Happy new year, everyone! Hope all are well!
Looking for some pointers troubleshooting a slightly puzzling to me issue. When digging around on a different issue I noticed this happening regularly in the MSR logs:
[latest-24366]2025-01-10T19:50:07.630Z <Engine:NOTICE> Starting reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) [latest-24366]2025-01-10T19:50:07.630Z <VeraController:INFO> VeraController#vera perform action power_switch.on on Switch#vera>device_20060 with [Object]{ } [latest-24366]2025-01-10T19:50:07.630Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20060 with [Object]{ "state": true } [latest-24366]2025-01-10T19:50:07.670Z <VeraController:NOTICE> VeraController#vera action power_switch.set([Object]{ "state": true }) on Switch#vera>device_20060 succeeded [latest-24366]2025-01-10T19:50:07.671Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 1 [latest-24366]2025-01-10T19:50:07.672Z <Engine:NOTICE> Garden lights on when the doors are open<SET> delaying until 1736538787672<10/01/2025, 19:53:07> [latest-24366]2025-01-10T19:50:19.595Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from SET to RESET! [latest-24366]2025-01-10T19:52:16.506Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from RESET to SET! [latest-24366]2025-01-10T19:52:16.515Z <Engine:INFO> [Engine]Engine#1 not enqueueing rule-lb2h69nb:S: already in queue with status 2 [latest-24366]2025-01-10T19:52:20.823Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) evaluated; rule state transition from SET to RESET! [latest-24366]2025-01-10T19:53:07.676Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 2 [latest-24366]2025-01-10T19:53:07.677Z <VeraController:INFO> VeraController#vera perform action power_switch.off on Switch#vera>device_20060 with [Object]{ } [latest-24366]2025-01-10T19:53:07.678Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20060 with [Object]{ "state": false } [latest-24366]2025-01-10T19:53:07.719Z <VeraController:NOTICE> VeraController#vera action power_switch.set([Object]{ "state": false }) on Switch#vera>device_20060 succeeded [latest-24366]2025-01-10T19:53:07.720Z <Engine:INFO> Resuming reaction Garden lights on when the doors are open<SET> (rule-lb2h69nb:S) from step 3 [latest-24366]2025-01-10T19:53:07.721Z <Engine:INFO> Garden lights on when the doors are open<SET> all actions completed. [latest-24366]2025-01-10T19:55:04.468Z <VeraController:ERR> VeraController#vera update request failed: [FetchError] network timeout at: http://192.168.70.249:3480/data_request?id=status&Timeout=15&DataVersion=416912953&MinimumDelay=50&output_format=json&_r=1736538886459 [-] [latest-24366]2025-01-10T19:55:09.646Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-] [latest-24366]2025-01-10T19:55:09.646Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.646Z <VeraController:CRIT> *Entity#vera>device_20050 [latest-24366]2025-01-10T19:55:09.656Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-] [latest-24366]2025-01-10T19:55:09.656Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.656Z <VeraController:CRIT> *Entity#vera>device_20570 [latest-24366]2025-01-10T19:55:09.678Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-] [latest-24366]2025-01-10T19:55:09.679Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.679Z <VeraController:CRIT> *Entity#vera>device_20610 [latest-24366]2025-01-10T19:55:09.744Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-] [latest-24366]2025-01-10T19:55:09.744Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.744Z <VeraController:CRIT> *Entity#vera>device_20631 [latest-24366]2025-01-10T19:55:09.889Z <VeraController:NOTICE> VeraController#vera reload detected! [latest-24366]2025-01-10T19:55:09.910Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-] [latest-24366]2025-01-10T19:55:09.910Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.910Z <VeraController:CRIT> *Entity#vera>device_20050 [latest-24366]2025-01-10T19:55:09.935Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-] [latest-24366]2025-01-10T19:55:09.936Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.936Z <VeraController:CRIT> *Entity#vera>device_20570 [latest-24366]2025-01-10T19:55:09.937Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-] [latest-24366]2025-01-10T19:55:09.937Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.937Z <VeraController:CRIT> *Entity#vera>device_20610 [latest-24366]2025-01-10T19:55:09.939Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-] [latest-24366]2025-01-10T19:55:09.939Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.939Z <VeraController:CRIT> *Entity#vera>device_20631 [latest-24366]2025-01-10T19:55:09.968Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged [latest-24366]2025-01-10T19:55:10.037Z <VeraController:NOTICE> VeraController#vera reload detected!That repeats until something like this:
