  2. Blogs
  3. My Home Automation Story
Seeking Advice:
Blogs
L
Blogs
Blogs
Blogs
Half-way migration from Vera
Blogs
Blogs
Blogs
Not so much a blog
Blogs
My Wandering
ElcidE
Blogs
This is me
Blogs
My Home Automation Setup...
Blogs
2 Posts 1 Posters 1.4k Views 1 Watching
    Here is mine:
    My Home Automation Journey
      A bit random but will post it here anyway...
      My second my sensative strip sensor ran out of battery. These non battery replaceable devices are rated for 10 year battery life and they have spent 2 year running on the vera which wiped their battery down from 100% to 0~20%. I have sustained the remaining battery life for over a year now running it on z-way. The rest of my battery operated devices have had such a dramatic battery life extension (~3x for battery nodes and ~5x for FliRs) since I junked the vera and its flabbergastingly stupid z-wave network management and destructive "maintenance" that I have no doubt that the shortened battery life of my sensor is due to the vera. I am not happy at all to have to replace such an expensive sensor so much sooner than planned as you can imagine...
