  4. Fail safe condition for battery devices
29 Posts 3 Posters 9.7k Views 3 Watching
    The iBlinds 3.x implementation in ZWaveJSController commands 99 for close, not 0. Try using position.set with 0 instead.
    @toggledbits said in Fail safe condition for battery devices:
    Not quite working either. Position 99 is Closed, down inside. Position 0 is Closed, up inside. The cover.open and cover.close commands work in my previous iteration. When I try and use the position.set command, I get unexpected results.
    Below is the corresponding Open version. When I set the position.set to 50, which is 50% (halfway between 0 & 99, so the blinds are flat and fully open, it set's the position to 99, not 50.
    If I use position.set to 1, the current value changes to 99, so for opening the blinds to that 50 value, position.set does not appear to be appropriate.
    iBlinds now uses the Window Covering command class and not the previously used multilevel switch window class, which works fine for roller blinds, but not horizontal blinds.
      Sorry, I erred... try using values in the range of 0 to 1 (so 50 = 0.5) for position.set.
      I would also be consistent and not use the extended attributes (x_zwave_values...), but rather position.value and/or cover.state.
        That makes sense. The cover.state is a True/False value, so I'm not quite sure what that does.
        I've revised it, and I've extended the delay times out a bit. The first blind opens correctly, but the second one opens, and then closes itself again. I'm really perpelexed as to why.
        • T tamorgen
          @tamorgen said in Fail safe condition for battery devices:
          Can you also post the full attributes for this device (using the Copy Attributes button)?
            Here you go:
            battery_power.level=0.9
            battery_power.since=1721846488511
            cover.state=false
            position.value=0
            x_debug.dt={"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=7","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","description":"Window Blind Controller","model":"iblinds V3","default_name":"Window Blind Controller","values":[{"valueId":"38:currentValue:","capabilities":{"cover":{"attributes":{"state":{"expr":"!(value == 0 || value >= 99)"}},"actions":{"open":{"valueId":"38:targetValue:","value":50},"close":{"valueId":"38:targetValue:","value":99},"stop":false}},"position":{"attributes":{"value":{"expr":"round( value / 99, 2 )"}},"actions":{"set":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )"}},"increase":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"decrease":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) - ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"relative":{"valueId":"38:targetValue","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}}}},"toggle":{"actions":{"toggle":{"valueId":"38:targetValue:","value":{"expr":"entity.attributes.cover.state ? 99 : 50"}}}}}}],"manufacturerId":647,"productType":4,"productId":113}
            x_zwave_values.Battery_level=90
            x_zwave_values.Configuration_Close_Interval=15
            x_zwave_values.Configuration_Default_ON_Value=50
            x_zwave_values.Configuration_MC=1
            x_zwave_values.Configuration_Maximum_Tilt_Level=null
            x_zwave_values.Configuration_Minimum_Tilt_Level=null
            x_zwave_values.Configuration_Movement_Duration=0
            x_zwave_values.Configuration_Override_Response_to_ON_Command=null
            x_zwave_values.Configuration_Remote_Calibration=1
            x_zwave_values.Configuration_Reset_Button=0
            x_zwave_values.Configuration_Reverse_Direction=0
            x_zwave_values.Configuration_Send_Reports=0
            x_zwave_values.Indicator_Node_Identify_3=0
            x_zwave_values.Indicator_Node_Identify_4=0
            x_zwave_values.Indicator_Node_Identify_5=0
            x_zwave_values.Indicator_identify=null
            x_zwave_values.Indicator_timeout=null
            x_zwave_values.Indicator_value=null
            x_zwave_values.Manufacturer_Specific_manufacturerId=647
            x_zwave_values.Manufacturer_Specific_productId=114
            x_zwave_values.Manufacturer_Specific_productType=4
            x_zwave_values.Version_applicationBuildNumber=43707
            x_zwave_values.Version_applicationFrameworkAPIVersion="3.12.1"
            x_zwave_values.Version_applicationFrameworkBuildNumber=35
            x_zwave_values.Version_applicationVersion="3.12.1"
            x_zwave_values.Version_firmwareVersions=["3.12"]
            x_zwave_values.Version_hardwareVersion=2
            x_zwave_values.Version_hostInterfaceBuildNumber=0
            x_zwave_values.Version_hostInterfaceVersion="unused"
            x_zwave_values.Version_protocolVersion="7.12"
            x_zwave_values.Version_sdkVersion="7.12.2"
            x_zwave_values.Version_zWaveProtocolBuildNumber=35
            x_zwave_values.Version_zWaveProtocolVersion="7.12.2"