[latest-24366]2025-01-10T19:55:10.049Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20050: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20050) [-] [latest-24366]2025-01-10T19:55:10.049Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:10.049Z <VeraController:CRIT> *Entity#vera>device_20050 [latest-24366]2025-01-10T19:55:10.053Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20570: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20570) [-] [latest-24366]2025-01-10T19:55:10.053Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:10.053Z <VeraController:CRIT> *Entity#vera>device_20570 [latest-24366]2025-01-10T19:55:10.062Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20610: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20610) [-] [latest-24366]2025-01-10T19:55:10.062Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:10.062Z <VeraController:CRIT> *Entity#vera>device_20610 [latest-24366]2025-01-10T19:55:10.112Z <VeraController:WARN> VeraController#vera failed to apply attribute scene_activation.scene_id to Entity#vera>device_20631: [TypeError] Can't set NaN on attribute scene_activation.scene_id (vera>device_20631) [-] [latest-24366]2025-01-10T19:55:10.112Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:10.113Z <VeraController:CRIT> *Entity#vera>device_20631 [latest-24366]2025-01-10T20:00:05.003Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "10/01/2025 20:00:05" (TZ offset 0 mins from UTC) [latest-24366]2025-01-10T20:13:51.872Z <Rule:INFO> No motion in Cinema (rule-m4ocglke in Cinema Environment) evaluated; rule state transition from SET to RESET! [latest-24366]2025-01-10T20:13:51.882Z <Rule:INFO> Cinema Heater On (rule-m4ocf1di in Cinema Environment) evaluated; rule state transition from RESET to SET! [latest-24366]2025-01-10T20:13:51.888Z <Engine:INFO> Enqueueing "Cinema Heater On<SET>" (rule-m4ocf1di:S)And the errors / reloads just stop.
From Openluup:
2025-01-10 19:49:56.379 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2025-01-10 19:50:00.085 luup_log:0: 14Mb, 1.7%cpu, 36.1days 2025-01-10 19:50:07.591 luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.KWH was: 18.6793008 now: 18.6805008 #hooks:0 2025-01-10 19:50:07.591 luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0 2025-01-10 19:50:07.591 luup.variable_set:: 20160.urn:micasaverde-com:serviceId:EnergyMetering1.Watts was: 7.4 now: 7.3 #hooks:0 2025-01-10 19:50:07.591 luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.KWH was: 32.2417984 now: 32.2470016 #hooks:0 2025-01-10 19:50:07.591 luup.variable_set:: 20170.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0 2025-01-10 19:50:07.591 luup.variable_set:: 20330.urn:micasaverde-com:serviceId:EnergyMetering1.KWHReading was: 1736538000 now: 1736538600 #hooks:0 2025-01-10 19:50:07.592 luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2025-01-10 19:50:07.592 luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736534850 now: 1736538607 #hooks:0 2025-01-10 19:50:07.593 openLuup.server:: request completed (3392 bytes, 1 chunks, 12875 ms) tcp{client}: 0x55c3299a9cf8 2025-01-10 19:50:07.618 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3299a9cf8 2025-01-10 19:50:07.624 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329d0a5b8 2025-01-10 19:50:07.624 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912906&MinimumDelay=50&output_format=json&_r=1736538607623 HTTP/1.1 tcp{client}: 0x55c329d0a5b8 2025-01-10 19:50:07.632 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3292ed678 2025-01-10 19:50:07.633 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20060&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1736538607631 HTTP/1.1 tcp{client}: 0x55c3 292ed678 2025-01-10 19:50:07.633 luup.call_action:: 20060.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2025-01-10 19:50:07.633 luup.call_action:: action will be handled by parent: 37 2025-01-10 19:50:07.633 luup.variable_set:: 20060.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0 2025-01-10 19:50:07.669 openLuup.server:: request completed (35 bytes, 1 chunks, 35 ms) tcp{client}: 0x55c3292ed678 2025-01-10 19:50:07.673 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3292ed678 2025-01-10 19:50:07.776 openLuup.server:: request completed (821 bytes, 1 chunks, 151 ms) tcp{client}: 0x55c329d0a5b8 2025-01-10 19:50:07.784 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329d0a5b8 2025-01-10 19:50:07.795 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3287bc8f8 2025-01-10 19:50:07.796 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912907&MinimumDelay=50&output_format=json&_r=1736538607794 HTTP/1.1 tcp{client}: 0x55c3287bc8f8 2025-01-10 19:50:08.644 luup.variable_set:: 20060.