  4. [SOLVED]Logs permissions for Docker Install
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
8 Posts 2 Posters 1.5k Views 2 Watching
  • V Offline
    V Offline
    Not a big issue simply a request if easily doable.
    The MSR logs files inside the container are owned by root witch is fine however, the permissions are very restrictive. I do not know if there is something wrong with my installation but the logs permission are set to 222 (write only). Even if the docker volume is set for Read/Write the log files are retaining these values.
    I go around the problem by doing a chmod 777 on all reactor logs but every time there is an MSR log rotation the permissions are set back to 222. So unless the permission are implemented in the container there is no permanent solution to this (that I know of).
    I do not know much about Docker container so I do not know what is involved here.
    Can the logfiles permission be simply chaged in the container to at least allow "other" read permission?
    Could the MSR log rotation routine implement a chmod to set the permission?
    Just a small anoyance
    Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
      There should not be any log files inside the container. You should not have any reason to access anything inside the container.
      • V Offline
        V Offline
        Ok, I guess that I did not put enough information to be clear. I skipped the intro and went directely into what I beleive to be the issue. I should stick with the issue not the solution. My bad.
        I do not go in the container to access the logs or change permissions but I did looked at them, trying understand how that works. Docker volumes, map the /var/reactor of the container to a directory on the host with read/write premissions. From the host it is then, via samba, shared to my PC where I would like to access the logs.
        Because of the permissions of the files, I cannot access the files directely from my PC. I have to change the permissions on the Host before I can access them (It can however, be access from the hosts by using "sudo" ).
        What I was trying to say in my initial post is that the permission are set to 222 in the container that get mapped to the the hosts and eventually to my PC. Changing the permissions on the host is only temporary until Reactor do a log rotation where the files changed back to 222. If the logfiles in the container were created with something like 226 the "read" permission for "other" would ripple all the way to the hosts a then to the PC.
        Like I said in my first post, I am not a Docker specialist but I thought that the only way to permanentely change the logs permissions would be by the application at the container level where they are created.
        That being said, I have been wrong before!
        Again, not a big deal just convenience.
          Please do an ls -l (on the docker host system) of the directory that's mapped to /var/reactor, and an ls -l of your logs directory. And, please post the contents of your config/logging.yaml file.
          There's something definitely not right with your setup. Files produced by my containers are owned by root, that's normal, but that 222 permission is not something I've ever seen.
          • V Offline
            V Offline
            All my docker applications, including reactor, have a volume in my "automation" folder on the host.
            vezinpi@RPI8G:~/automation $ ls -l
            total 32
            drwxr-xr-x  2 vezinpi vezinpi 4096 May 28  2023 docker-compose
            drwxrwxrwx  4 vezinpi vezinpi 4096 Jan 14 13:41 esphome
            drwxrwxrwx  8     472     472 4096 Feb  8 07:45 grafana
            drwxrwxrwx 12 vezinpi vezinpi 4096 Feb  6 15:25 homeassistant
            drwx------  3 vezinpi root    4096 Feb 22  2023 influxdb2
            drwxrwxrwx  6 vezinpi vezinpi 4096 Jun 20  2024 reactor
            drwxr-xr-x  9 vezinpi root    4096 Feb  8 03:28 ssl
            drwxrwxrwx 11 vezinpi vezinpi 4096 Feb  8 07:52 zwave-js-ui
            Here is the reactor folder:
            vezinpi@RPI8G:~/automation $ ls -l reactor
            total 64
            drwxrwxrwx 2 vezinpi vezinpi  4096 Feb  5 21:38 config
            drwxrwxr-x 2 root    root     4096 Feb  6 14:07 dist-config
            drwxrwxrwx 2 vezinpi vezinpi  4096 Feb  8 06:23 logs
            -rwxrw-rw- 1 vezinpi vezinpi 45473 Jan  3  2022 reactor-config-backup.json
            drwxrwxrwx 7 vezinpi vezinpi  4096 Jun 20  2024 storage
            Here is the log folder. Please note that some files still have read/write permissions for "other" . This is me changing the permission on the host to grant me access from my PC. The most recent one are back to write only (222). As the log rotation progresses they will all become 222.