            x_zwave_values.Window_Covering_currentValue_23=0
            x_zwave_values.Window_Covering_duration_23={"value":0,"unit":"seconds"}
            x_zwave_values.Window_Covering_levelChangeDown_23=null
            x_zwave_values.Window_Covering_levelChangeUp_23=null
            x_zwave_values.Window_Covering_targetValue_23=0
            zwave_device.capabilities=[106,112,114,128,134,135]
            zwave_device.endpoint=0
            zwave_device.failed=false
            zwave_device.generic_class="Multilevel Switch"
            zwave_device.impl_sig="23326:1:23260:1"
            zwave_device.is_beaming=false
            zwave_device.is_listening=false
            zwave_device.is_routing=true
            zwave_device.is_secure=true
            zwave_device.manufacturer_info=[647,4,114]
            zwave_device.node_id=80
            zwave_device.specific_class="Motor Control Class C"
            zwave_device.status=4
            zwave_device.version_info=[null,"3.12.1"]
              So is it 80 or 81 that's not staying in the expected state?
                80, which is the second one
                  Can you command 80 from the Entities list using the same actions and values?
                    Yes, it opens to 50% using position.set .50
                    When I use the reaction, it does change to .5, but then changes back after 20 or 30 seconds.
                      Is there a rule that could be triggered by the shade moving that's still active?
                        I don't believe so. I believe I would see other rules flashing active/green, were that to happen. If that was the case, manually doing it either through HA or through the entities tab, like you just had me do, would cause that reaction as well.
                        BTW, that was one of the first things I thought of. I had two separate reactor windows open, so I could monitor the Reactions tab, as well as the Blinds Rule Set rules simultaneously.
                          Perhaps, but there's no command setting to closed in that reaction, either.
                          Another way to look at this is to open a second tab for Reactor, and stay on the Status page with the Running Reactions widget displayed. If the blind closes after the Reaction has stopped running, that suggests the command to close it is coming from elsewhere.
                          And of course, any time things don't look as expected, you should always be looking in the logs.
                          Edit: based on your edit, I'd make sure all rules doing anything with blinds are disabled during this testing.
                            WAIT -- WHAT'S THIS???
                              @toggledbits,
                              That would be me dying of embarrassment. I'm not sure how that got there.
                              Removed and surprise surprise, works fine.
                                Whew! All good!
                                  Best thread ever given I have 13 iblinds and they get... cranky/fussy.
                                  I'm going to pile onto the "wait, I never knew about Repeat While - when was this added @toggledbits ?
                                    #22
                                    @gwp1 said in Fail safe condition for battery devices:
                                    I'm going to say they been a lot less cranky since I added the dead node routine. It's not strictly for iBlinds, but the battery powered devices are the ones that tend to not report in quite as regularly.
                                    I also have a notification routine that sends me push notifications when battery level is below 35%. This used to be a huge problem when I ran Vera and the original iBlinds. Battery readings would go from 80% to dead overnight. Not so much a problem anymore with HA and the 3.1 version of iBlinds.
                                    This whole thread came up, because I got tired of walking into a room, and wondering if my wife closed a blind on purpose, or if the routine that opens them failed in some manner. I'm hoping this will reduce my questioning.
                                    • T tamorgen
                                      Build 22023... two and a half years ago. 🙂
                                      In fairness, though, it was advertised as "experimental" in the release notes, and I never did make another note to clear that status, so by the power vested in me by the Universal Life Church of Stockton, California USA, I hearby bless it.
                                        @toggledbits Praise be to He!
                                          @tamorgen @toggledbits is it better to use cover.open and cover.close or postion.set=.5 and 0/.99?
                                          I'm noticing this morning after moving my open/close Reactions to Repeat While that the iblinds will "settle"... ie, land on .52 and then retry for the next few minutes until settling on .51 as "open".
                                            159.4k