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0 2025-01-10 19:50:08.950 openLuup.server:: request completed (821 bytes, 1 chunks, 1154 ms) tcp{client}: 0x55c3287bc8f8 2025-01-10 19:50:08.958 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3287bc8f8 2025-01-10 19:50:08.969 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3297e95a8 2025-01-10 19:50:08.970 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912908&MinimumDelay=50&output_format=json&_r=1736538608969 HTTP/1.1 tcp{client}: 0x55c3297e95a8 2025-01-10 19:50:19.181 luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:0 2025-01-10 19:50:19.585 openLuup.server:: request completed (832 bytes, 1 chunks, 10615 ms) tcp{client}: 0x55c3297e95a8 2025-01-10 19:50:19.602 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3297e95a8 2025-01-10 19:50:19.605 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328d298a8 2025-01-10 19:50:19.605 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912909&MinimumDelay=50&output_format=json&_r=1736538619604 HTTP/1.1 tcp{client}: 0x55c328d298a8 2025-01-10 19:50:34.950 openLuup.server:: request completed (593 bytes, 1 chunks, 15344 ms) tcp{client}: 0x55c328d298a8 2025-01-10 19:50:34.953 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328d298a8 2025-01-10 19:50:34.965 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328c48a58 2025-01-10 19:50:34.966 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912909&MinimumDelay=50&output_format=json&_r=1736538634964 HTTP/1.1 tcp{client}: 0x55c328c48a58 2025-01-10 19:50:34.989 luup.variable_set:: 25019.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2025-01-10 19:50:34.990 luup.variable_set:: 25019.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736534437 now: 1736538634 #hooks:0 2025-01-10 19:50:35.094 openLuup.server:: request completed (975 bytes, 1 chunks, 127 ms) tcp{client}: 0x55c328c48a58 2025-01-10 19:50:35.101 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328c48a58 2025-01-10 19:50:35.113 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32985e298 2025-01-10 19:50:35.113 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912911&MinimumDelay=50&output_format=json&_r=1736538635111 HTTP/1.1 tcp{client}: 0x55c32985e298 2025-01-10 19:50:40.255 luup.variable_set:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel was: 0 now: 30 #hooks:1 2025-01-10 19:50:40.256 scheduler.watch_callback:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel called [20]DataWatcherCallback() function: 0x55c3288a8d20 2025-01-10 19:50:40.460 openLuup.server:: request completed (835 bytes, 1 chunks, 5346 ms) tcp{client}: 0x55c32985e298 2025-01-10 19:50:40.472 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32985e298 2025-01-10 19:50:40.478 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329b28238 2025-01-10 19:50:40.479 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912912&MinimumDelay=50&output_format=json&_r=1736538640478 HTTP/1.1 tcp{client}: 0x55c329b28238 2025-01-10 19:50:44.471 luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:1 2025-01-10 19:50:44.472 luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736538400 now: 1736538644 #hooks:0 2025-01-10 19:50:44.472 scheduler.watch_callback:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [20]DataWatcherCallback() function: 0x55c3288a8d20 2025-01-10 19:50:44.775 openLuup.server:: request completed (975 bytes, 1 chunks, 4296 ms) tcp{client}: 0x55c329b28238 2025-01-10 19:50:44.775 openLuup.server:: request completed (975 bytes, 1 chunks, 4296 ms) tcp{client}: 0x55c329b28238 2025-01-10 19:50:44.782 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329b28238 2025-01-10 19:50:44.793 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328f1e968 2025-01-10 19:50:44.793 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538644791 HTTP/1.1 tcp{client}: 0x55c328f1e968 2025-01-10 19:51:00.122 openLuup.server:: request completed (593 bytes, 1 chunks, 15328 ms) tcp{client}: 0x55c328f1e968 2025-01-10 19:51:00.125 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328f1e968 2025-01-10 19:51:00.136 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32995b318 2025-01-10 19:51:00.136 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538660134 HTTP/1.1 tcp{client}: 0x55c32995b318 2025-01-10 19:51:15.481 openLuup.server:: request completed (593 bytes, 1 chunks, 15344 ms) tcp{client}: 0x55c32995b318 2025-01-10 19:51:15.484 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32995b318 2025-01-10 19:51:15.495 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32998b068 2025-01-10 19:51:15.497 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538675493 HTTP/1.1 tcp{client}: 0x55c32998b068 2025-01-10 19:51:30.869 openLuup.server:: request completed (593 bytes, 1 chunks, 15371 ms) tcp{client}: 0x55c32998b068 2025-01-10 19:51:30.872 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32998b068 2025-01-10 19:51:30.884 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c32905bda8 2025-01-10 19:51:30.885 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912914&MinimumDelay=50&output_format=json&_r=1736538690882 HTTP/1.1 tcp{client}: 0x55c32905bda8 2025-01-10 19:51:32.886 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21 now: 22 #hooks:0 2025-01-10 19:51:33.090 openLuup.server:: request completed (841 bytes, 1 chunks, 2205 ms) tcp{client}: 0x55c32905bda8 2025-01-10 19:51:33.100 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c32905bda8 2025-01-10 19:51:33.112 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328de0d58 2025-01-10 19:51:33.112 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912915&MinimumDelay=50&output_format=json&_r=1736538693111 HTTP/1.1 tcp{client}: 0x55c328de0d58 2025-01-10 19:51:36.064 luup.variable_set:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:1 2025-01-10 19:51:36.065 scheduler.watch_callback:: 25007.