            vezinpi@RPI8G:~/automation/reactor $ ls -l logs
            total 44688
            -rwxrw-rw- 1 vezinpi vezinpi    6572 Feb  6 14:07 hass_config.json
            -rwxrw-rw- 1 vezinpi vezinpi  288139 Feb  6 14:07 hass_services.json
            -rwxrw-rw- 1 vezinpi vezinpi  308677 Feb  6 14:07 hass_states.json
            --w--w--w- 1 root    root    1802037 Feb  8 08:02 reactor.log
            --w--w--w- 1 root    root    4194194 Feb  8 06:23 reactor.log.1
            --w--w-rw- 1 root    root    4194347 Feb  7 06:16 reactor.log.10
            --w--w-rw- 1 root    root    4194366 Feb  8 02:48 reactor.log.2
            --w--w-rw- 1 root    root    4193980 Feb  7 21:59 reactor.log.3
            --w--w-rw- 1 root    root    4194236 Feb  7 19:04 reactor.log.4
            --w--w-rw- 1 root    root    4194260 Feb  7 17:18 reactor.log.5
            --w--w-rw- 1 root    root    4194318 Feb  7 15:13 reactor.log.6
            --w--w-rw- 1 root    root    4194256 Feb  7 12:39 reactor.log.7
            --w--w-rw- 1 root    root    4193917 Feb  7 10:39 reactor.log.8
            --w--w-rw- 1 root    root    4194228 Feb  7 09:10 reactor.log.9
            -rw-r--r-- 1 root    root      11755 Feb  5 19:45 unhandled.json
            -rwxrw-rw- 1 vezinpi vezinpi   24164 Feb 28  2022 vera-status-initial.json
            -rwxrw-rw- 1 vezinpi vezinpi   48401 Feb 28  2022 vera-user_data-initial.json
            -rwxrw-rw- 1 vezinpi vezinpi 1263301 Nov  6  2022 zwavejs_devices_initial.json
            config/logging.yaml
            vezinpi@RPI8G:~/automation/reactor/config $ more logging.yaml
            logging:
              default:
                level: 4
                streams:
                  - type: console
                    level: 0
                  - type: file
                    mode: 0666
                    maxsize: 4  # megabytes max size
                    keep: 10     # copies of old logs
                    # capture_console: if true, (most) console output will be captured to
                    #                  this stream (if you have multiple streams, this
                    #                  feature can only be used by ONE of them). If you
                    #                  turn this on (true), set the "console" type stream
                    #                  (above) log level to 0 to avoid duplicate logging
                    #                  entries. The default is false, console not captured.
                    #capture_console: true
              app:
                level: 4
              httpapi:
                level: 4
              httpproxy:
                level: 4
              wsapi:
                level: 4
              Structure:
                level: 4
              Controller:
                level: 4
              OWMWeatherController:
                level: 4
              VeraController:
                level: 4
              HubitatController:
                level: 4
              HassController:
                level: 4
              Rule:
                level: 5
              Engine:
                level: 5
            (END)
            Hope this help
              The YAML parser doesn't like the octal value in mode: 0666. The parser library changed standard a while back, and I guess there's so little use of octal in Reactor that yours is the first report that points back to it.
              Change your mode: 0666 to mode: 0o666.
              Additional note/edit here: Use of 0o as a prefix for octal is the YAML 1.2 (2009) standard. Many web-based YAML editors don't support this standard, and will parse that form incorrectly. For example, the YAML editor at codebeautify.org currently parses 0o644 as 0. The YAML checker at yamllint.com works correctly with 0o prefixing (fortunately). Be careful what tools you're using out there, and be suspicious around octal values until you know they are parsed correctly.
              • V Offline
                V Offline
                Super, it worked as expected.
                My MSR installation date from all the way back at the begining of this treck. I do recollect adjusting the # of logs and size but not adding the "mode". In any case, I see from the dist-config/logging.yaml that the default is 0644 (which would work just fine) and that it is commented out. That is probably what everybody have and the reason why I was the lone woolf out there. I think I will follow the pack and comment it out.
                EDIT: I did add the "mode" back in dec 2021 to fix a similar issue. Things have changed/evolved since causing the issue to show up again.
                Many thanks
                • V vezinpi
                  Many thanks
                  @vezinpi said in [SOLVED]Logs permissions for Docker Install:
                  Yes, and that needs to read 0o644 now -- I've fixed that for the next build. The default is actually 0o640 in the code, so I've fixed the distribution template for that as well.
                  • Possible feature request 2?
                    82.3k
                  • Copying a global reaction
