and millions of transactions on my local network, I've seen no evidence of any message getting 'lost', so a transaction handshake is really not required.
        B Offline
        B Offline
        Buxton
        @therealdb Hey,
        If you're happy with the UDP sender, can you post it in the alt-plugin store. That is if it's in plugin form. I'm considering doing the same thing and no use re-inventing the wheel.
        • B Buxton
          @therealdb Hey,
          @buxton no plugin at the moment, just a bunch of code. I was planning to do it and use the VeraBridge inside openluup, but I could definitely start with just the server part soon.
            157.0k