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped called [20]DataWatcherCallback() function: 0x55c3288a8d20 2025-01-10 19:51:36.369 openLuup.server:: request completed (832 bytes, 1 chunks, 3256 ms) tcp{client}: 0x55c328de0d58 2025-01-10 19:51:36.377 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328de0d58 2025-01-10 19:51:36.387 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329054188 2025-01-10 19:51:36.388 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912916&MinimumDelay=50&output_format=json&_r=1736538696386 HTTP/1.1 tcp{client}: 0x55c329054188 2025-01-10 19:51:37.134 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0 2025-01-10 19:51:37.540 openLuup.server:: request completed (841 bytes, 1 chunks, 1152 ms) tcp{client}: 0x55c329054188 2025-01-10 19:51:37.553 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329054188 2025-01-10 19:51:37.566 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328d97568 2025-01-10 19:51:37.566 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912917&MinimumDelay=50&output_format=json&_r=1736538697564 HTTP/1.1 tcp{client}: 0x55c328d97568 2025-01-10 19:51:41.367 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21 now: 22 #hooks:0 2025-01-10 19:51:41.874 openLuup.server:: request completed (841 bytes, 1 chunks, 4307 ms) tcp{client}: 0x55c328d97568 2025-01-10 19:51:41.884 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c328d97568 2025-01-10 19:51:41.895 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329385678 2025-01-10 19:51:41.896 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912918&MinimumDelay=50&output_format=json&_r=1736538701894 HTTP/1.1 tcp{client}: 0x55c329385678 2025-01-10 19:51:57.168 openLuup.server:: request completed (593 bytes, 1 chunks, 15272 ms) tcp{client}: 0x55c329385678 2025-01-10 19:51:57.171 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329385678 2025-01-10 19:51:57.183 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329b092b8 2025-01-10 19:51:57.184 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912918&MinimumDelay=50&output_format=json&_r=1736538717182 HTTP/1.1 tcp{client}: 0x55c329b092b8 2025-01-10 19:52:00.124 luup_log:0: 14Mb, 1.6%cpu, 36.1days 2025-01-10 19:52:00.476 openLuup.server:: request completed (1841 bytes, 1 chunks, 3292 ms) tcp{client}: 0x55c329b092b8 2025-01-10 19:52:00.483 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329b092b8 2025-01-10 19:52:00.495 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c3297be088 2025-01-10 19:52:00.495 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912929&MinimumDelay=50&output_format=json&_r=1736538720494 HTTP/1.1 tcp{client}: 0x55c3297be088 2025-01-10 19:52:09.867 luup.variable_set:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel was: 30 now: 0 #hooks:1 2025-01-10 19:52:09.868 scheduler.watch_callback:: 25021.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel called [20]DataWatcherCallback() function: 0x55c3288a8d20 2025-01-10 19:52:10.071 openLuup.server:: request completed (834 bytes, 1 chunks, 9575 ms) tcp{client}: 0x55c3297be088 2025-01-10 19:52:10.079 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c3297be088 2025-01-10 19:52:10.088 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c329c16a08 2025-01-10 19:52:10.089 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=416912930&MinimumDelay=50&output_format=json&_r=1736538730087 HTTP/1.1 tcp{client}: 0x55c329c16a08 2025-01-10 19:52:16.194 luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2025-01-10 19:52:16.195 luup.variable_set:: 20770.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1736538607 now: 1736538736 #hooks:0 2025-01-10 19:52:16.498 openLuup.server:: request completed (976 bytes, 1 chunks, 6409 ms) tcp{client}: 0x55c329c16a08 2025-01-10 19:52:16.515 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55c329c16a08 2025-01-10 19:52:16.516 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x55c328dbad18Nothing I can see indicating that Openluup is reloading?
.249 IP address is the internal IP of the NUC that hosts both Openluup and MSR.
Any thoughts as to how I can troubleshoot this? It's not a big deal, but would like to get to the bottom of it.
I should add that all the devices listed in entries like this:
[latest-24366]2025-01-10T19:55:09.744Z <VeraController:INFO> VeraController#vera class scene_controller meta [Object]{ "source": "urn:micasaverde-com:serviceId:SceneController1/sl_SceneActivated", "expr": "int(value)" } orig final NaN [latest-24366]2025-01-10T19:55:09.744Z <VeraController:CRIT> *Entity#vera>device_20631Are the tamper switches on Fibaro FGMS001 multifunction detectors, of which I have 4, and they correspond exactly to the devices listed.
TIA
Home Automation means you have to have a way of describing the logical steps you want your home to implement automatically.
Whilst I've always been a fan of the Lua language, as used in Vera (and openLuup) for scenes and plugins, it's perhaps not ideal. For this reason, there has been a long development history of plugins with their own "language" to help define the automation logic: PLEG (for those with a long memory), AltUI workflows, Rules Engine, Reactor, MSR, ...
It's always seemed to me that the 'best' way of describing logic would be a language designed for that purpose – a "logic programming language". Perhaps one of the most famous, and venerable, is Prolog, which had its fiftieth birthday last year in 2022.
Thanks to some relatively recent research A Hitchhiker’s Guide to Reinventing a Prolog Machine, Paul Tarau (2017) it's become possible to implement a very efficient Prolog engine in a reasonably concise way. So, just for fun, I'm developing a CGI plugin for describing openLuup actions in Prolog.
I have an early prototype running (written in Lua, of course). It presents a web page which looks like a fairly typical Interactive Development Environment (IDE) and contains some primitives which allow basic access to the Luup engine.
In a subsequent post, I'll give a glimpse of its capabilities...
On start up the log indicates the following:
2023-12-19 10:17:12.588 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelTarget","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelStatus","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","LoadLevelLast","",209) old value "" 2023-12-19 10:17:12.589 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","TurnOnBeforeDim","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:upnp-org:serviceId:Dimming1","AllowZeroLevel","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](setVar@104):setVar("urn:bochicchio-com:serviceId:VirtualBinaryLight1","SetBrightnessURL","",209) old value "" 2023-12-19 10:17:12.590 luup_log:209: VirtualDevices[3.0-beta7@209](initializeMqtt@421):initializeMqtt(209,{ PowerStatusOff={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" }, BrightnessValue={ Variable="LoadLevelStatus", Service="urn:upnp-org:serviceId:Dimming1" }, PowerStatusOn={ Value="1", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) - openLuup: true 2023-12-19 10:17:12.591 luup_log:209: VirtualDevices[3.0-beta7@209](subscribeToMqtt@414):subscribeToMqtt(209,nil,{ deviceID=209, opts={ Value="0", Service="urn:upnp-org:serviceId:SwitchPower1", Variable="Status" } }) 2023-12-19 10:17:12.591 openLuup.context_switch:: ERROR: [dev #209] ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value) 2023-12-19 10:17:12.591 openLuup.scheduler:: job aborted : ./L_VirtualLibrary.lua:415: attempt to concatenate field 'topic' (a nil value)The MQTT variables are all set to "skip":
MQTT_BrightnessValue
MQTT_PowerStatusOff
MQTT_PowerStatusOn
However it looks like the code doesn't check for "skip" and executes the functions initializeMqtt() and subscribeToMqtt() disappearing into the weeds at that point as there is nothing to subscribe to.
It would also be good if the code treated an empty string in the same way as it uses the key word "skip". It's not obvious that "skip" needs to be explicitly used.
I still use Vera controllers in combination with ReactorSensors. I have several Reactor sensors in use to retrieve weather data from Wunderground (i have a personal weather station), my smartmeter etc.
Recently I installed solar panels with a SolarEdge inverter. SolarEdge has an API to retrieve my power production data from their cloud.
Output is in json.
So I created a new Reactor Sensor. Connection is working (query okay).
But I encounter problems at the Value Expressions. Either I get ""query okay" but no data or I get "query okay but 1 expressions failed"
This is the json output
{"overview":{"lastUpdateTime":"2023-05-12 10:45:57","lifeTimeData":{"energy":476310.0,"revenue":216.577},"lastYearData":{"energy":433001.0},"lastMonthData":{"energy":433001.0},"lastDayData":{"energy":8262.0},"currentPower":{"power":5647.0},"measuredBy":"INVERTER"}}So it has different layers/levels.
I tried to put in the Value Expressions field several combinations to get the energy data of today (8262.0), like:
response.lastDayData.energy
response.overview.lastDayData.energy
response.overview.lastUpdateTime.lastDayData.energy
all fail...
Who can help me with this ?
I have the following issue: In my Vera, I have created a dimmer using the Switchboard plugin. I want this light always turn on at 100% brightness when turn the light on. By default, the dimmer remembers its last used setting. I have created the following scene: when the light is turned off, the LoadLevelLast should be 100.
Manually, this works through the test Luup code (Lua), but not through the scene's action by execute the following Luup code.
I also tried in MSR, but no result
Does anyone know the solution to this?
Just seen notification to Netatmo developers that the current password-based login is being disabled as from October.
Oath2 is now a requirement for apps needing access to Netatmo. This will require some changes to my venerable plug-in. I’m not sure how easy this will be with the current libraries in use.
Does anyone out there use the Netatmo plug-in?
Does anyone have any advice on using Oath2?
Hardly a big deal, and likely user error. Bare metal install on Debian Bullseye
Observed behaviour:
TTS announcements are made with the correct volume. So a message to group 'Everywhere' with Volume 40 is announced. Asking an individual echo device to state its volume after the announcement gets the response 'This device is at volume 4'
So far so good.
Using the:
x_vera_svc_bochicchio_com_VeraAlexa1.SetVolumeIn an MSR reaction appears to have no impact when either applied to the group 'Everywhere' or a specific device.
So executing this reaction:
Is acknowledged by the device (with a 'beep') and shows the Lua Log below:
2023-01-31 09:21:45.778 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399831f8 2023-01-31 09:21:45.779 openLuup.server:: GET /data_request?GroupZones=Office&DesiredVolume=10&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=SetVolume&output_format=json&_r=1675156905777 HTTP/1.1 tcp{client}: 0x5572399831f8 2023-01-31 09:21:45.780 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.SetVolume 2023-01-31 09:21:51.670 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s>Volume Set</s><break time="0s" /> to dev:Office type:A32DOYMUN6DTXA serial:G090U50991550NLS cu... now: sending cmd:vol:10 to dev:Office type:A32DOYMUN6DTXA serial:G090U50991550NLS customerid:A1CVTZEBJIUFJI #hooks:0 2023-01-31 09:21:51.671 openLuup.server:: request completed (35 bytes, 1 chunks, 5891 ms) tcp{client}: 0x5572399831f8 2023-01-31 09:21:51.683 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5572399831f8 2023-01-31 09:21:51.685 openLuup.server:: request completed (930 bytes, 1 chunks, 42818 ms) tcp{client}: 0x557239726708 2023-01-31 09:21:51.687 openLuup.server:: request completed (930 bytes, 1 chunks, 42548 ms) tcp{client}: 0x5572392c0fd8 2023-01-31 09:21:51.688 openLuup.server:: request completed (930 bytes, 1 chunks, 12501 ms) tcp{client}: 0x5572392c7f88 2023-01-31 09:21:51.692 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x5572392c7f88 2023-01-31 09:21:51.704 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239be10b8 2023-01-31 09:21:51.704 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66666322&MinimumDelay=50&output_format=json&_r=1675156911703 HTTP/1.1 tcp{client}: 0x557239be10b8 2023-01-31 09:21:51.905 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66666322&Timeout=60&MinimumDelay=1500&_=1675022474387 HTTP/1.1 tcp{client}: 0x5572392c0fd8 2023-01-31 09:21:53.042 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66666322&Timeout=60&MinimumDelay=1500&_=1675079237873 HTTP/1.1 tcp{client}: 0x557239726708However direct interrogation of the device reveals the volume has not changed.
I assume I'm doing something wrong or not understanding how this is meant to work?
One other observation is that messages announce to the 'Everywhere' group appear to make the volume 'stick' where as messages to an individual device appear to revert to the previous volume setting.
My expectation would be analagous to a radio i.e. the volume stays as it was last set, but happy to be corrected.
TIA!
Anyone else seeing issues with Vera TTS? All was working fine. I assumed the cookie had expired, but even having replaced it, and seeing that the .alexa.login file is aging (as I'd expect) No speech.
I seem to be getting an odd timeout but no idea from where.
Debian Bullseye, bare metal
Good call from this morning:
2023-01-18 08:22:51.657 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a2345e8 2023-01-18 08:22:51.667 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:51.668 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085221&MinimumDelay=50&output_format=json&_r=1674030171666 HTTP/1.1 tcp{client}: 0x563e89df13d8 2023-01-18 08:22:58.223 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.223 openLuup.server:: GET /data_request?Text=Rachel%20has%20arrived%20at%20Washtec&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action= Say&output_format=json&_r=1674030178221 HTTP/1.1 tcp{client}: 0x563e8a4ab388 2023-01-18 08:22:58.224 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 08:22:58.224 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 08:23:09.379 luup.variable_set:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.LatestResponse was: sending cmd:speak:<s><lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is -3 degr... now: sendi ng cmd:speak:<s>Rachel has arrived at Washtec</s><break time="0s" /> to dev:Everywhere type:A3C9PE6TNYLTCH ser... #hooks:0 2023-01-18 08:23:09.381 openLuup.server:: request completed (29 bytes, 1 chunks, 11156 ms) tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0 2023-01-18 08:23:09.391 luup.variable_set:: 25001.urn:micasaverde-com:serviceId:SecuritySensor1.LastTrip was: 1674030032 now: 1674030189 #hooks:0 2023-01-18 08:23:09.394 openLuup.server:: request completed (1389 bytes, 1 chunks, 31782 ms) tcp{client}: 0x563e897eefd8 2023-01-18 08:23:09.395 openLuup.server:: request completed (1389 bytes, 1 chunks, 31662 ms) tcp{client}: 0x563e8a7c5248 2023-01-18 08:23:09.396 openLuup.server:: request completed (1389 bytes, 1 chunks, 17728 ms) tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.396 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a4ab388 2023-01-18 08:23:09.411 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.412 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e89df13d8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?newTargetValue=1&DeviceNum=20330&id=action&serviceId=urn%3Aupnp-org%3AserviceId%3ASwitchPower1&action=SetTarget&output_format=json&_r=1674030189410 HTTP/1.1 tcp{client}: 0x563e 8a13f3c8 2023-01-18 08:23:09.413 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=31085224&MinimumDelay=50&output_format=json&_r=1674030189411 HTTP/1.1 tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.413 luup.call_action:: 20330.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2023-01-18 08:23:09.413 luup.call_action:: action will be handled by parent: 37 2023-01-18 08:23:09.413 luup.variable_set:: 20330.urn:upnp-org:serviceId:SwitchPower1.Target was: 1 now: 1 #hooks:0 2023-01-18 08:23:09.449 openLuup.server:: request completed (35 bytes, 1 chunks, 36 ms) tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.461 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a13f3c8 2023-01-18 08:23:09.564 openLuup.server:: request completed (819 bytes, 1 chunks, 151 ms) tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.569 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x563e8a79f3c8 2023-01-18 08:23:09.581 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x563e8a32bf28Bad request from just now:
2023-01-18 18:29:26.695 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.696 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066566691 HTTP/1.1 tcp{client}: 0x557239889e58 2023-01-18 18:29:26.799 openLuup.server:: request completed (833 bytes, 1 chunks, 2249 ms) tcp{client}: 0x557239a62f78 2023-01-18 18:29:26.911 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674030721531 HTTP/1.1 tcp{client}: 0x5572385f78d8 2023-01-18 18:29:27.028 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 openLuup.server:: GET /data_request?Text=Testing...1...2...3&Language=en-GB&GroupZones=Everywhere&Volume=50&DeviceNum=22&id=action&serviceId=urn%3Abochicchio-com%3AserviceId%3AVeraAlexa1&action=Say&output_format=json&_r=1674066567027 HTTP/1.1 tcp{client}: 0x557238b98c58 2023-01-18 18:29:27.029 luup.call_action:: 22.urn:bochicchio-com:serviceId:VeraAlexa1.Say 2023-01-18 18:29:27.029 luup_log:22: VeraAlexa: addToQueue: added to queue for 22 2023-01-18 18:29:43.149 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 29 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.150 openLuup.server:: ...only 0 bytes sent 2023-01-18 18:29:43.150 openLuup.server:: request completed (29 bytes, 1 chunks, 16121 ms) tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: device is not a sensor or if a sensor; is not coded for 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: veraId: 64, blId: a0:43:b0:8b:e0:e5, altId: a0:43:b0:8b:e0:e5_ir 2023-01-18 18:29:43.153 luup_log:63: BroadLink_Mk2 debug: RM3 Mini - IR 1: urn:schemas-micasaverde-com:device:IrTransmitter:1 2023-01-18 18:29:43.154 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=66503545&Timeout=60&MinimumDelay=1500&_=1674066518681 HTTP/1.1 tcp{client}: 0x557239a62f78 2023-01-18 18:29:43.155 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557238b98c58 2023-01-18 18:29:43.157 openLuup.server:: request completed (591 bytes, 1 chunks, 16460 ms) tcp{client}: 0x557239889e58 2023-01-18 18:29:43.161 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557239889e58 2023-01-18 18:29:43.175 openLuup.io.server:: HTTP:3480 connection from 192.168.70.249 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:43.176 openLuup.server:: GET /data_request?id=status&Timeout=15&DataVersion=66503545&MinimumDelay=50&output_format=json&_r=1674066583172 HTTP/1.1 tcp{client}: 0x5572399f30e8 2023-01-18 18:29:57.979 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 21 #hooks:0Any thoughts?
Cheers
I use the excellent SiteSensor plugin of @toggledbits for some years to get the data from my PWS on Wunderground.
This has worked flawlessly but recently it suddenly stopped working.
I see this in my Vera:
When I copy/paste the URL code to be queried in my browser this still works.
This is the URL:
https://api.weather.com/v2/pws/observations/current?stationId=ILIMBURG130&format=json&units=m&numericPrecision=decimal&apiKey=xxxxxxxxxxxxxxxxxxxxxxxxx
Patrick (or someone else on this forum) can you help me solve this ?
Many thanks in advance!
Virtual HTTP Devices plug-in:
I wanted to try this out. Installed the plugin and created one device, which came up as a light bulb. So far so good. In AltUI I clicked on the On/Off slider on the page. The log shows that the Target is set to one. Likewise for the Variable list in AltUI. However the Status never gets set to one and the light bulb icon doesn't go yellow.
In some plugins you set the Target and then the plugin checks the physical device actually went on by checking an actual status report from the device, which can be used to set the variable Status.
In other cases a plugin will send a message to the physical device but that device will have no status feedback mechanism available. So the Status variable has to be set locally when the Target is set and everybody hopes the physical device all worked.
Not to sure what Virtual HTTP Devices plug-in does in this regard? Does the above go in anyway to explaining what I'm seeing? Is the plugin looking for status feedback?
I have a couple of issue with Openluup ATM. I'm going to work through them in the order that they appeared if that's OK 🙂
OpenLuup on bare metal (Debian Bullseye) running Z-way server and Z-wave.me
Issue:
I deleted a (I think) virtual switch in OpenLuup
Now when I call up all devices I have this in a 'tile'
And below (in room 101)
ReferenceError: nil is not defined at eval (eval at evaluateConditions (http://192.168.70.249:3480/J_ALTUI_verabox.js:960:18), :1:1) at Object.evaluateConditions (J_ALTUI_verabox.js:960:18) at Object._evaluateConditions [as evaluateConditions] (J_ALTUI_verabox.js:1642:37) at Object._evaluateConditions [as evaluateConditions] (J_ALTUI_multibox.js:629:89) at Object. (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2572:23) at Function.each (https://cdnjs.cloudflare.com/ajax/libs/jquery/3.5.1/jquery.min.js:2:2976) at _getDeviceIconPath (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2569:10) at _deviceIconHtml (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2739:18) at _internalDeviceDraw (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2765:19) at _deviceDraw (http://192.168.70.249:3480/J_ALTUI_uimgr.js:2840:4)Any ideas from anyone?
Full reboot has been done....
Cheers
I've been trying to figure out Reactor but I'm not very good at programming.
I have two scenes in VERA.
One scene should only run during the DAY and then stop running.
One scene should only run during the NIGHT and then stop running.
My scenes start off at the right times, but they do not turn off. I created a Sunrise/Sunset Reactor trigger and added it as a condition to each of my scenes.
However, the Reactor trigger when tripping or untripping does not prevent my Vera scenes from running. It will start them correctly the first day, but after that, both scene stay running and fight with each other. What am I doing wrong?
Thanks for any help!
If you are interested, here are the actions I wish to perform with each scene.
FARM STAND - DAY (runs at Sunrise)
Turn ON a device called LETTUCE LAMP2a) Every 60 min, turn ON a device called LETTUCE PUMP
2b) Wait 15 min then turn OFF a device called LETTUCE PUMP
FARM STAND - NIGHT (runs at Sunset)
Turn OFF a device called LETTUCE LAMP2a) Every 135 min, turn ON a device called LETTUCE PUMP
This sounds simple, but I cannot figure out how to disable these scenes when the theyre not supposed to run.
I am no longer using any VERA scenes. I am only using a REACTOR trigger and activities.
Will my activities do what I need them to do? See below:
Here's what I am trying to accomplish:
AT SUNRISE
Turn ON a light called LETTUCE LAMP and keep it ON.2a) Turn on a device called LETTUCE PUMP for 15 min each hour.
2b) Repeat the pump cycle all day long.
AT SUNSET
Turn OFF a light called LETTUCE LAMP and keep it OFF.2a) Turn on a device called LETTUCE PUMP for 15 min then wait 2 hours..
2b) Repeat the pump cycle all night long.
Good evening, all.
Is there a simple readme to set up and use a Broadlink device with OpenLuup?
The readme on github points to a thread on the old forum, and thence to a rabbit hole.
Is it just a case of adding IP address of the device? Or does it need the MAC?
Then how do I fire commands? It looks like I need to find the codes and send via Lua?
TIA
Hi Patrick,
A quick question about your virtual sensor plugin. I saw that the child sensors rely on polling for sensor data updates. Was there a reason not to use a watch on the underlying (source) state variable as opposed to polling. I'm asking in the sense that I need a fairly rapid response to a rise in humidity, but am unsure how to set sensor polling without adding additional io drag to openLuup.
I currently use the state humidity variable directly in a reactor sensor (the data is captured via a bluetooth device with multiple humidity variables), however, these state humidity variables have a generated name making it difficult to determine what is what in group of approximately 10 state humidity variables. So a virtual sensor solves the naming problem, while creating some trigger delay due to polling.
Thx
Openluup reloads
From Openluup:
TIA
